Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-27-2013, 06:24 PM   #126
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Project 30 years sitting
Its not easy when you have to remove that much metal to keep things aligned. Looks like you're doing ok though. Keep welding. tack, tack, tack, tack, tack, grind, tack, tack, tack...
hgs_notes is offline   Reply With Quote
Old 03-29-2013, 08:48 AM   #127
Dale99
Yep, thats what I'm doing. Also trying to educate the neighbor kid thats been helping. Every time you hit the welder, the lights flicker. We joke about it being a dance club
Got a new larger tool box last night. Spent the whole evening getting it, and transferring tools. Still have a few hrs left of that, then put it in place.
Then I got in a slight wreck this morning with the new truck. Will have to spend time fixing it. Will have to make a part to replace some of this plastic crap.
Dale99 is offline   Reply With Quote
Old 04-04-2013, 10:15 PM   #128
Dale99
No pictures, but I have the 1st run of welding done all the way around it. Now it will be a ton of grinding so I can do 2nd run wherever I missed.
This is where I wanted it because I have to move it this weekend to fix a hole in the ceiling and work on the sierra.
Old 04-16-2013, 10:28 AM   #129
Dale99
Alright, forgot to take pics of my floor. But drivers floor is done, even a light rattle can spray of a paint color I am debating to paint it.
Stereo is in, so I have tunes while driving. Makes it so much nicer.
Picked up an np205 transfer case from a board vendor "American trucks" Also got a passenger fender that needs a cup, and a grill thats better then what I have.
Also made an aluminum skid plate for my sierra since the stock plastic one one got destroyed.
Then this coming weekend I am going to meet up with user "teeitup" for some driveshafts, rear hatch, and few other parts. Then also swing by LMC and get some bumpers and patch panels.
Old 04-16-2013, 11:39 AM   #130
Wasted Income
Boosted Member
Wasted Income's Avatar
Nice work on the skid plate.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-16-2013, 02:19 PM   #131
Dale99
Thanks. Getting the bottom heli-arced was quite a chore. I ended up just tacking it on the truck, then putting it in the garage and built a wind-shield.
Old 04-22-2013, 12:15 PM   #132
Dale99
So I spent this past weekend gathering parts. Also got my seats back before I left. Fronts look great, rear I am not happy with.
Old 04-22-2013, 12:16 PM   #133
Dale99
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Old 04-24-2013, 11:29 PM   #134
hgs_notes
GEARHEAD
hgs_notes's Avatar
Nice pics. Truck is looking good. What's wrong with the rear seat?
Old 04-26-2013, 11:06 AM   #135
Dale99
Rear seat, I wanted two "humps" like the original design. Not a flat sheet of velour like this. Also the stiff board that came behind the seat is gone, as well one of the seatbelt bolts got lost and replaced with one that is not correct. And it did have the correct one before. One of my ash trays got lost also.
Old 04-29-2013, 09:09 AM   #136
Dale99
So this weekend I got my "new" hatch from teeitup installed. My electric pusher fan installed, and my driving lights working. Also while working on this, I had a guy pull up that heard I was looking for a passenger fender. Talked to him for a while and traded some of my extra parts for his repo fender. SCORE!
Cant wait to get my transfer case adapter in, so I can start working on getting a working TC in this.
Old 05-06-2013, 09:54 PM   #137
Dale99
New transfer case is in. 2 used drive shafts. So now my distributor is not touching my firewall Plan to adjust timing and take for a test drive tomm.
Old 05-08-2013, 09:55 AM   #138
Dale99
So test drive was somewhat interesting.
I have the wrong shifter, so I only had 4low and neutral. So did test drive w/o the trans hump. Everything works, so I need a new shifter.
Front drive shaft needs a new cardan(sp?) joint
Transcase needs more fluid in it.
Was able to set timing now, and engine starts/runs better.
Also fixed a few of my pinhole exhaust leaks.
Old 05-14-2013, 05:48 PM   #139
Dale99
New shifter should be in today.
