Old 11-19-2015, 04:48 PM   #126
burnitg
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
I have made some progress on the old GMC.
I made a bracket to attach the throttle, cruise control and engine stop cables to the top of the governor.
Here's a photo of the bracket:
Name:  Throttle Bracket - side view.jpg
Here's a couple of photos with the cables attached:
Name:  Throttle Bracket with cables - front view.jpg
Name:  Throttle Bracket with cables - side view.jpg
I'm thinking I will use a couple of spark plug wire supports to organize the cables and route them over the top of the rocker cover.
I need to order a torsion spring for the throttle return spring since there is very little room between the back of the governor and the firewall.
I picked up some aluminum sheet in town the other day. Time to start working on the fan shroud...
Have a safe and happy Thanksgiving.
burnitg is offline   Reply With Quote
Old 11-19-2015, 06:23 PM   #127
nsulacountry
Slick job on the cable bracket.
CT
nsulacountry is offline   Reply With Quote
Old 11-19-2015, 08:30 PM   #128
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work on the throttle bracket, and you have a Happy Thanksgiving as well!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-16-2015, 08:00 PM   #129
burnitg
I purchased a sheet of aluminum and got to work on a fan shroud. The OEM shroud was not even close and, at the time, it seemed like it would be easier to fabricate a new one. Well, about 20 hours of work later, here's the completed shroud on the workbench:
Name:  Fan Shroud on the bench.jpg
Here it is installed in the truck:
Name:  Fan Shroud installed.jpg
I like the look of it. I haven't decided if I will polish it or paint it.
I have been thinking about the upper radiator hose. The original elbow on the thermostat housing turned up. The outlet was about 1" higher than the inlet to the radiator. I mocked it up using some hose and tubing that I had on hand:
Name:  Upper Radiator Hose - first idea.jpg
This is clearly not good! I would have had a big vapor trap that I would have needed to vent somehow.
Thanks to Grigg over at 4btswaps, I found a OEM Detroit Diesel elbow that points toward the passenger side. I can easily make this work without causing a vapor trap. Here's a photo of the elbow.
Name:  New Upper Coolant Elbow.jpg
I have had no luck finding a pre-molded hose for the upper or lower radiator connections so I will make something out of tubing. At least now, I won't have the vapor trap.
Old 12-17-2015, 06:05 PM   #130
Dieselwrencher
Nice work and that worked out nicely to find an OE piece that would work.
Ryan
Old 12-18-2015, 08:37 AM   #131
ryanroo
ryanroo's Avatar
Nice! i dig the shroud. that is in my enormous pile of to do's as well
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-14-2016, 06:45 PM   #132
burnitg
Happy New Year! It has been a good one for me so far. We had a great time with family and friends over the holidays. The Alabama Crimson Tide won the college football national championship. Roll Tide! The Broncos are in the playoffs. Life is good!
I've made some progress on the GMC. I mocked up the upper radiator hose. It looks a lot better with the new water neck.
Name:  Upper Radiator Hose mock-up.jpg
I am planning to fabricate the top pipe, including the elbow and reducer, from aluminum. I purchased the tubing and fittings for the radiator hoses and intercooler from Columbia River Mandrel Bending.
Name:  Aluminum water and intercooler tubing.jpg
I ordered the intercooler. Unfortunately, it looks like someone dropped it before it arrived. The UPS man came and picked it up for return.
Name:  Intercooler Damage.jpg
The replacement arrived and I fabricated brackets to support it and the condenser. Here's the top view:
Name:  Intercooler Installation - top view.jpg
Here's the driver's side view.
Name:  Intercooler Installation - driver's side view.jpg
This is only the first pass, I know that the top of the condenser interferes with the hood latch so the brackets will have to be modified or I will have to purchase a shorter condenser. Two steps forward, one step back...
Old 01-14-2016, 10:34 PM   #133
Dieselwrencher
It's always something! Great work. That upper hose looks really nice with the new housing.
Ryan
Old 01-17-2016, 02:03 PM   #134
1972RedNeck
1972RedNeck's Avatar
Subscribed
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-20-2016, 07:33 PM   #135
burnitg
The intercooler is in! I have modified the brackets to bring the intercooler closer to the radiator and to move the condenser down a couple of inches. After the modifications, the hood latch clears the condenser.
First, I had to make some cutouts in the core support. I was going to have to do this anyway to make a pass through for the tubing from the turbo and to the blower. Since I needed to move the intercooler back, the nozzles interfered with the core support.
Name:  Core Support Cutouts.jpg
I had to cut some of the structure of the core support out. I will reinforce it later.
Here are the completed brackets on the table:
Name:  Completed Brackets on the table.jpg
Here is a front view of the intercooler installed:
Name:  Intercooler Front View.jpg
Here is a rear view:
Name:  Intercooler Rear View.jpg
Here's a view of the intercooler, condenser and hood latch:
Name:  Intercooler & Condenser Front View.jpg
The elbows for my intercooler tubing are on back order, so I will be working on the brace for the hood latch and reinforcing the core support next.
Old 01-29-2016, 08:07 PM   #136
burnitg
I finished the brace for the hood latch. I had to cut so much out of it to fit the intercooler, that I decided to box it. Here are the pieces on the workbench:
Name:  Hood Latch Brace pieces.jpg
Here they are welded up:
Name:  Hood Latch Brace boxed on the bench.jpg
Here it is installed (I had to fit the fenders and grille to make sure that everything still fit):
Name:  Hood Latch Brace installed.jpg
I made an upper radiator pipe of aluminum. Here it is on the bench:
Name:  Upper Radiator Pipe on the bench.jpg
Here it is installed (temporarily):
Name:  Upper Radiator Pipe installed.jpg
Next is the lower radiator pipe. It is larger, shorter and has some odd angles. Should be fun...
