Old 02-08-2013, 01:57 PM   #126
gettmoneyy7
gettmoneyy7's Avatar
Re: My 82 shortbed
Originally Posted by moregrip View Post
fantastic! what brand if I may ask? easy to apply?
Ah I don't remember I'd have to take a look and let you know when I get home .... I sprayed it with a low pressure system and wasn't hard at all to apply
gettmoneyy7 is offline   Reply With Quote
Old 02-09-2013, 03:36 AM   #127
mud.man.rj
mud.man.rj's Avatar
Re: My 82 shortbed
One complete loop cut off a front spring usually ends up being about 2" of drop. So in your case you only want 1" more which is 1/2 a loop.
mud.man.rj is offline   Reply With Quote
Old 02-09-2013, 02:16 PM   #128
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: My 82 shortbed
Another idea: you can see how low it sits with the motor and tranny weight on the frame as well, then pop off the spring and cut it to your taste before you put the fenders on?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-09-2013, 03:27 PM   #129
gettmoneyy7
Re: My 82 shortbed
To be honest with you I'm not to sure.. I asked a buddy of mine that had gave me it it was what he had left and he's not sure the brand .. He said all the self etching is pretty good and will run you probably like 40 a quart . Sorry I couldn't help best of luck to you
Old 02-09-2013, 03:32 PM   #130
gettmoneyy7
Re: My 82 shortbed
As of right now I have motor and tanny in and cranks up on the frame Suspension is in, both gas tanks all the fuel lines I'm just running behind in posting the pics didn't post for a wiel cuz I was busy as hell working on it .. Picture leading up to that are coming soon. Cab isn't quite done yet but getting there .. Thanks for the advice I got some experimenting to do with the springs. Appreciate everyone's help. Hopefully I can help you guys out in some way in the future .
c10, frame off build
