Old 10-07-2010, 04:14 PM   #126
PBFAB.COM
PBFAB.COM's Avatar
Re: Make it handle
I would drill mine.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-07-2010, 05:54 PM   #127
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Make it handle
with my 2.5" drop spindles I added tubular upper control arms to my low budget build because I wanted the extra 5* of caster....if needed I'd drill for more.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-07-2010, 10:08 PM   #128
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Make it handle
Originally Posted by robnolimit View Post
...So, Are you guys willing to drill out the spindle, or not??What do you think about this??
If it were part of a tested package, sure I would do it. Keep in mind, I am rather conservative about modding anything with out a proven reason.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-08-2010, 02:17 PM   #129
Wvgearhead
Re: Make it handle
Rob,
I am setting up a 3 link wishbone(triang 4) and I am having trouble with fitting everything
around the driveshaft. What do you think about this set up, 57% Anit Squat,16RCH, 2* roll oversteer, Ic 127" 13", I think my Cog should be around 18 or 19. Wheel base is 116"
Wvgearhead is offline   Reply With Quote
Old 10-08-2010, 02:50 PM   #130
M5-
Re: Make it handle
I'd have no problem drilling that out especially if it gave you the option of using a high quality Cro Mo rod end.
M5
M5- is offline   Reply With Quote
Old 10-08-2010, 03:57 PM   #131
robnolimit
robnolimit's Avatar
Re: Make it handle
Good feedback, keep it coming. Those that know me, know that safety is a concern, and I tend to overbuild.
WvGearhead first off, you need to speek up more often. How about some picts. How are you getting your numbers? Are you using Suspension-Pro? You seem to be up on this stuff. Thats great. Your set-up seems to be pretty good, I'm guessing your tire is about 29" dia. thats puts your roll center a few inches above the axle center line (hieght). I would consider lowering it a bit, or at least allowing for an adjustment later, second set of forward holes. Some squat in a truck is good, to help with some weight transfer. Lets go over this on the forum so everyone can check out your work. How about shocks/springs?
robnolimit is offline   Reply With Quote
Old 10-08-2010, 04:34 PM   #132
ctrow
New Member
ctrow's Avatar
Re: Make it handle
I'm going to have to do some reading....
Great thread BTW.
The questions I have are related to materials. Where does one find the right tubing and end links for fabricating things like rear end linkage?
Mabye it's covered in the recommended reading earlier in this thread.
Of course it probably makes sense to buy off the shelf on some items. Nothing like making your own pieces though.
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=366351
ctrow is offline   Reply With Quote
Old 10-08-2010, 05:47 PM   #133
Wvgearhead
Re: Make it handle
Rob,
I am building a 53 3100 on air, The front is a tci MII and the rear is a custom built Wishbone I picked up, The wishbone and the lowers both span 28", so it should keep constant pinion angle. My problem is, I didnt think about the driveshaft...hmmm, So now I am trying to get the best numbers I can without having to flip the wishbone around and put the single on the center section. I used a suspension calculator from a 4wheel drive form. I dont have any big intentions on racing the truck, but you never know. I figure I would atleast try to make it real fun to drive anyway. The numbers I am plugging in are: upper links ,frame end x=28 y=0 z=17.50 Axle end x=0 y=17 z=18.86 lower links frame end, x=28 y=17 z=9.14 axle end x=0 y=17 z=8.14. This equals AntiSquat=%57 RCH17", IC x=127" z= 13" Roll oversteer 2*, travel roll axis -2.78*. I am not sure about the roll steer, how much is too much. How do you think this set up would handle and ride? The Cog I am guessing to be around 19", and as for the tire size I am planning on running around a 26" tire.
Aaron
Old 10-08-2010, 05:48 PM   #134
Wvgearhead
Re: Make it handle
Oh yea just in case, X=0 on the axle y=0 at cl of chassis and z-=0 at shop floor
Old 10-08-2010, 07:21 PM   #135
PBFAB.COM
PBFAB.COM's Avatar
Re: Make it handle
Wvgearhead- What kind of power is your drivetrain puting out? You could always run a 2-piece driveshaft as well. It should take care of your clearance issues on your upper wishbone.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-08-2010, 07:23 PM   #136
PBFAB.COM
PBFAB.COM's Avatar
Re: Make it handle
Great thread BTW.
We can sell you any of the necessary parts to make your own linkage and or make recommendations to help you out.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-08-2010, 07:58 PM   #137
ctrow
New Member
ctrow's Avatar
Re: Make it handle
Can't you just move to okc so I can work off materials and learn something as I go? Lol
I can't seem to find the books mentioned earlier on learning suspension. Anyone got the names of them?
Old 10-08-2010, 10:09 PM   #138
M5-
Re: Make it handle
Man looks I got some serious learning to get after.