Old 02-01-2016, 10:56 AM   #137
nsulacountry
Fabricated aluminum water piping!! This build is getting real!
CT
Old 02-16-2016, 08:27 PM   #138
burnitg
The intercooler piping saga begins...
I didn't have the parts that I needed to complete the bottom radiator piping, so I decided to start the intercooler piping.
One major problem, the blower inlet points up. Here it is in the center of this photo (with the Gorilla tape around the inlet). I need it to point forward to meet the piping from the intercooler.
Name:  4-53T Driver's Side View.jpg
Here it is in the vise awaiting major surgery:
Name:  Blower Inlet Housing in the Vise.jpg
There's no turning back now!
Name:  Blower Inlet Housing after cuts.jpg
Welding cast aluminum - no problem - right? Well it was for me. This casting was full of inclusions. It was the devil to weld.
Name:  Blower Inlet Housing welded.jpg
I made a test apparatus to test the welds. Here it is in the apparatus for the first time. I obviously didn't have the clamps tight enough since there are bubbles around the gasket.
Name:  Blower Inlet Housing test apparatus.jpg
By the time I got the two pinholes welded up, I had lots of practice in putting the housing in the test fixture. The pinholes were caused by two nasty inclusions. I would weld, test, grind, weld, test, grind, etc., etc., etc. I am not proud of the looks of the weld only that it doesn't leak.
Between the fitting, welding, testing and re-flattening the sealing surface, I must have 30 hours in this part. Good thing I'm retired - I would starve to death trying to make a living this way!
Old 02-17-2016, 10:42 AM   #139
nsulacountry
I'm impressed! I would have tried to hose the IC in somehow.
Welding porous cast aluminum, you're my hero!
CT
Old 02-18-2016, 08:03 PM   #140
burnitg
The radio is back! I had it serviced and the speaker re-coned by Crockett Sound Labs. It looks great, it will be a while before I know how it sounds.
Word of advice, if you are planning to have an old radio restored, plan ahead. The radio guys are really busy! I sent this radio to them 8 months ago.
Name:  Radio returned from Crockett Sound Labs.jpg
I had considered just installing the radio without having it serviced; but, decided against it when I saw how much of the interior I would have to remove if it didn't work. It's a good thing I sent it in, the output transistor was blown (common with these radios) and I would have been pulling it out again.
I got the blower inlet housing cleaned up and back on the engine:
Name:  Blower Inlet mounted.jpg
Now that both of the endpoints are set, I started working on the tubing for the intercooler. Here is the turbo to intercooler portion tacked and mocked into place:
Name:  Turbo to Intercooler pipe mocked-up.jpg
Old 02-22-2016, 11:45 AM   #141
nsulacountry
Looking good! Before long you will be dripping oil all over town! LOL.
CT
Old 02-22-2016, 10:04 PM   #142
Dieselwrencher
Nice work! It's coming a long nicely. I almost went the route you went on the factory am/fm but never found one reasonably priced I could talk myself into buying. Do they offer an option to add an input jack to these old radios by chance/
Ryan
Old 02-23-2016, 02:16 AM   #143
burnitg
Thanks for the compliment. After paying for the service and replacing the output transistor, mine is not reasonably priced either. Oh well, in for a penny, in for a pound...
They do offer to add a line in input to our old radios. I considered having one added; but, decided that it was not worth the additional expense. After all, I may not even be able to hear the radio over the music of the engine. I once put a nice stereo in a '91 Dodge Cummins. It sounded great until I started the engine...
Old 02-23-2016, 08:34 AM   #144
ryanroo
ryanroo's Avatar
Nice progress! the piping looks great.
72 K20 12v build
Old 02-26-2016, 02:10 PM   #145
j_cst_10
j_cst_10's Avatar
Subscribed. Looks awesome.
j_cst_10 is offline   Reply With Quote
Old 03-14-2016, 08:19 PM   #146
burnitg
Intercooler piping - done!
I had to cut a couple of big holes in the core support to pass the piping from the turbo to intercooler and intercooler to blower. Here's a close-up look at the passenger side opening:
Name:  Hole in Passenger side of Core Support.jpg
I reinforced the openings on both sides. I believe the core support is now as strong as it once was:
Name:  Reinforcement of hole in Passenger Side of Core Support.jpg
Here's a front view of the intercooler installed:
Here's the turbo to intercooler piping welded and pressure tested:
Name:  Intercooler piping - Passenger side.jpg
Here's the intercooler to blower piping welded and pressure tested:
Name:  Intercooler piping - Drivers side.jpg
I need a longer coupling between the intercooler piping and the blower. I'll take care of that in my next Summit Racing order.
Old 03-15-2016, 07:36 PM   #147
ryanroo
ryanroo's Avatar
Lookin good, as always!
72 K20 12v build
Old 03-17-2016, 07:50 PM   #148
Dieselwrencher
Great work!
Ryan
Old 03-31-2016, 07:06 PM   #149
burnitg
I found some time to work on the old GMC today. I finally finished the lower radiator pipe.
Name:  Lower Coolant Pipe on the bench.jpg
Here it is installed:
Name:  Lower Coolant Pipe installed.jpg
The cooling system is now complete.
I purchased a hydro boost master cylinder since the vacuum pumps available for the Detroit Diesel look terrible. Next, I'll start on the plumbing for the power steering and brakes.
Old 04-28-2016, 09:45 AM   #150
ryanroo
ryanroo's Avatar
How goes the struggle? The piping continues to please the eye
72 K20 12v build
