Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-17-2016, 01:18 AM   #126
First c10
First c10's Avatar
Re: Project "Hulk Jr"
EXHAUST IS DONE!!!
I got 2 -45 degree elbows and got them installed. The tail pipes are heading up hill but I did not like the look of the pipes level. They looked to low.
Parts list.
Heartthrob pipe kit $149.00
Summit(flow master clones) $50 ($25 each)
4 summit exhaust clamps 7$ each
2-45 degree fittings $13.
For 250$ not bad. I will try and post video of the first start up if I can.
I also got the AC delco plugs gapped at .045 and installed with the wires.
I am hoping to get the front clip on tomorrow. Maybe even running by the weekend.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-17-2016, 01:23 AM   #127
First c10
First c10's Avatar
I had to move the rear brake line tee to the top of the diff. It was right where the passenger exhaust needed to go. Can tell it was a single pipe out the back from stock. This kit even has room for the spare tire underneath.
GO GO!!!
Old 05-17-2016, 07:56 AM   #128
lowrodderchev
lowrodderchev's Avatar
Exhaust looks killer man good job
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 05-17-2016, 09:56 AM   #129
First c10
First c10's Avatar
Thanks. I am hoping to have it running by the weekend.
GO GO!!!
Old 05-17-2016, 11:50 PM   #130
swamp rat
swamp rat's Avatar
Cool! for $250 ya can't beat that!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-18-2016, 12:06 AM   #131
First c10
First c10's Avatar
Got the front clip hung but need to completely shim the cab since I have replaced all the bushings. The cab needs to be lifted about 1/4" in the front. I will try and get shims made tomorrow in aluminum. After I get them installed I am sure I will be adjusting the doors.
The PO had just cut what looks like pieces of a tire between 2 big washers for the front body mounts.
GO GO!!!
Old 05-18-2016, 12:08 AM   #132
First c10
First c10's Avatar
Motor fits great even after I moved the motor forward 2".
GO GO!!!
Old 05-18-2016, 12:13 AM   #133
First c10
First c10's Avatar
Looks like I have the perfect amount of room between the fan and the radiator support.
GO GO!!!
Old 05-18-2016, 12:18 AM   #134
First c10
First c10's Avatar
Front looks mean. The little bit of height added to the truck makes a lot of difference.
The width of the front also.
GO GO!!!
Old 05-22-2016, 12:37 AM   #135
swamp rat
swamp rat's Avatar
Truck looks great!
On the shims if you go to Home Depot/Lowes ect where the concrete pier block hardware is, they have hardened steel galvanized square washers that are used for the screw adjusters that are about 1/4" thick, similar to the link here but thicker, the hole is large enough to allow body bolts and possibly the mounts center spacers too..
http://www.homedepot.com/p/Simpson-S...PHDG/100506799
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-22-2016, 12:46 AM   #136
swamp rat
swamp rat's Avatar
Here they are..
http://www.homedepot.com/p/Simpson-S...2HDG/100375300
http://www.homedepot.com/p/Simpson-S...2HDG/202092501
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-22-2016, 01:35 AM   #137
First c10
First c10's Avatar
Mike that would have worked great and save me time. But I cut aluminum and made basically what you shared in the links. Thank you
I have been working to get this thing done. Consuming all my extra time. All I have to do is finish the transmission lines to the radiator and should be ready to hit the switch and see what happens.
GO GO!!!
Old 05-25-2016, 12:01 PM   #138
First c10
First c10's Avatar
OK so I got the the dizzy clocked and got the truck started. I took a video but not sure how to attached or load it. You tube is best I think.... when I get time I will try and post.
this truck has so many little crazy things go wrong or give me fits I am tired of this truck!!! I love working on them but man every time I turn around somethings a miss with this thing not that it cant be fixed but just takes an extra hour..... I even had a the key switch stop working, turn it all day and some times the accessory would work sometimes not, sometimes start and sometimes not. Before the build it didn't have a problem... so I had an extra one from my sons truck that I replaced with the new harness... changed it out and now it is working great.
not a very good picture but look how close the fan is to the upper radiator hose. I am thinking about making a hard line like the original 4x4 trucks had. if not I need to install a brace or make a fan shroud.
