Old 12-15-2014, 06:42 PM   #126
Nate_
Re: DIY Disc Brake Conversion
Dave,
Thanks for all of the information. It will save me quite a bit of money sticking with the ball bearings.
Nate_ is offline   Reply With Quote
Old 12-16-2014, 05:00 PM   #127
Wingnut1
Wingnut1's Avatar
This may save allot of time or aggravation: I have a 1/2 ton, so I don't need this, but I'm aware many with 3/4 ton would like discs.
1947 - 59 3/4 & One Ton Chevy GMC Truck Disc Brake Conversion
Front Disc Brake Caliper Bracket Kit
http://www.thehollisterroadcompany.c...converion.html
Wingnut1 is offline   Reply With Quote
Old 03-25-2015, 09:32 PM   #128
Nate_
Anyone have updates for this mod?
I have a question for anyone that can answer: I am fitting my axle under my truck. I put the hub back onto the spindle and tightened the castle nut. I have tons on play in the hub and it will not sit on the spindle properly. What could be making it sloppy? Could the back plate have been holding it on more snug?
Nate
Old 03-26-2015, 12:11 AM   #129
dwcsr
Hollister Road Co.
dwcsr's Avatar
Nate
you forgot either the inner or outer spindle race. The bearings are 3 piece, an inner race the bearing and the race that's pressed into the hub. .
What updates do you want on the MOD
dwcsr is offline   Reply With Quote
Old 03-26-2015, 09:11 AM   #130
Nate_
OK thanks! I was wondering if Nick or anyone else had actually finished this modification and had pictures.
Old 03-26-2015, 12:37 PM   #131
dwcsr
Hollister Road Co.
dwcsr's Avatar
If your asking about the one I make its working on several trucks that I know of and several more have purchased the kit.
Old 01-19-2016, 06:14 PM   #132
dwcsr
Hollister Road Co.
dwcsr's Avatar
I know this is an old thread but we now have a rear kit in the works soon to be available for 47-59 HO52 HO72 that has slide on drums. We have the test parts in, we will have to tweak them for the final version but it did allow us to do proof of concept. It will work on HO52 HO72 with slide on drums. It allows you to unbolt a rear brake assembly from a 2003 up to about 2010 2500HD and bolt it onto your stock rear end. It keeps the 2003 disc brake, parking brake and rotor without changing rear wheel track. You use your stock hub.
Here are a few pictures.
Rear disc swap
Rear Disc swap
It will be about 3- 4 weeks before its ready. But it is on the top of the work list for us. We do have a front kit and booster kit available now at www.hollisterroad.com
Old 06-22-2016, 07:47 PM   #133
Sgtfluffy16
so from what i have read so far there are NO bolt on items i can purchase to do a front disc brake conversion on my 51 3100 6 lug? I see alot of customization (don't have tools to fab up items) but i am looking for something bolt on. Can anyone point me in the right direction? I would like to do a new brake master cylinder as well and i'm sure a proportional brake valve
Sgtfluffy16 is offline   Reply With Quote
Old 06-22-2016, 09:07 PM   #134
dwcsr
Hollister Road Co.
dwcsr's Avatar
literally dozens of companies make them. google, 1950 chevy 3100 disc brake conversion
Old 06-22-2016, 09:37 PM   #135
Sgtfluffy16
Yes i know CCP. PoL. And others. My buddy has a 51 Ford and literally he bought brackets from a gentleman online which came with a full list of parts of what calipers to buy, what rotors to buy, what brake hoses to buy, what master cylinder to buy, with part numbers. It made it simple and very inexpensive. But I have not come up with anything for this.
Old 06-23-2016, 12:18 AM   #136
mechanixman
mechanixman's Avatar
https://www.tuckersparts.com/Disc-Br...-FDB-4706.html
http://www.bobschevytrucks.com/compl...954-truck.html
http://www.dreamershotrods.com/Front...GMCPickup.aspx
https://www.brotherstrucks.com/47-59...tinfo/NOFX559/
There ya go. There are plenty of 6 lug kits out there, as stated earlier in my thread, this conversation is for making an 8 lug conversion which now seems to have a vendor that makes a kit. I attached a photo of what I searched.....
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 06-23-2016, 11:32 AM   #137
1-ton of fun
polishing a turd
1-ton of fun's Avatar
https://scarebird.com/index.php?rout...product_id=185
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 02-28-2017, 02:34 PM   #138
mechanixman
Hey Mikec4193!
Did those brackets fit?
Thanks a bunch,
-Nick
Projects:
