Old 02-04-2017, 09:55 PM   #126
Jason7121
Jason7121's Avatar
Re: 71 C10 6.0 LS ground up build
Jason7121 is offline   Reply With Quote
Old 02-08-2017, 01:48 AM   #127
Jason7121
Jason7121's Avatar
Getting the hood and fenders fit now. Will need to do a little work to get gaps right. Cowl panel needs some work too.
Old 02-11-2017, 09:48 PM   #128
Jason7121
Jason7121's Avatar
Started getting moldings mocked up and ready to drill all the holes. Any advice on hole size and approach for the clips would be great
Old 02-14-2017, 04:49 PM   #129
Jason7121
Jason7121's Avatar
Got all the holes drilled for body moldings. Got cab divider trim and taillight bezels in place and holes drilled as well.
Old 02-14-2017, 04:53 PM   #130
MMcMasters
MMcMasters's Avatar
Heck yeah! It won't be long now!!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 02-14-2017, 04:56 PM   #131
Jason7121
Jason7121's Avatar
Almost ready to tear down one last time!
Old 02-15-2017, 01:33 AM   #132
88Stanger
88Stanger's Avatar
damn fine job so far!
88Stanger is offline   Reply With Quote
Old 02-15-2017, 01:37 AM   #133
Jason7121
Jason7121's Avatar
Thanks for the compliments
Old 02-19-2017, 11:37 PM   #134
Jason7121
Jason7121's Avatar
Got the tailgate band mocked up and the holes drilled. Also worked on panel alignment this weekend. The body shop has been great about having me be part of the work.
Old 02-27-2017, 02:24 AM   #135
Jason7121
Jason7121's Avatar
Body came off Friday and primer was put on cab and front end. Pretty pleased with the epoxy primer.
Old 02-27-2017, 02:27 AM   #136
Jason7121
Jason7121's Avatar
Got Cpp tubular control arms installed today and also headers fit.
Old 02-27-2017, 11:55 AM   #137
lowrodderchev
lowrodderchev's Avatar
Looks good bro
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 02-27-2017, 12:44 PM   #138
MMcMasters
MMcMasters's Avatar
You will be driving it before you know it!
Mike
Old 02-27-2017, 02:10 PM   #139
uxdesigner
Great work! Looks like you moved on with mounting the body moldings. Any advice on hole size and approach you have concluded now that you've had a chance to work through the install?
uxdesigner is offline   Reply With Quote
Old 02-27-2017, 02:14 PM   #140
Jason7121
Jason7121's Avatar
I used stick on clips where there was no access to put a nut on back side. Holes I did drill I drilled 1 size larger than the threaded stud so moldings could be moved around a bit until aligned. The spots where there is a screw going through to hold them I drilled 1 size smaller than the screw for a tight fit of screws. Hope this helps.
Old 02-27-2017, 02:34 PM   #141
meenaggie
Low A/C mount question?
It looks like you used the Alan Grove / Vintage Air low mount A/C bracket and Sanden 508 compressor designed to work with the stock accessory drive. This set up uses the rear stock belt for A/C only. Is that correct? If so, any clearance issues with the brackets and/or compressor?
I am planning on running this setup on my LS6 and 1968 C10. I was hoping to find someone that has made it fit before ordering the parts. Mine will use the corvette offset instead of the truck but other than that would be very similar. Thanks in advance.
meenaggie is offline   Reply With Quote
Old 02-27-2017, 02:39 PM   #142
Jason7121
Jason7121's Avatar
My bracket came from old air products and uses the stock configuration for belt. I did clearance the frame a bit to make everything fit.
Old 02-27-2017, 08:09 PM   #143
sprint_9
sprint_9's Avatar
Your panel alignment looks great. Control arms look good to, kind of wish I would have went with something tubular on mine.
sprint_9 is offline   Reply With Quote
Old 02-27-2017, 08:25 PM   #144
Jason7121
Jason7121's Avatar
Thanks we spent alot of time with panel alignment
Old 02-27-2017, 11:01 PM   #145
jkeating1
jkeating1's Avatar
I like the full molding package you're doing. Great mix of OEM look, but with engine, trans, brakes, and suspension right up-to-date!
jkeating1 is offline   Reply With Quote
Old 02-27-2017, 11:13 PM   #146
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
How did you fabricate the fuel system lines? Can you take a pic of the lines coming off the engine to the frame?
Thanks,
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-27-2017, 11:46 PM   #147
Jason7121
Jason7121's Avatar
I used 6an push lock hose with 6an hose holders
Old 02-28-2017, 09:11 AM   #148
mcbassin
Still Learning
mcbassin's Avatar
Looking good!
mcbassin is offline   Reply With Quote
Old 03-06-2017, 10:51 AM   #149
Jason7121
Jason7121's Avatar
Thanks everyone. This weekend we worked on fitting the new tailgate and got trim holes drilled for upper gate molding. Final prime and block this week then color next week!
Old 03-06-2017, 10:59 AM   #150
Jason7121
Jason7121's Avatar
Picture of tailgate ready for primer
