Old 11-20-2014, 11:57 AM   #126
FirstOwner69
FirstOwner69's Avatar
Re: Urgent, need opinions on my new crate engine
Same as an original small block. Behind the intake manifold there is a vertical hole in the top edge of the block.
Dead center in this picture.
FirstOwner69 is offline   Reply With Quote
Old 11-20-2014, 12:00 PM   #127
1972BlueC20
1972BlueC20's Avatar
Originally Posted by FirstOwner69 View Post
Same as an original small block. Behind the distributor there is a vertical hole in the top edge of the block.
Ok that's what I thought!
Thanks!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 11-20-2014, 12:02 PM   #128
FirstOwner69
Thanks!
Added pic. Above.
Old 11-20-2014, 12:34 PM   #129
1972BlueC20
Added pic. Above.
ok cool, so same spot....thanks for the picture!!
Old 11-20-2014, 02:19 PM   #130
mechanicalman
Originally Posted by CUSTOM/10 View Post
No, I believe it's 1/2" and I am using it for my electric fan control .
OK. You could tee into your bypass hose going from your intake to your water pump, and it would bypass well under all conditions, but I doubt it would circulate your heater water very well.
I'd recommend to run your 3/4" heater return hose into a reducer if necessary and into the lower radiator hose using a Tee, shown below. Measure what size you need and order one. KAT's has a variety of them, they are made for block heaters but you can buy separately for about 10 bucks.
http://www.oreillyauto.com/site/c/se...0650/C0076.oap
http://www.oreillyauto.com/site/c/de...0886&ppt=C0108
mechanicalman is offline   Reply With Quote
Old 11-24-2014, 09:16 PM   #131
1972BlueC20
I'm getting excited guys!! Went to see my new engine. Should have my truck back by Friday!!
Also, FYI the latest configuration of the 330 hp / 380 tq, 350 GMPP crate engine part # 19210008 does come fully assembled. Only thing needed is fuel pump, starter and water pump. Summit Racing told me the intake would not be installed. They told me wrong info on my last engine too, I don't think they know what the heck is going on sometimes lol
