Old 04-09-2014, 10:36 PM   #126
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 86 Silverado K20 12V CUMMINS Build
It turned out really nice! Nice work.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-15-2014, 09:46 AM   #127
shopteacher
All I can say is Way to hang in there! Great Info and attention to detail ! Too bad your not closer as I have a couple of divorced 205's one drivers side and the other passengers side drop!
Well spring should be about over up there and I'm looking forward to seeing more, so keep up the good work!
Cheers !!
shopteacher is offline   Reply With Quote
Old 06-17-2014, 11:12 AM   #128
brimc
brimc's Avatar
Cheers !!
Thanks for the comments. I too wish you were closer as there is nothing anywhere in a 205. Still searching kijiji every week but they are very rare and made of gold up here.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 11-23-2014, 04:45 PM   #129
brimc
brimc's Avatar
Wow. Been 5 months since last post. Couldn't find the build, way down pg.2
Well it has been a crappy and busy couple of months. We found out of the 4th of July that my father had cancer. We all found out the same day, even him. The next 6 weeks was a battle that I would not wish on my worst enemy. He only came home once for a few rough days the 2nd week of July and passed away on the 10th of August. That was a whir wind blur of a 6 week span.
One of the last things he said to me on one of the last nights when he was still responsive was that he still wanted to see "that truck run".
Needless to say, I haven't hardly worked on the truck. But I did do some cab work in the late spring and now in this last week I worked on the engine. After I get my uploads finished on my super slow internet Ill have some updates.
BRIAN
Old 11-23-2014, 06:45 PM   #130
brimc
brimc's Avatar
Last spring I cut out all the rust and patched up the floors with 18gauge. I rebuilt-replaced the two skis with 3/16 angle.
Got the doors hung and setup-replaced the rockers and cab corners.
I have got the cab completely welded. Just needs some more finish sanding then it will be ready for the POR15 treatment.
BRIAN
Old 11-23-2014, 06:54 PM   #131
brimc
brimc's Avatar
So fast forward from last spring until mid October. I was thinking about all the times during the winter that I have time to work in the garage but just can't for more than a few min because I can't feel my fingers anymore.
So........................
I installed a zero cost reclaimed SS chimney out the back wall.
and then installed a freebee wood stove/furnace.
So far it works awesome.
BRIAN
Old 11-23-2014, 07:02 PM   #132
y5mgisi
Second Chance Program
y5mgisi's Avatar
Drooling over the heated shop!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-23-2014, 07:07 PM   #133
brimc
brimc's Avatar
So last Sunday I fired up the stove in the Garage and un covered the Cummins. I picked up everything needed to button up the engine. Front crank seal and gaskets, valve cover gaskets, engine oil, filters etc, etc, etc.
While I had it apart, I decided to re-do the KDP and loc tite and re-torque the front housing bolts.
Made my own from the scrap drawer in the tool box
Tabbed for good. ( I hope )
BRIAN
Old 11-23-2014, 07:21 PM   #134
brimc
brimc's Avatar
I dont seem to have any pictures after I did the KDP. I guess I was so excited to work on the truck I never even thought about the camera.
Today I hooked up a battery, put some fuel in a can and primed the fuel system. I have ran out of diesel before and I have heard and read on the internet that it can be a real bear to prime, but it went real smooth. This engine has gone smoke free for approx 32months. I pulled the engine exactly 2 years ago this month from the Dodge. Here is a short small low quality walk around video of the "second" start in the new Chevy!!
Hopefully this works for everyone.
BRIAN
Old 11-23-2014, 08:05 PM   #135
Mr. 250r
Mr. 250r's Avatar
I don't know why the big 3 manufacturers don't do this but on the stuff i build at work we use 3 motors only a qsb 6.7/4.5 cummins or a deutz but disregarding the deutz on the cummins we use a fuel filter that has a hand primer on it literally best invention i have seen i wish regular trucks had them because running out of fuel would be a thing of the past you unscrew the handle prime it till the handle is really hard to push in and they start right up. It has a regular quick disconnect line that goes to the pump not sure if its high pressure but the other line we use is regular rubber lines for the return.
If you want i can look for a part # on it i am sure its there somewhere.
Its somewhat similar to this picture
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 11-23-2014, 08:25 PM   #136
brimc
brimc's Avatar
That is very interesting. Looks like a neat setup.
My current plan is to use the stock setup. When I get the truck drivable I will then start the mods on the fuel system.
The 2nd Gen Cummins lift pump has a "primer bulb" built in. It works very good. I use it at filter changes and one time I ran out of fuel on the side of the road.
