Old 07-09-2014, 12:24 PM   #126
99 to Life
99 to Life's Avatar
Re: You guessed it, 1950 s10 swap.
cool, glad your iroining things out. only way you really learn how stuff work is to have it not work, then work!!!! I keep telling myself that, it breaks so you know how to fix it. Keep us posted.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-10-2014, 12:56 AM   #127
Root2812
Root2812's Avatar
Now that you have it on the road, how is the pusher fan working for you?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 07-10-2014, 09:54 AM   #128
oldman3
oldman3's Avatar
Glad to see you have it on the road...Jim
oldman3 is offline   Reply With Quote
Old 07-11-2014, 10:15 AM   #129
Layedoutsonoma91
Layedoutsonoma91's Avatar
Im still working all the bugs out of course. As far as the pusher fan. I have driven it probably 100 miles since i finished it. Havent overheated yet. Stays around 180-200. These engines normally run over 200. Gotta figure out if i got somethong wrong in the cooling system or not. I got black fluid that keeps showing up. I thinm its dexcool mixed with green. Im gonna flush the system and see what i get. Steering linkage is messed up. I think i may have the center link on backwards. The pass side where the tierod connects to the center link. The nut tightens all the way down and the cotter pin hole is like almost a half inch away from the castle nut. It tightens way too far. Other side barely tightens to the castle nut. Im thinking the taper or stud side is different per side. If not i got a defective center link
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 07-15-2014, 03:48 PM   #130
Layedoutsonoma91
Pics in next post
6.0 ls swap/4l80e
Past build thread
Old 07-15-2014, 04:00 PM   #131
Layedoutsonoma91
Had a photoshoot with the truck sunday. Perfect weather and lighting. Im really happy with the pics. Thought i would share. These were sent to me via the internet ill have the higher quality later this week.
6.0 ls swap/4l80e
Past build thread
Old 07-15-2014, 04:02 PM   #132
youngrodder
youngrodder's Avatar
The shots look great...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-15-2014, 08:02 PM   #133
99 to Life
99 to Life's Avatar
gotta love a little pro photography, world of difference. the bridge shot is my favorite. Congrats on the truck.
Old 07-15-2014, 08:35 PM   #134
Layedoutsonoma91
oh yea, he did a good job. Love driving this thing. Thanks for all the support guys
6.0 ls swap/4l80e
Past build thread
Old 07-16-2014, 10:27 AM   #135
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome truck!
ChuckDriver is offline   Reply With Quote
Old 07-16-2014, 01:37 PM   #136
steve aleve
Man this thing is looking great!!! I've been following the build for a while now and I love it. Ive got a 55.1 that I am doing a S10 swap on and I was going to use a TPI L98 from an 88 Trans am that is laying around but I recently came on a 5.3L LS engine out of a 03 Silverado. It is basically the block, heads, intake and throttle body. Early on you briefly mentioned the parts needed to take the engine to where it is now. Do you have a detailed list of everything you picked up?
steve aleve is offline   Reply With Quote
Old 07-16-2014, 07:01 PM   #137
JakeDW
JakeDW's Avatar
Cool AD
Jake
JakeDW is offline   Reply With Quote
Old 07-20-2014, 12:19 AM   #138
Layedoutsonoma91
Do you wanna go with ls car intake or use the truck intake. The truck pulleys work better on our trucks, but the car intake looks so much better. I had to get a ls1 water pump and spacers to space it out. Idler pulley relocator. a smaller power steering pulley and the intake cost. probably costs a good 1000 bux to swap to the ls6 intake from truck. Truck intake all you would need are all truck access. and get the smaller power steering pulley. You would need a harness and computer of some sort. either stock or aftermarket.
6.0 ls swap/4l80e
Past build thread
Old 07-20-2014, 06:58 AM   #139
4DSEVEN
4DSEVEN's Avatar
Awesome build, congrats!
