Old 01-17-2013, 04:30 PM   #126
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
It is stalled out right now. I have been busy with work and some other projects lately.
I hope to get back at in the next couple weeks.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-17-2013, 07:00 PM   #127
NEWFISHER
NEWFISHER's Avatar
It's the best looking rig in the driveway!
NEWFISHER is offline   Reply With Quote
Old 01-17-2013, 07:10 PM   #128
Coach529
Coach529's Avatar
Thanks, but that is not saying much.......
1949 Chevy 3600
Old 01-17-2013, 07:50 PM   #129
NEWFISHER
NEWFISHER's Avatar
Well, my driveway has My wifes 2008 Tahoe, my 2006 GMC crew cab 2x on bags and my 97 Chevy 1 ton 4x crew dually camper hauler and the 50 Burb. I drive the 50 burb and my neighbors think I'm nuts. Not saying much is me saying I would drive that sweeeet blue truck before any of the others
Old 01-17-2013, 09:53 PM   #130
Coach529
Coach529's Avatar
I am sure it will be the most used ride......except during those hot summer months when the top comes off the Jeep!!
I cannot wait!!
1949 Chevy 3600
Old 01-27-2013, 03:19 PM   #131
Coach529
Coach529's Avatar
looking for some water pump advice.....
1949 Chevy 3600
Old 02-10-2013, 11:55 AM   #132
Coach529
Coach529's Avatar
Despite water pump issues, we are still making forward progress.
Time to install the new Sid's lowered 1/2 ton axle.
Height reference picture!!
15 minutes and a grinder with a skinny wheel and the stock 3/4 ton axle was out.
The ultimate goal is a 5"-6" drop. The axle is 4" drop, so the remaining 2" of drop will come from tires and removing some leaves from the spring pack. To start I removed 2 from the bottom of the stack. The spring retainer bolt came out easy, but I replaced it anyway.
Today I need to round up a puller for the steering arm and start installing the new stuff!!
1949 Chevy 3600
Old 02-10-2013, 12:08 PM   #133
Dan in Pasadena
Dan in Pasadena's Avatar
Hi Coach,
It looks from this photo like you pulled the smallest leaf and then the 3rd smallest leaf, is that correct?
Any plans to put Teflon between the leaves to smooth out the ride? This once was a common upgrade that I never seem to see anymore on our trucks. I THINK its because everyone's into IFS. I'm planning to try that when I pull my spring packs apart for cleaning/painting.
Dan in Pasadena is offline   Reply With Quote
Old 02-10-2013, 12:11 PM   #134
Coach529
Coach529's Avatar
Originally Posted by Dan in Pasadena View Post
Hi Coach,
That is correct, 1st and 3rd leaf pulled from the bottom.
I though briefly about the teflon.......but then kind of forgot all about it.
1949 Chevy 3600
Old 02-10-2013, 12:23 PM   #135
mechanixman
mechanixman's Avatar
Great work Coach,
It look fantastic
I haven't heard of the Teflon idea before.
What product would you use to coat the springs?
(I'm pretty sure it's not Teflon tape. Ha ha)
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 02-10-2013, 02:13 PM   #136
Coach529
Coach529's Avatar
Originally Posted by mechanixman View Post
Great work Coach,
It look fantastic
http://www.speedwaymotors.com/Flat-S...ners,7471.html
1949 Chevy 3600
Old 02-10-2013, 02:42 PM   #137
NEWFISHER
NEWFISHER's Avatar
How's the water pump issue?
Old 02-10-2013, 02:53 PM   #138
_Ogre
_Ogre's Avatar
going to color match the interior?
shop air compressor timer
Old 02-10-2013, 03:02 PM   #139
Coach529
Coach529's Avatar
Ongoing.
I made a couple gaskets and did a multiple layer of Honda Bond and 2 gaskets to try and take up the dish on the pump.
It sealed it up better.....it now only leaks when it runs.
It leaks so little it evaporates off the block now at idle.
I am just stepping away from cooling system issues for a bit.......Frustrated.
1949 Chevy 3600
Old 02-10-2013, 03:04 PM   #140
Coach529
Coach529's Avatar
Doubtful....but I do have a matching bucket and pad for the passenger side. :-)
1949 Chevy 3600
Old 02-13-2013, 12:08 PM   #141
Coach529
Coach529's Avatar
Not much progress.
I got the axle bolted up, along with my disc brake bracket bolted up on the passenger side and that is it.
Running to the junk yard shortly to ditch my old stuff and hopefully find some temp 15", 5 on 4-3/4" rims to use.
1949 Chevy 3600
Old 02-13-2013, 11:03 PM   #142
Coach529
Coach529's Avatar
Little more progress tonight.
I had to change out the races in the hubs. They stockers came out easy with a punch and hammer. I hit the hubs with a torch and left the new races in the freezer for a couple hours. Went together perfect!!
Next came packing bearings and assembly!!
I could not install the nut and cotter pin. I need to install a couple thick washers so the hole in the spindle aligns with the nut.
Money shot......Henry at ride height with 28" wheels!!
1949 Chevy 3600
Old 02-13-2013, 11:15 PM   #143
mechanixman
Looks great!
Those discs really look slick. So you've gotten SID's dropped axle for the front, are you going to do anything to the back?
-Nick
Projects:
Old 02-13-2013, 11:18 PM   #144
Coach529
Coach529's Avatar
Looks great!
Yea updates rear end, axle flip and notch. Running boards will be parallel with the ground!!
1949 Chevy 3600
Old 02-14-2013, 01:01 AM   #145
NEWFISHER
NEWFISHER's Avatar
Looking good! I'm liking Henry's patina.
Old 02-14-2013, 08:40 AM   #146
Garys8
Garys8's Avatar
Cool old truck. I was never a fan of those pre-55ish years but I really like yours. That CLR clean up is great.
Garys8 is offline   Reply With Quote
Old 02-14-2013, 09:25 AM   #147
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Seeing the corn supply over the visor brought back memories of a 1950 pick-up I had. When I pulled the headliner down, there was a mouse nest that was 8"s wide and stretched from one side to the other. Must have been a multi family dwelling. Your truck looks great, keeping an eye on the progress.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 02-14-2013, 10:24 AM   #148
Coach529
Coach529's Avatar
Thanks Fish!!
1949 Chevy 3600
Old 02-14-2013, 10:25 AM   #149
Coach529
Coach529's Avatar
Thanks....I am pretty proud of it.
1949 Chevy 3600
Old 02-14-2013, 10:26 AM   #150
Coach529
Coach529's Avatar
Thanks Jim. I am guessing this was a condo for quite some time. I keep vacuuming and blowing stuff out and still keep finding nest material and poop.
Oh well.........
1949 Chevy 3600