I used this about 30 to 40 pumps today. It filled all the line, fuel canister and the IP.
Old picture from tear down but the rubber boot thing on the side of the lift pump is the primer.
BRIAN
Old 11-23-2014, 08:27 PM   #137
brimc
brimc's Avatar
I'm still drooling too. Oh you have no idea.
BRIAN
Old 11-23-2014, 09:37 PM   #138
COS399
COS399's Avatar
Brian, Sorry to hear about your loss. Glad to see your making some good progress and that heater is going to come in handy. I have to drive about 16 miles, to use my friends heated shop. One day I will have my own heated shop.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 11-24-2014, 03:25 AM   #139
Dieselwrencher
So sorry to hear about your father! The engine sounds great. Nice rust repair, and I'm sure the heater will be used a lot there s winter, unfortunately.
Ryan
Old 11-27-2014, 06:49 PM   #140
brimc
brimc's Avatar
Thanks guys.
Ya the engine does sound good. I was starting to get worried because it has sat so long plus I had the injection pump off. Guess I got the pin timing right.
After I get the truck drivable I want to upgrade the fuel system with better lines, filters, free mods etc. For now, just to know it runs, is good enough for me. Thinking about getting rid of the saddle tank as well and go with the rear burban style. Seams to be the popular way to go. I have been keeping an eye out in the classifieds etc for a 88 to 91 suburban for a parts wagon.
BRIAN
Old 11-28-2014, 04:04 PM   #141
Dieselwrencher
You need to find someone near you with the timing kit and add some timing. That is a well worth mod on these. Around 15 is great for a DD/tow rig with minimal mods.
Ryan
Old 11-29-2014, 06:54 AM   #142
brimc
brimc's Avatar
I have done a fair bit of homework on this and yes timing will need to be done. I was looking at kits on-line when I was getting ready to install the pump but they are pricey. Not something that would be used very much but would make a very nice addition to the tool box collection for sure. I plan on doing all the adjustments and mods on the p7100 after I get it drivable. Then I can have a comparison for turning etc.
Your not that far from southern Ontario are you?
BRIAN
Old 11-30-2014, 11:16 AM   #143
Dieselwrencher
You can get them from Snap-on for $189. When I purchased mine I paid $489. Yes, I'm more than bitter about that.
Ryan
Old 11-30-2014, 11:32 AM   #144
6BT 56
6BT 56's Avatar
You and I are less than a hr apart . We can split on Ryan's travel costs and he can tweak my pump as well . lol. Truck is looking good . Like your new heater as well. Im just in the process of rigging up a waste oil heater . Go to YouTube some time and type in efficient waste oil heater. The guy in the vid looks like relic from beachcombers Heater is kick ass . He has done lots of homework to get it to this level
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 11-30-2014, 12:00 PM   #145
Dieselwrencher
That could be a fun trip. Speaking of heaters, I managed to get a fuel oil/diesel burning furnace I have to get installed in my shop.
Ryan
Old 11-30-2014, 02:09 PM   #146
brimc
brimc's Avatar
Ya I seen some on the internet and remembered thinking that was a lot of money. It would be cheaper than trying to get someone to do it at a diesel shop tho. 489 ya, that is a lot of money but I'm guessing you get to use it more than I would so eventually it would pay for itself.
If you had the p7100 pump we could just split the cost of the tool kit then figure out how to setup joint custody and which weekends etc
On the waste oil heaters, my buddy does alot of oil changes throughout the year and he stores the waste oil in a regular furnace oil tank and has it piped in to the heater. It puts out good heat. The fuel is free but he had high start up cost if I remember as he bought all new stuff. But if you could piece together some items from around the farm, shop, or kijiji you'd be laughing.
BRIAN
Old 11-30-2014, 03:43 PM   #147
Dieselwrencher
When you get to the point of adjusting your timing, let me know. We have two kits and I could probably send you one and let you borrow it.
Ryan
Old 11-30-2014, 09:33 PM   #148
72MARIO
72MARIO's Avatar
If you can take a week off and come up here I am only another hour and a bit north of Brian. I can hire you to mount a cummins in my longhorn chassis.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-01-2014, 04:39 PM   #149
Dieselwrencher
2wd or 4wd?
Ryan
Old 12-01-2014, 08:06 PM   #150
72MARIO
72MARIO's Avatar
Haven't decided yet. I would like to build 4wd but really don't want too big of a lift in it as its my daily work truck and I need access to the flat bed.
2005 TAHOE DD
