Old 04-05-2011, 08:57 AM   #126
maxxxy
maxxxy's Avatar
Re: maxxy's 81 bagged c10 build
That's how my truck was just one leaf on each side, but it had bags over the axle, which almost rides as bad. Dude we should work out some kind of trade or something for that bed floor.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-05-2011, 11:33 AM   #127
CuRtdOgG
CuRtdOgG's Avatar
What do u got
CuRtdOgG is offline   Reply With Quote
Old 04-06-2011, 01:37 PM   #128
CuRtdOgG
CuRtdOgG's Avatar
Yeah that beds just sitting at my parent...so how hard is it bagging a truck
Old 04-06-2011, 11:33 PM   #129
maxxxy
maxxxy's Avatar
Well pm me your # and sometime we can work something out.
It's really not that hard, I mean I'm not near done, but like for the front, all you need to get is a plate for each side, bags, and fittings.
The back is a little harder, but you can still buy a kit with minimal welding, for pretty cheap, brackets and fittings. If you just want to be pretty low and not necessarily lay frame, you can get it done for under 500. Thats probably without tank, valves, and compressor and switches,(like running off a outside air source) but I found a set of valves, tank, compressor, and switches on eBay for like low 200$.
But laying frame is where you have to get into a lot mor money, or do a lot more of your own fab work. And sometimes both.
Max
Max's bagged 81
Old 04-06-2011, 11:37 PM   #130
maxxxy
maxxxy's Avatar
Did lots of welding today after school. I'm getting all the rear arms finish welded, I would like to be pretty much done with this homemade wishbone four link by the end of the weekend.
Max
Max's bagged 81
Old 04-10-2011, 09:58 PM   #131
maxxxy
maxxxy's Avatar
On Saturday I met CuRtdogG, he was pretty cool and he hooked me up with a deal on his old bed. I really just needed it for the bedfloor and the inner fenders so I can do my raised bed floor.
So I spent the first half of my day working on removing the bedsides and stuff.
There had to be like 50+ bolts plus 4 very hefty spot welds. Lol
Then I spent like an hour with the body hammers getting out every possible dent. Even though it doesn't look like it because it's like 5 different colors, It's now one of the straightest looking old used bed floors I've seen in a while. Haha
Then I spent the rest of my day welding up all the ends on my wishbone, all I have left is to add a couple gussets/ braces, and final weld in my axle tabs.
Max
Max's bagged 81
Old 04-11-2011, 12:21 AM   #132
CuRtdOgG
CuRtdOgG's Avatar
Looks good man. That's gonna be tight
Old 05-09-2011, 06:44 PM   #133
maxxxy
maxxxy's Avatar
Thanks man. I got a little bit done yesterday.
I cut some of my old bed out. Still not exactly sure how I'm going to go about my raised bed. I've seen lots of different ways, but I still dont know yet.
Any input would be appreciated.
Then I got some fittings for a temporary rear end air.
Max
Max's bagged 81
Old 05-09-2011, 11:07 PM   #134
ekjunky80
ekjunky80's Avatar
Question.. what are you going to do with the brackets hangin off the frame for your E-brake cable? what did you/what are you going to do with the hard brake line on the pasenger side that runs to the rear ? Im just noticing these things as im going through my build. Maybe you have seen or talked to someone about this also. lemme know man! lookin good BTW!
Key City Truckers Abilene, Tx.
USAF AMMO
87 C10 (Beulla)
87 Buick Regal Turbo T (Tiffany)
ekjunky80 is offline   Reply With Quote
Old 05-10-2011, 12:27 AM   #135
maxxxy
maxxxy's Avatar
As for the Ebrake cables, I think they are long enough to just keep the way they are and the brackets for them don't hang below the frame so there's no issues with those either.
The hard brake line, I'm going to have to replace the portion attached to the frame, because I accidentally cut it when grinding, but there's the portion that is rubber that connects it from the frame to the axles hard line, from what I've read I believe it's too short to allow much clearance, but can possibly be traded out for a 4x4s because theirs are supposedly longer.
Did I understand your question correctly?
Max
Max's bagged 81
Old 05-10-2011, 12:34 AM   #136
ekjunky80
ekjunky80's Avatar
Thumbs up Re: maxxy's 81 bagged c10 build
yessir, you understood me. thanks. are you laying it out? or are you not trying to make it "Lay frame"? thats where my problem is. Im setting it all the way down. i got a 10" notch for mine. Im sure that cable bracket on the drivers side will hit on mine. what are you doing for a fuel tank? lemme know how you finish up that brake line setup on the passenger side! thanks for the quick reply. time to get back to grinding!
