Old 10-06-2019, 09:29 PM   #126
cornerstone
cornerstone's Avatar
Re: 72 Swb starting from the bottom
Looks really good!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-07-2019, 09:17 PM   #127
J3rm0ff
Originally Posted by cornerstone View Post
Looks really good!
Thanks!
J3rm0ff is offline   Reply With Quote
Old 10-07-2019, 09:23 PM   #128
J3rm0ff
Got the spindles and brackets painted, the transmission painted with flat clear, and got the trailing arms painted with new bushings. Also got the trailing arm mounts bolted on with the spacers and got the ac compressor on. Although I’m not sure I have the air gap set right on the clutch. I have 2 washes but don’t remember taking two washers off. Grrr.
Old 10-11-2019, 04:41 PM   #129
J3rm0ff
Got the top side of the inside of the cab primed this week. Going to finish up priming the inside of the cab next week. Also got the last fitting in so I can finish plumbing the air ride
Old 10-11-2019, 09:43 PM   #130
cornerstone
I just noticed that you installed spacers between the trailing arms and the crossmember... I can't say I've ever seen that before... What's the reason or benefit for doing that?, if you don't mind educating me please.
Brian
Old 10-11-2019, 10:29 PM   #131
a.c.ward
the spacers are a mod that I have been doing on customer builds and my personal build.
it moves the axle centerline back the distance of the spacer.
I usually use 1/2" thick aluminum from local metal store, get 3" strip, 1/2" thick and about 2 feet long for less than $20. that amount of stock has done to date 3 trucks and still have enough for at least one....
A C Ward Retired US Army
66 El Camino
67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475
a.c.ward is offline   Reply With Quote
Old 10-11-2019, 11:05 PM   #132
cornerstone
Interesting... is it just for aesthetics? Sorry for the hijack man.
Brian
Old 10-12-2019, 09:27 AM   #133
J3rm0ff
No problem. Like he said when you lower these trucks because of the arc of the trailing arms it moves the wheel forward in the wheel opening. Some people move the whole crossmember back but I chose spacers that way if I need to mill them down more after everything is back together I can do that. Right now they are 3/4” thick.
Old 10-16-2019, 08:59 PM   #134
J3rm0ff
Got the inside about ready to prime. Going to have to push it outside to sandblast a few tight places. Also bolted up the trailing arms for the time being and thought I was finally going to finish up the air system today but ordered the wrong fitting
Old 10-17-2019, 12:49 AM   #135
cornerstone
First time I've heard this... If the wheels are noticeably forward on lowered trucks I may want to move my crossmember before I mount my cab and bed permanently. Could you say what the usual measurement that the wheels need to go back in order to be centered in the wheel well is?
Thanks, Brian
Brian
Old 10-17-2019, 10:02 PM   #136
J3rm0ff
Thanks, Brian
Can’t say for sure it’s been a year or so since I figured that out. I’d say between 1/2” and 1” depending on how low it is
Old 10-20-2019, 01:38 PM   #137
J3rm0ff
Got the inside of the cab painted and had to throw the turbo back on just for some inspiration
Old 10-20-2019, 09:06 PM   #138
KMC3420
KMC3420's Avatar
Looking good. How close was the low mount AC to the frame?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 10-21-2019, 09:59 AM   #139
J3rm0ff
Thanks. There's a decent amount of clearance all around it. I made my motor mounts and set the motor as low as possible so I think that helped.
Old 10-21-2019, 11:48 AM   #140
KMC3420
KMC3420's Avatar
Okay, thanks. I need to go look those motor mounts over again.
Keagan
Old 10-22-2019, 09:01 PM   #141
J3rm0ff
Got the frame pushed back over and set back on the quick jacks and started putting the front suspension back together and realized my bag plates that I set up for use with the factory lower control arms aren’t lining up at all with the ridetech control arms. I never paid attention closely before when I had them on. I called up ridetech and ordered their plates and the front shock brackets too.
Old 10-26-2019, 03:33 PM   #142
J3rm0ff
Got the ridetech upper bag plates in and that solved my issue. Also got the ridetech upper shock brackets and started getting those put on. And finally got to see the brakes all installed!
Old 10-28-2019, 10:39 PM   #143
J3rm0ff
For the first time today I got to play with the airlift air management! That was a treat considering it’s been sitting in a box for a year.
Old 10-29-2019, 12:19 AM   #144
cornerstone
Cool! Initially I mounted my air manifold on the crossmember just in front of my rear mounted gas tank, but when it came time to route my exhaust pipes over the axle it was clear they needed to occupy the same space. Would you mind posting a picture of the way you mounted yours? What type of controller are you going to use for the air ride?
Brian
Old 10-29-2019, 10:21 AM   #145
J3rm0ff
I was going to originally put mine in the cab but changed my mind on that. because of the way my exhaust is routed I had room to put it here. if you have normal dual exhaust I'm not sure if this location would work for you. Here's some pictures anyways so you can see how its mounted and the way the exhaust routes.
Old 10-29-2019, 04:21 PM   #146
layinrocker65
layinrocker65's Avatar
Brakes look awesome. What did you end up doing with them as far as rotors and hubs? I have the same spindles on my truck and those calipers on the shelf for future use.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 10-29-2019, 05:33 PM   #147
J3rm0ff
Those are factory camaro ss rotors I got with the calipers. I’m going to be buying new rotors but not sure if I want to redrill the rotors or the hubs. Jeep srt8 rotors are 5x5 and similar thickness which would also be a good choice but I think the offset of the rotor was less so it would push the caliper further into the face of the wheel.
For the hubs I used factory c10 rotors and machine off the rotor part and then turned down the OD to fit into the rotor.
Old 10-31-2019, 12:57 AM   #148
cornerstone
I do appreciate it.
Brian
Brian
Old 10-31-2019, 11:31 AM   #149
SCOTI
SCOTI's Avatar
Cool build. Tagging in to watch the updates.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-10-2019, 06:08 PM   #150
J3rm0ff
Just got back from a week in Vegas at sema. It’s a love hate week. Love all the ideas but hate that all these ideas will cost more money
I’m not good and snapping pictures but here’s a few I got.