Front cardan joint replaced
fluid in transcase.
Figured out my balancer on engine had spun due to no crank key. Fixed that.
Going to prime my repo passenger fender, bolt it on, then hopefully onto rear skins.
Old 05-19-2013, 08:45 PM   #140
Dale99
So today was a day of making IT work. Started out fun n great. Went down some trails made for walking, with it. Loaded it with some scrap metal, and returned the same trail.
Unloaded it, drove it across town to pick a friend up. Come back and its leaking oil around the new timing cover. Didnt surprise me. Rig it up for now with some silicone so we can go trail riding. Get down the first big hill, idles rough, stumbles n stalls. 30min of random trying and no fire. Friend hikes back to the house to get my other truck. Hook up, snap tow strap in 10 seconds. Get another strap, turn truck around. Walk it up the hill. Then to get down the hill, we switch leads and let it roll down stopping it with the working truck.
Get home, it starts . I am guessing I overheated the icm???
Going in.
coming out.
Old 05-19-2013, 10:37 PM   #141
hgs_notes
GEARHEAD
hgs_notes's Avatar
Vapor lock? Started after cooling down. Something to do with going downhill? Angle of the carb and fuel in the float bowls flooding it? Might be too high a float level. Just guesses.
At least you got it out and had some fun. Mine ain't there yet. Started redoing the exhaust on my C-10 today, so it is OOC for a short while too.
Old 05-20-2013, 08:19 AM   #142
Dale99
I had drove down this trail before and made it. So all the carb settings should have been fine.
I think something just heated up and quit. This is the hottest temps I have drove it in(90deg). But if it cant take these, it sure wont take this summer(sometimes it gets 110).
Old 05-24-2013, 09:22 PM   #143
Dale99
So after investigating, the radiator cracked right under the upper rad hose. So new 4core is laying in my garage.
Also, my timing cover change is still leaking after 2 fixes. So its back off and noticed this thing has a plastic cam gear. WTF, That is coming OFF!!!
Still cant find an upper rad hose thats preformed.
Old 05-24-2013, 11:17 PM   #144
hgs_notes
GEARHEAD
hgs_notes's Avatar
LMC has the hose.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=117
Timing chain cover leaks suck. I finally got mine down to a slow drip. Crappy design.
Old 05-25-2013, 04:15 PM   #145
Dale99
found a hose locally for a 72 elcamino that works.
Time to mow.
Old 05-27-2013, 02:17 PM   #146
Dale99
Alright, back together and running. Also found a vac leak. So new rad, hose, timing chain, and some vac hoses. Readjust the timing. Wow, runs 10x better then it has since I have had this thing.
Replaced the right inner fender from being cut out. Time to wirewheel the floor and see how bad this rust is. I think its all surface.
Old 05-27-2013, 06:51 PM   #147
Dale99
I guess since I lack picture updates. Here is some of this weekends projects.
Old 05-27-2013, 06:53 PM   #148
Dale99
Old 05-28-2013, 06:00 PM   #149
fear_nothing
fear_nothing's Avatar
Sorry if I missed this post.... what can you tell me about your radio? My dash is uncut & I'm still rocking the OEM radio. I've been reluctant to cut the "virgin" dash.
fear_nothing is offline   Reply With Quote
Old 05-28-2013, 09:43 PM   #150
Dale99
I got the retro-sound kit. You can get thru lmc, or strait from the mfg. It has 2aux inputs, am/fm, and a usb port to plug in a thumb drive(or maybe even an icrap).
Main thing I like is that you dont cut the dash.
I wish I would have gotten chrome rather then black.
It takes a few seconds to "turn on" and has an annoying banner that goes across the screen.
It is a little loose around the knob holes. I wish it was a little more secure there.
I only have a dash speaker at the moment, so over my exhaust, its fairly hard to hear. I plan to put more speakers later, but I have other fish to fry first. If you want me to do a video of it for you, I can do that.
