Old 02-12-2015, 09:00 PM   #126
Hankster
Hankster's Avatar
Re: 1991 V3500 Project Heavy Hauler
OMG sweet h1 man!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-13-2015, 12:40 AM   #127
MTCK
MTCK's Avatar
Very cool rig! I've always lusted after an H1 alpha...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-15-2015, 10:09 PM   #128
MTCK
MTCK's Avatar
Got a little done on the truck today. Straightened the rear bumper with a come along, replaced the back up lights with some LEDs I had sitting around, replaced the headlight switch and played around with my rammount/lifeproof iPad mount. I like it. Bluetooth connects to the stereo for tunes, gps runs map or nah software and I can control my gopro with it. I'll need to play around a bit with it this summer.
-Marcus
Project Plow Truck
Old 02-16-2015, 08:59 PM   #129
Hankster
Hankster's Avatar
Sweet! Id like to set up a go pro..
Current Build
Old 02-17-2015, 07:33 PM   #130
kevinr1970
Originally Posted by MTCK View Post
Motor has developed a pretty noticeable knock and I used about a quart of oil over the ~400 miles. Everything else worked flawlessly. Had to use 4wd just about every time to get out of my driveway, but was good after that. I get a loud rubbing noise under hard acceleration in 1st gear. I think it might be the fan hitting the shroud, and may try placing my gopro under the hood and seeing if I can make it happen. I would not be surprised if the motor mounts are shot - the t-case shifter sure moves a lot.
Did you ever get this figured out?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-17-2015, 08:56 PM   #131
MTCK
MTCK's Avatar
I have not trouble shot it at all. No symptoms unless I'm pulling a heavy trailer or under heavy load, and the truck has been pretty much parked since late fall. It's supposed to remain warm through the weekend so I might mess with it some then.
-Marcus
Project Plow Truck
Old 02-21-2015, 02:00 AM   #132
MTCK
MTCK's Avatar
Picking out interior materials...
-Marcus
Project Plow Truck
Old 02-21-2015, 07:27 PM   #133
Hankster
Hankster's Avatar
Awesome! Can't wait to see it!
Current Build
Old 02-22-2015, 06:08 PM   #134
MTCK
MTCK's Avatar
You and me both...
Put my AK Children's Trust plates on this truck and when I was bolting up the front I happened to be looking through the grille at a funny angle. Looks like someone took a machete to the wad of wires that service the right side lights. Lots of bare wires including my low beams etc and some good melted action. Cut everything back to good, crimped in new. Wrapped it all with electrical tape since I used all my loom on hand when I did the trailer brake controller. More on the way soon when I make my Waytek order. Now my one headlight doesn't come on with the parking lights and my side maker works. They had two wires switched.
Got a bunch of freezing rain last night so chained up the front axle to head to work for a bit. Crazy it's +35F here and east coast is getting hammered with below freezing temps. Made wiring outside for an hour yesterday no big deal.
-Marcus
Project Plow Truck
Old 02-23-2015, 12:08 PM   #135
hartbraker
Replying to your comment about a low rubbing noise in tow with heavy load. The truck in my signature did the same thing. Only under heavy acceleration.
I narrowed the issue down to the flywheel rubbing on the bellhousing cover.
For the life of me, I couldn't figure out what the problem was, until recently. I had the turbo 400 rebuilt, and the issue was resolved. I believe there was too much end play in the input shaft causing the flywhell to be able to walk just enough to come in contact with the cover.
Since having the transmission rebuilt, towing a 20,000 # trailer, I have had no issues.
Hope that helps.
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 02-23-2015, 12:33 PM   #136
MTCK
MTCK's Avatar
Thanks for the info, that's a great idea of something to check. Pretty cool truck in your signature, got any pictures?
-Marcus
Project Plow Truck
Old 03-15-2015, 05:44 PM   #137
gmcrew
gmcrew's Avatar
Nice truck! This is a little off topic, but do you happen to know what your RPM's are when you're running down the highway, un-laden and on the flat, say at 60 mph? I'm having issues with my 4l80e.
gmcrew is offline   Reply With Quote
Old 03-16-2015, 01:12 AM   #138
MTCK
MTCK's Avatar
Thanks! Right now it goes 0 rpm as a rod bearing is imminently failing... My tranny shifts great though. I can feel the three distinct shifts into OD and the torque converter lock. By the calculator, my 32", 4.56 gears, .75 OD ratio at 60 MPH would be 2155 RPM. I don't have a tach.
-Marcus
Project Plow Truck
Old 03-23-2015, 01:19 AM   #139
MTCK
MTCK's Avatar
As I alluded to, my motor is toast. Made it to the shop so I can throw something else at it, barely. No L18 in the immediate budget so rolling the dice with a junkyard 350 that runs "great." Exciting. Picked it up this weekend.
