Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-22-2015, 08:32 PM   #126
jdl71
jdl71's Avatar
Re: Parting this 66
There are actually different upper brackets. They mount the same, but the "V-8" one is wider to accommodate a wider upper tank. The simplest way would probably be to just measure the inside opening of the bracket and see if it will fit over the tank you are trying to work with. There are also different lower mounts, in a different location farther forward the the larger radiator.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-22-2015, 10:06 PM   #127
zeusflash
zeusflash's Avatar
Re: Parting this 66
PM sent
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 10-23-2015, 01:26 AM   #128
azlamm65GMC
Re: Parting this 66
Been desperately looking for original oil filter housing/canister for 305 V-6 if have one. Any suggestions? All threads on here about adapters seem worthless
azlamm65GMC is offline   Reply With Quote
Old 10-26-2015, 03:33 AM   #129
Nils
Nils's Avatar
Re: Parting this 66
Originally Posted by PGSigns View Post
Picked this up last week to get some things we needed for a couple of projects. Bed was about the only usable body part. I has a new home. Going to post pics as I pull stuff off. If there is something you want let me know and I will look to see if it is there.
Jimmy
Hi,
I need a Mount for my wiper Motor like this. Do you have some one like this ???
Thank you verry much.
Greetings
Nils
Nils is offline   Reply With Quote
Old 10-26-2015, 06:36 AM   #130
PGSigns
PGSigns's Avatar
Re: Parting this 66
I have a 66 and that piece is still in it. I'll check it tonight when I get home from work and make sure its good. How much fire wall around it do you need?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-26-2015, 09:12 AM   #131
Nils
Nils's Avatar
Re: Parting this 66
Jimmy
Hi Jimmy.
thats great. I think i need a piece of 11" inch (ca.28cm) long and 8" high.
Thank you verry verry much.
Greetings Nils
Old 10-26-2015, 10:36 AM   #132
PGSigns
PGSigns's Avatar
Re: Parting this 66
That should not be an issue.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-26-2015, 02:19 PM   #133
Nils
Nils's Avatar
Re: Parting this 66
Jimmy
Nils
Old 10-29-2015, 01:33 AM   #134
Nils
Nils's Avatar
Re: Parting this 66
Hi Jimmy,
Is the Motor Mount ok ? Do you have a picture ?
Greetings
Nils
Old 10-29-2015, 07:15 AM   #135
PGSigns
PGSigns's Avatar
Re: Parting this 66
Mount is OK just been raining the last two days and I have not been able to get it cut out. Rain should be done this morning and will cut it out after work. Will take a pic of it when out so you can see it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-29-2015, 01:41 PM   #136
Nils
Nils's Avatar
Re: Parting this 66
Jimmy
Hi Jimmy,
Ok thank you verry much.
Nils
Old 10-29-2015, 06:28 PM   #137
PGSigns
PGSigns's Avatar
Re: Parting this 66
Got it cut out. Here are a couple of pictures. $20 and what ever it takes to get it to you.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-30-2015, 01:49 AM   #138
Nils
Nils's Avatar
Re: Parting this 66
Jimmy
Hi Jimmy,
the Mount looks great. 20$ is ok. Is PayPal ok for paying ?
Could you say me how much is Shipping costs to Germany ?
Nils
Old 10-30-2015, 06:55 AM   #139
PGSigns
PGSigns's Avatar
Re: Parting this 66
Nils I sent you a PM to get your shipping information. Think about if you need anything else to go in the the box.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-30-2015, 01:07 PM   #140
drewbert41
drewbert41's Avatar
Re: Parting this 66
Jimmy
Do you have pictures of the accelerator pedal?
drewbert41 is offline   Reply With Quote
Old 11-02-2015, 09:18 PM   #141
65sub
65sub's Avatar
Re: Parting this 66
Jimmy I need a section of the windshield frame. Drivers side bottom corner outlined in tape in the picture. About 6" high and 8" wide. Thanks for the help.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 11-03-2015, 09:39 AM   #142
PGSigns
PGSigns's Avatar
Re: Parting this 66
Ill look to see if it is any good.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-03-2015, 11:19 AM   #143
65sub
65sub's Avatar
Re: Parting this 66
Thanks Jimmy
Dale
Old 11-03-2015, 02:41 PM   #144
PGSigns
PGSigns's Avatar
Re: Parting this 66
Not sure what I have is much better than yours. Drip rail is rusted off of it and looks pretty pitted in about the same spot as yours.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-04-2015, 01:12 PM   #145
65sub
65sub's Avatar
Re: Parting this 66
Thanks for checking Jimmy I guess I'll keep looking
Dale
Dale
Old 11-07-2015, 07:58 PM   #146
Oldgmc1963
Re: Parting this 66
Hi and thank you in advance for fielding this. I am looking for what I believe is called a Parking brake cable clamp. It's bolted (two bolts) to the rear brake back plate were the parking brake cable goes into the back plate.
Oldgmc1963 is offline   Reply With Quote
Old 11-08-2015, 11:37 AM   #147
PGSigns
PGSigns's Avatar
Re: Parting this 66
I would have to look. LMC does sell them. Call it a seal.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-08-2015, 02:40 PM   #148
Oldgmc1963
Re: Parting this 66
thanks. Let me know. I have a 4x4 3/4 ton so don't see it in LMC or many others.
Old 11-08-2015, 08:19 PM   #149
PGSigns
PGSigns's Avatar
Re: Parting this 66
Well that changes things. What rear do you have? I thought you were looking for C-10 stuff.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-15-2015, 08:41 PM   #150
PGSigns
PGSigns's Avatar
Re: Parting this 66
Les here is the pulley.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