USAF AMMO
87 C10 (Beulla)
Old 05-10-2011, 12:47 AM   #137
maxxxy
maxxxy's Avatar
I might be wrong, but I'm pretty sure the brake bracket is at a place where the frame is not at its lowest. But if that becomes a problem, I'll probably just try to relocate it to run on the outside/inside of frame rail.
I plan to get some drop spindles, and by that point I'll be really close to laying pinch weld, probably less than 1 or 2 inches. I don't remember exactly how far the pinch is in relation to the frame. No idea on the gas tank yet.
Max
Max's bagged 81
Old 05-10-2011, 12:57 AM   #138
ekjunky80
ekjunky80's Avatar
yea i was looking at the way my setup is gonna be and i wouldnt be able to move that bracket cause of where my 4 link bars are going to be located. guess ill worry about it when i get there.
Same for the tank. your raising your bed so you have more options than i would. I wanna put the tank in the rear between the rails, but the tanks ive been looking at look like they hang to low. may just do a fuel cell. Im gettin ideas from all over! hahaa
USAF AMMO
87 C10 (Beulla)
Old 05-23-2011, 01:09 AM   #139
maxxxy
maxxxy's Avatar
Welp this weekend I pretty much got the rear buttoned up. I just have to make a trip to the hardware store and buy myself some good nuts and bolts to replace the once I used for mock up. Plus I need to add my shocks.
I temporarily put the bed on today basically just to help motivate me.
And to remind me that my truck is still a truck. Lol
Then the bed came back off again To make everything easier.
Max
Max's bagged 81
Old 05-23-2011, 01:24 AM   #140
luifer76
luifer76's Avatar
truck looks god man!!!....where are you gonna be mounting the shocks?.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 05-23-2011, 04:24 AM   #141
ekjunky80
ekjunky80's Avatar
hmmm makes me wanna raise my bed floor now...
USAF AMMO
87 C10 (Beulla)
Old 05-24-2011, 02:05 AM   #142
luifer76
luifer76's Avatar
here you go maxxxy i made my own lower mounts and on top i used the ones that the axel came with all i had to do is cut them off and mount them on top....
Old 05-31-2011, 09:13 AM   #143
luifer76
luifer76's Avatar
any updates bro?
Old 06-05-2011, 02:19 AM   #144
maxxxy
maxxxy's Avatar
No big updates really. I've been really busy past couple of weeks and it's just going to get busier. The little time I have had to work on my truck, I just sit there staring at it and scratching my head trying to figure out what to do. Lol
But I did order some belltech drop spindles on Friday. I think they're part no. 3200. They should ship out of Cali on Tuesday and be in little ol Oklahoma by Thursday.
That's all for now I guess.....
Max
Max's bagged 81
Old 06-05-2011, 11:11 AM   #145
luifer76
luifer76's Avatar
right on bro did you go for 2 or 3 inch drop spindles?
Old 06-05-2011, 11:12 PM   #146
maxxxy
maxxxy's Avatar
I got the 3 inch drop spindles. But I don't even know if I can drop the full 3 inches before I hit the bottom of the control arms and/or x member. Lol
I was going to start on my shocks yesterday, but I started to figure out what I was going to do when I realized one of the shocks I had of the two for the rear was bad, so I have to get a new set of rears before I start.
Max
Max's bagged 81
Old 06-06-2011, 12:41 AM   #147
luifer76
luifer76's Avatar
well it all depends on how high is your truck sitting right now with the stock spindles and how high are the control arms from the ground, but i think if you put on the 3 inch drop spindle you should be able to tuck your wheels in pretty good, you should get the truck on level ground or concrete and take pic of the rockers before and after the drop spindle to see how much lower it gets but your control arms are gonna hit first thats for sure keep us posted bro....
Old 06-10-2011, 09:31 AM   #148
JohnC
JohnC's Avatar
Hey Max coming along nicely. You guys didn't get any damage from the tornado a few weeks ago did ya?
JohnC is offline   Reply With Quote
Old 06-23-2011, 11:21 PM   #149
maxxxy
maxxxy's Avatar
Okay its been a little while, I have half of an update. Lol I got my spindles in a day or two ago and I started to put them on. I got on the drivers side and realized I was hitting the bottom of my control arm way before anything else. So I did some trimming there. I ended up only getting about two inches of drop and now I think my upper ball joint is binding. But oh well. Lol*
here's the pics.
Pass side w/o drop spindles
Driver side with drop spindles
Max
Max's bagged 81
Old 06-24-2011, 12:25 AM   #150
luifer76
luifer76's Avatar
oh hell yeah bro it looks lower and better yep.... any updates on the rear of the truck and bed?
1981, bagged, c10, custom, oklahoma