While I was waiting for the salvage yard to pull the motor a buddy brought over his high speed buffer. Paid needed even more help so I picked up some 1500 grit and wet sanded the one side. Quite a difference.
I used a 3M decal remover that goes on a drill to take the graphics off. Way better than a heat gun and razor blade.
-Marcus
Project Plow Truck
Old 03-23-2015, 01:25 AM   #140
MTCK
MTCK's Avatar
After getting the intake and exhaust manifolds and valve covers off, this is a high mileage motor. All the valves are good and wet in the exhaust runners. I'm sure it will smoke like a champ. I have a gasket set to go in it so I'll do most of what I can get to with the heads on. Better start gathering up parts for that big block swap...
-Marcus
Project Plow Truck
Old 03-25-2015, 09:38 PM   #141
Hankster
Hankster's Avatar
At least you found another motor pretty quickly, I kinda liked them graphics though.. The paint def cleaned up good though!
Current Build
Old 03-26-2015, 10:44 AM   #142
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Too bad you don’t live closer Marcus as I could have hooked you up with the 5.7L out of my Suburban to hold you over. I’m with Hankster…. I liked those graphics on your truck. I’m usually not into that kind of stuff but they looked good.
Also, a while back we talked about paint for the center console. We’ll after several attempts I gave up on getting paint to stick to the console in the K10 and have a console over at an upholstery guy getting covered in the same vinyl that is on the seats. I’ll post pics when I get it back. How is your console paint holding up?
DirtyLarry is offline   Reply With Quote
Old 03-27-2015, 03:03 AM   #143
MTCK
MTCK's Avatar
Thanks guys. I'm bummed the 350 died so close to its retirement date. I ended up not painting the charcoal. I think it and the dash will work well with the other interior materials.
I'm going to withhold praise until I have the materials installed but so far I've had a great customer service experience with an upholstery outfit. Local place wanted $2700 to redo the seats and headliner. Hard to justify on a $3500 truck.
Decals had to go. I'm going to reserve judgement on the paint until I see it outside but it sure feels smooth. Lots of work with the 3m decal removal tool, 1500 grit and ultimate compound.
-Marcus
Project Plow Truck
Old 03-27-2015, 06:53 PM   #144
JGood
JGood's Avatar
I second that motion those 3m wheels are awesome and quick!! Been working on my wrangler stripe the past couple nights. Takes no time at all I was impressed with how they work.
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 07-11-2015, 04:14 PM   #145
MTCK
MTCK's Avatar
Only thing I noticed about the 3m wheels is once they get hot they start to lose chunks so they need a cool down period occasionally.
Finished putting the motor together, installed it, serviced the transmission, put in a new heater core, started replacing the window and door seals and replaced the rear springs. Feels like a never ending list but it is starting to come together.
While the truck was in motor swap jail I cleaned all the trim, prepped and painted it with the SEM classic coat. Turned out pretty good. I'm getting excited to see the interior together. Hopefully that gets finished in the next couple weeks.
-Marcus
Project Plow Truck
Old 07-11-2015, 04:17 PM   #146
MTCK
MTCK's Avatar
Pics
-Marcus
Project Plow Truck
Old 07-11-2015, 04:21 PM   #147
MTCK
MTCK's Avatar
When I had the pan off the transmission I installed a temp sensor for the gauge that will go in my pod and put a new heating pad on it. 8 quarts of dexron VI later...
Reworked a bunch of the wiring harness. Most of the loom was cracked or missing so that was fun.
-Marcus
Project Plow Truck
Old 07-11-2015, 04:26 PM   #148
MTCK
MTCK's Avatar
New motor mounts that I had sitting around went in. For those doing this install, leave the mounts bolted loosely to the cross member and keep a BFH close when you lower the engine in, then tighten the clam shells to the cross member once bolted to the motor.
Rear springs have the stance right. I did not reinstall the overloads as eventually I hope to be doing a shackle flip which will make them useless. These seem plenty stiff but we will see once a load is on. Part # 22-617.
-Marcus
Project Plow Truck
Old 07-21-2015, 03:08 PM   #149
LuckyLightning
LuckyLightning's Avatar
Great thread here; love seeing how great that truck is turning out. Mind if I ask what brand tires those are? I've been eye-balling 255/85/16 for a little while now, so I really like seeing that size work on your truck. Have you been happy with them?
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
Old 07-21-2015, 04:49 PM   #150
y5mgisi
Second Chance Program
y5mgisi's Avatar
Love the way you go about stuff.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
