Old 01-29-2019, 12:33 PM   #126
Johns 66
Johns 66's Avatar
Re: 1965 LWB Stepside Build
Originally Posted by roll_the_dice View Post
OK, got the firewall shot today with #503 light green which as I have said is the original color of the truck. I think it will be a nice pop of color against the mostly satin black engine bay. I am going to clean up the cowl section and shoot it in the same color (I think), so it will peek out from under the cowl. This color will darken some after I get clear on it, but will wait for that so I can do the cowl section at the same time along with the rest of the cab after I clean it up.
Again not perfect and I am not striving for perfect or I would not have painted it in my driveway.
Just took the tape off...not bad, but now that I look at it, I think I am going to do the entire cowl section including the top just under the cowl, not just the windshield wiper section...here it is without the tarp and tape. Should be easier to paint that entire section also than just in the wiper section...thoughts?
Andy this looks really good...I mean REALLY good!
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 01-29-2019, 04:18 PM   #127
straight6chevyguy
straight6chevyguy's Avatar
It looks great!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 01-29-2019, 09:40 PM   #128
roll_the_dice
roll_the_dice's Avatar
Thanks guys....I appreciate it. I finally feel like the truck is moving along. The POR-15 is supposed to be here tomorrow...so moving forward!
roll_the_dice is offline   Reply With Quote
Old 01-31-2019, 11:17 PM   #129
roll_the_dice
Didn't get much done the last few days... Removed the wiper linkage, going to blast it and paint it green. Started cleaning out the cowl area...going to remove the wiper motor and clean up the rust in the opening and sand clean up the rest of it for paint...got the e-brake handle and steering column bracket blasted and primed. Hopefully will get paint on them tomorrow. Looking at the cowl section with the original green still under the white...The firewall green is a great match to the original...I will give a shoutout to www.automotivetouchup.com for mixing the color. I have used them a lot over the years...always a great match.
Old 02-01-2019, 12:21 AM   #130
Johns 66
Johns 66's Avatar
Andy this is looking great....I will be following your lead shortly once I get mine back from Bryan.
2019 GMC AT4
Old 02-01-2019, 09:02 AM   #131
roll_the_dice
Has he sent you anymore pictures? Should be getting it back fairly soon right?
Should get green on the handbrake today and silver on the steering column bracket. I am interested in how the silver is going to look. The paint arrived yesterday...hope to get more blasted and primed today. Need to go turn the heater on in my shop so it can warm up some.
Old 02-01-2019, 01:13 PM   #132
roll_the_dice
OK, shot some color on the pieces this morning. Hooked up a cross draft spray booth out of my blast cabinet box since it was chilly to spray outside. The steering column is Silver Pearl Metallic that was used on 1965 Corvettes. I like this color a lot! I will also put this color on my wheels. I will probably use a satin finish over it. I don't want it too shiny. I painted the hand brake handle #503 light green for just a little color in the cab. It will be the only piece inside the can that color. I will use gloss on it most likely to match the other green accents I will do on the truck.
Old 02-01-2019, 02:39 PM   #133
Johns 66
Johns 66's Avatar
I like the colors.....Gonna look sharp!!!!
2019 GMC AT4
Old 02-01-2019, 05:10 PM   #134
straight6chevyguy
looking good!
Old 02-05-2019, 10:29 PM   #135
roll_the_dice
Thanks guys...Slowly getting parts blasted and painted. Got the pieces off the steering column today...cleaned them up and painted them...not exciting, but nice to get the blue off and the new color on. Hope to get the inside cab painted soon.
Need to figure out my brakes. I have front disc and rear drum and it didn't have a proportioning valve on it at all...will crawl under the cab tomorrow just to make sure one isn't on the frame rail somewhere.
Old 02-05-2019, 11:15 PM   #136
Johns 66
Johns 66's Avatar
Looks sharp...When I paint mine Ill get with you to figure out how to take it apart..lol
2019 GMC AT4
Old 02-08-2019, 12:05 PM   #137
roll_the_dice
Found this picture of my brothers in our front yard April 1968. I was 2 and not in the picture. My dads truck in the background...Cool picture. I think I may have more of some of the trucks my family has owned somewhere...I will have to look.