M5
Old 10-08-2010, 10:34 PM   #139
Wvgearhead
Re: Make it handle
I am running a 450 hp small block, hopefully a lt1 t56 if I can find one and a 8.8 rear with a locker and 373s. M5 there are books, but you can learn alot by google. I looked at some other forums geared for road racing. The best calculator I have found was actually on a 4 wheeldrive forum. I still need to read a lot more, but I'm learning.
Aaron
Old 10-08-2010, 10:37 PM   #140
Wvgearhead
Re: Make it handle
An extra ujoint scares me, I have been known to break things. Lol
Old 10-09-2010, 12:07 PM   #141
robnolimit
robnolimit's Avatar
Re: Make it handle
Wv Do you have the motor/trans mocked up yet? Remember that it is helpfull to mount the motor as low, and as far back, as you can. Sometimes we notch the MII crossmembers and box them back up to create more oil pan clearance. The bottom of the pan can be even with the running board. it will look small in the engine bay, but it will drive/handle better. Also, the low motor/trans hieght may solve your driveshaft issue. Try to keep the carb base level with the frame, crank angle will then be about 3*, then match the pinion.
Info search, I'll post up some book/web/chart info later
Old 10-09-2010, 12:37 PM   #142
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Make it handle
..... a copy of Herb Adams suspension book. If your a computer guy, buy a copy of "suspension geometry pro" ....
Google Herb Adams "Chassis Engineering" and you will get several hits.
Articles-
"Refining Sierra"
Old 10-09-2010, 02:21 PM   #143
Wvgearhead
Re: Make it handle
Great rob, thanks
Old 10-09-2010, 06:36 PM   #144
PBFAB.COM
PBFAB.COM's Avatar
Re: Make it handle
Google "Carroll Smith". He has written several good books inlcuding Tune to Win, and Engineer to Win. These are great books that will really open your eyes and understaning. After the books, purchase a suspension analyzer program. Rob mentioned a great one earlier in the thread "Front Suspension Geometry Pro". It's a great and affordable program, just over $100. I bought one several years ago and even bought the new version a couple months back to see how I liked it. I also have some more expensive software including Bill Mitchell's WinGeo... It's more complicated to use.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-10-2010, 03:09 AM   #145
leftcoast66
leftcoast66's Avatar
Re: Make it handle
Thanks Nate for the info, I've read Herb Adams, I'm gonna have to pick up the Carroll Smith's books next. What would you guys suggest for material size for building a frame. What dimensions and thickness are working best for the frame builders.
leftcoast66 is offline   Reply With Quote
Old 10-10-2010, 01:40 PM   #146
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Make it handle
Originally Posted by leftcoast66 View Post
Thanks Nate for the info.... What dimensions and thickness are working best for the frame builders.
From another thread entitled- what size metal to build rear frame?
We build ours from 2x4x.120.
Originally Posted by FnLow69 View Post
Same here, even Art Morrison chassis are 2x4x.120 wall.
Originally Posted by BlueJeep View Post
2x4x.120 works for me, and this is exposed to a lot more stress than a street driven truck. A lot of it has to do with the competency level, engineering ability, and welding ability of the builder.
Articles-
"Refining Sierra"
Old 10-10-2010, 04:36 PM   #147
robnolimit
robnolimit's Avatar
Re: Make it handle
We build a three piece main rail. 2 x 6, .188 wall in the middle (appx firewall to the start of the rear fick) and 2 x 4, .188 on each end. Yes, its a bit heavier, about 85 lbs over a 2 x 4 .120 wall pair of rail, but this is good weight. - low and centered. Our X-members for these trucks are 2 x 4 .120.
Old 10-10-2010, 05:58 PM   #148
leftcoast66
Re: Make it handle
Thanks Rob and N2TRUX for the help.
Old 10-10-2010, 09:15 PM   #149
dnd1978
dnd1978's Avatar
Re: Make it handle
[QUOTE=robnolimit;4167810]The whole goal of A arm swapping, and I don't know if this really works, is to increase positive 'Caster'. Stock C-10's spec out 1 or 2 degrees, but your truck will respond well to 6 to 7 deg, and more for the wide tire guys, bigger than 8". To my knowledge, nobody makes a set of arms to gain caster, may someone should. The trick is to move the lower ball joint forward about a 1/2", and the upper ball joint back about 7/8", this will keep the wheel centered and net about 8 deg. + caster.
Robnolimit,
I just found this. Hotckis make the corrected A arm. What do you think?
http://www.hotchkis.net/search.html?...mitForm=Search
dnd1978 is offline   Reply With Quote
Old 10-10-2010, 11:25 PM   #150
SCOTI
SCOTI's Avatar
Re: Make it handle
[quote=dnd1978;4234154]
Robnolimit,
This kit was mentioned back on posts 116-118 (referred to as the 'H' kit).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