After the picture was taken I loosened the clamp at the radiator and rotated the hose away from the fan. That worked pretty good but still needs something!
GO GO!!!
Old 05-25-2016, 12:15 PM   #139
lowrodderchev
I feel your pain man but it will all be worth it at the end. at least that what everyone keeps telling me LOL
Old 05-25-2016, 12:29 PM   #140
First c10
First c10's Avatar
Thanks.... they are telling me that too!!!
GO GO!!!
Old 05-25-2016, 05:02 PM   #141
junksaver
Don't drive it like that. That fan will eat that hose for lunch. Trust me I've made that mistake. I would highly recommended a fan shroud.
By the way good job on everything. I've been watching your build.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 05-25-2016, 05:20 PM   #142
First c10
First c10's Avatar
Thank you JS...
I rotated the radiator hose so its not that close anymore... I will be putting and fan spacer to move the fan closer to the radiator. This will give me a lot of room between the fan and hose, and help with cooling also as I have 3+" from the fan to the radiator. The plan is to find a shroud or make one.
GO GO!!!
Old 05-27-2016, 10:55 AM   #143
First c10
First c10's Avatar
The saga continues with this damn truck....starting to get pissed off!!!!
Every time I turn around something funky goes wrong.
The truck was running GREAT every thing checked and double checked, so I thought I would see if I could put the truck in gear. When I did I heard a little bit of noise like a whine, but it went in forward and reverse gears fine.
I checked the fluids and it was about 1/2 qt low so I topped it off. Tried it again and still a whine. So I called the trans shop and talked to the guy that rebuilt it and he told me to check the TC to Flex plate gap that sometimes mix matching old and new motors, transmissions and TC you have to shim. Well I noticed a little gap when I originally matted the trans to the engine but research it and a little bit of gap is ok. So I just bolted it up. Now I thought well I would just disconnect the TC from the flex plate and when I did I noticed that the TC was hard to spin for about 1/4 turn and then the TC moved towards the transmission and spun freely like it should. Now there is about .2" of gap. so I got 1/4" longer bolts and .2" spacer and installed them.... I felt like that was a positive move and that it would be the reason for the whine...
Now time to start the motor to see if the noise was there when I put in gear.
Hit the starter and the motor fires up and making a loud taping sound in the back of the motor... I was like what the hell??? so I checked for oil pressure (it was good) and shut the truck off... Thinking it was something hitting around the TC area. I looked and couldn't see anything or could think of anything I could have done to cause that noise. I unbolted the flex plate from the TC and started it up.... Noise still there... The day before it ran great. So in my mind I am thinking the worst....now I am thinking rocker stud pulled or something major in the valve train, but the sound is in the back of the motor not on 1 side or the other. I have a mechanic friend I work with coming to look at it this weekend.
I will keep you guys updated...
If you guys have any ideas please let me know?
GO GO!!!
Old 05-27-2016, 11:22 AM   #144
lowrodderchev
man I'm sorry that's happening to you good luck this weekend hopefully its something small
Old 05-27-2016, 11:32 AM   #145
First c10
First c10's Avatar
Thanks man! What I know now???... I would have went LS! hands down!!!
GO GO!!!
Old 05-27-2016, 11:39 AM   #146
lowrodderchev
NO way. I wish I kept the small block in my k5 instead of the LS LOL
Old 05-27-2016, 11:41 AM   #147
First c10
First c10's Avatar
Really? why? I am just wondering.
GO GO!!!
Old 05-27-2016, 02:19 PM   #148
lowrodderchev
just like yours a "Series of unfortunate events". if I would have done a straight 350 swap with a rebuild tranny sure it would be more money but I'd be done. I'm almost 2 months into my swap and seems like every time I turn around a new issue arises.
Old 05-27-2016, 03:34 PM   #149
First c10
First c10's Avatar
OK I have an idea you can finish up mine and I'll come finish up yours LOL
GO GO!!!
Old 05-27-2016, 05:21 PM   #150
First c10
First c10's Avatar
OK so I am going try this... my first video unfortunately it is not a good sound... Motor noise
GO GO!!!