4DSEVEN is offline   Reply With Quote
Old 07-20-2014, 05:49 PM   #140
steve aleve
Thanks man that helps a bunch. I think I'm gonna go with the car intake cause it just looks so sweet! I did find this online and wanted to see what you thought. This guy was able to use all of the truck stuff up front and with a couple cuts and minor mods he could fit the car intake. Maybe a good way to go.
http://ls1tech.com/forums/generation...-3-vortec.html
Old 07-20-2014, 11:27 PM   #141
Layedoutsonoma91
That guy did the same thing I did. only difference is the throttle body is drive by cable. It has enough room to run the truck pump water neck beside it. Mine is drive by wire, the water neck hits the throttle body so bad it wont bolt on. That's why I needed the car water pump cause the neck comes out at the side.
6.0 ls swap/4l80e
Past build thread
Old 07-30-2014, 03:36 PM   #142
steve aleve
I appreciate the help. I hate to keep bugging about details but what cam did you choose to go with? Stock or something a bit more lumpy?
Old 08-19-2014, 09:22 PM   #143
Layedoutsonoma91
Sorry for the slow reply, I just used the stock cam. I haven't touched the internals of the motor other than valve stem seals. And ask away man! I'm not bothered by it, that's why i post! I've got so much information off this site, I wanna return the favor. I wanna help any way I can.
6.0 ls swap/4l80e
Past build thread
Old 08-19-2014, 10:09 PM   #144
99 to Life
99 to Life's Avatar
the LS engines are insane bang for the buck when it comes to performance. The stock cam if you think about it (if a truck engine) is designed for torque. Your putting it in a truck that weights atleast 2k lbs lighter than the original intent..... I can only imagine how fun that would feel. Torque is what we are feeling till about 5,252 rpm anyway, then its usually all HP after that. It's like GM thought of this stuff way back when, seems to work out well for us in the long run.
Old 08-19-2014, 10:42 PM   #145
Layedoutsonoma91
Oh yeah. The truck weighs about 3100lbs with me not in it. So its aptly named. Lol . This motor on this truck is PLENTY fast enough for me. My wife tried to drive it the other day and couldnt handle it haha.
6.0 ls swap/4l80e
Past build thread
Old 08-19-2014, 11:04 PM   #146
99 to Life
99 to Life's Avatar
hahahhah the wife couldn't handle it, cracked me up. I tell my gal we aint getting married till she drives my truck. Its a standard so its gonna be a little harder for her I know that.
the weight sounds about right. I'd like to get my current project weighed when done, lot of fab work on it and welding, coatings etc. that stuff adds up in weight.
Old 08-24-2014, 02:04 PM   #147
Layedoutsonoma91
Haha. I want her to be able to drive it if something happens. She said it scares her. Here are some pics of my emblems I had made and rusted to match.
6.0 ls swap/4l80e
Past build thread
Old 08-26-2014, 11:55 AM   #148
steve aleve
So you are saying the truck intake is more than sufficient, Good to know. From what I know, the engine I bought had "lifter tick" and so I will have to replace the cam and lifters anyway. Here is another question, when you bought the LS1 intake, did you try to make sure to get the intake, rails and injectors in a package deal? Am I asking for trouble in the long run if I go with a mix and match package? Also what is a good price for these? I am seeing some outrageous numbers on "the worlds #1 bidding site" and unfortunately I can't find many locally through Craigslist.
Old 08-26-2014, 12:29 PM   #149
Bone$
If you can look for a ls6 car intake. These are HP readings off the same motor just swapping intakes. Not that a Small light truck would need more HP than a stock LS1 but hey why not.
LS1 Intake: 464 hp @ 6,200 rpm & 446 ft-lbs 5,100 rpm
LS6 Intake: 470 hp @ 6,400 rpm & 450 ft-lbs at 4,900 rpm
Largest Gains: 14 hp @ 5,800 rpm & 13 ft-lbs 5,800 rpm
Truck looks badass BTW..
Bone$ 54 Gmc Build
Bone$ is offline   Reply With Quote
Old 08-27-2014, 10:17 PM   #150
Layedoutsonoma91
I got the intake, rails, and injectors all from different sources. Changing from a truck intake to a car intake is basically only for looks. you wont gain anything in fact if you use a LS1 intake you will lose power. LS6 intake is the way to go if you want to change it. I would recommend keeping the truck intake. It will save you a lot of money. I ended up spending an extra 1000 bux easily going to a car intake.
6.0 ls swap/4l80e
Past build thread