Old 02-08-2019, 12:46 PM   #138
Johns 66
Johns 66's Avatar
Awesome Pic Andy!!!!
2019 GMC AT4
Old 02-08-2019, 06:22 PM   #139
cwcarpenter98
cwcarpenter98's Avatar
That is a cool pic! I want those hubcaps lol
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-09-2019, 01:39 PM   #140
roll_the_dice
Yeah those hubcaps are fantastic!
Old 02-09-2019, 01:52 PM   #141
roll_the_dice
OK so didn't get much done today...a friend is getting married and his wedding is getting in the way of my truck time. Wedding starts at 3...BUT I did get one coat of POR15 inside the cab floors and all the rust areas inside. Going to do coat 2 tomorrow.
However, I have been sanding dead paint off the truck and clear coating it. Today my wife helped with some sanding. We knew there would be original green paint on the tailgate..we see chunks of it all the time...so this is what she did with a sander today. It is a nod to the original...I love how she found the green under the white and primer. I think it will look awesome when I clear coat it.
Old 02-12-2019, 02:42 PM   #142
roll_the_dice
Guess no one liked the tailgate "NOS" letters...Doesn't matter...we like it!
Anyway, kind of an overcast day today...waiting on the rain to come. So I sanded the cab somewhat getting ready for the clear coat over the dead and freshly sanded white paint. I need to scrape out the old seam sealer around the drip rail and reseal it. The green on the rear was mostly all there from where it was painted without removing the bed from the PO. Most won't be seen now after it all goes back together anyway. Still have to paint the windshield wiper linkage and under the cowl.
Old 02-12-2019, 07:12 PM   #143
Johns 66
Johns 66's Avatar
The tailgate looks really cool....Are you gonna try and do that over the entire truck? Sanding some parts to show the original color....but the most important thing that I thing is cool is the Misses helping out
This is gonna look killer once you are done with it.....Im still in the sanding stage....LOL
2019 GMC AT4
Old 02-13-2019, 09:01 AM   #144
roll_the_dice
Thanks...Not really going to do it over the entire truck. I wanted it on the tailgate. Thought it would be nice. I am just really sanding off the dead paint and sometimes I get to aggressive and it goes through to the primer, green, or metal. If it does, it does. I will clear it though to bring the shine back.
Old 02-21-2019, 08:18 PM   #145
roll_the_dice
Have't gotten much done in the last week...the weather has sucked...rained every day. Today, I started working on the restoration of my "new" steering wheel. I cut into all the cracks and am going to start putting PC-7 on it this weekend. Once I get all the cracks filled and sanded smooth, I will epoxy prime and paint it my interior color.
I also tried Christians "trick" of using aluminum foil and water to polish the horn ring for the wheel...the pictures are hard to tell the difference but it is a huge difference! Thanks Christian.
Old 02-21-2019, 08:36 PM   #146
Johns 66
Johns 66's Avatar
Interested to see how the wheel comes out...gonna have to do mine when I get her back.
2019 GMC AT4
Old 02-21-2019, 08:51 PM   #147
cwcarpenter98
Looks like they cleaned up pretty good! The biggest difference I see is that the chrome shines in the after pic, but does not shine in the before pic
Keep up the good work man
Christian Carpenter
Old 02-22-2019, 12:12 PM   #148
roll_the_dice
I am curious too! I just put the PC-7 on all the cuts I made in the wheel. I will let it cure, sand it smooth and see if I need to add more if there are any low spots. I think it takes 24-48 hours to cure.
Now I am trying to decide whether to paint the wheel the same I am doing the interior...silver or a matte/satin black.
Thanks, I owe it all to you...I took a better picture of the finished piece this morning. I am please and won't worry about getting it chromed for a while.
Old 02-22-2019, 06:31 PM   #149
Johns 66
Johns 66's Avatar
Wheel is gonna look really good, wished it had fewer cracks for ya but that is pretty much impossible due to the age. I haven't even thought about the steering wheel color on mine.
Im getting pretty good at sanding right about now..lol
2019 GMC AT4
Old 02-23-2019, 01:11 PM   #150
cwcarpenter98
Glad I could save you a chunk of change! It looks like a high quality piece now, compared to the before pic
Christian Carpenter
