05-01-2020, 09:40 AM | #126 | |
Re: 53 3100 - complete rebuild and upgrade . . . .
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-01-2020, 10:47 AM | #127 |
good to see a beefy cross member in there. since the frame has lost the old cross member behind the engine the frame will be prone to flex some between the front and trans cross members. this can affect the cab mounts and some fellas have had issues with the door gaps changing and doors closing properly. big HP will also make it worse. the cross member you built looks beefy though.
just another thing to consider. nice machine work you are doing, impressive work and planning processes. keep the pics coming, they stoke the rest of us a bit to get us off the couch. |
05-01-2020, 09:38 PM | #128 |
Thanks for the input, fellas.
As for the frame flexing, I'm not completely finished with the support between the front and rear, but wanted to get everything mounted first (engine, trans, headers e.t.c) before I fully draw it out. That way, I'm not fighting it later. The plan is to integrate everything from the motor mounts and trans mount to the driveshaft loop, so there's plenty left to cipher on. Plus, the boxed frame should help too. More later - thanks for looking - Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 |
05-12-2020, 07:32 PM | #129 |
Just a little progress to keep motivated. Once the old bass boat comes out it's hard to get shop time !! Finished getting the crossmember mocked up and got the slugs tacked in, so it's something anyway.
More later - Dan
05-12-2020, 08:04 PM | #130 |
super nice!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-13-2020, 08:58 AM | #132 |
Great detail.....it takes time. There are no short cuts with this build.
Bravo... Marc
05-14-2020, 12:15 AM | #133 |
Post Whore
very slick on the trans crossmember..!!
05-14-2020, 05:32 AM | #134 |
Thanks for the compliments. Should get it welded up in the next week or so then I guess I'll start headers. That's always fun!
Thanks for looking - Dan
05-14-2020, 08:38 AM | #135 |
Nice job sir....
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
05-21-2020, 05:05 AM | #136 |
Not a lot of progress, but the crossmember is done for now, so time to get the 5.3 and cab back on and move to the next item.
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 Last edited by big_dan; 05-23-2020 at 03:29 AM. |
05-23-2020, 07:54 PM | #137 |
Headers next?
More later - Dan
05-24-2020, 06:07 PM | #138 |
Would be good to have a cab on there to mock up steering column angle before getting headers, maybe.
05-24-2020, 08:16 PM | #139 | |
So really, I should have said headers-firewall-column-steering next LOL. Thanks for looking- Dan
05-31-2020, 07:25 PM | #140 |
Another minor update.
Last set of headers I built I started with "U" and "J" bends. This set, I had an epiphany and thought I'd start with a pre-bent set and see how that works out. Either way there's substantial fabwork involved, but I thought it was worth a shot. So, here goes the passenger side while I ponder steering columns and such on the driver's side. FYI 1-3/4" with 3" collectors, planning to have cutouts right behind the H-pipe. As you can tell, no where close. Yet. More later- Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 Last edited by big_dan; 06-01-2020 at 05:13 AM. |
06-19-2020, 04:49 AM | #141 |
Slowly but steadily making progress on headers. Started on the passenger's side, should have everything tacked up soon I hope. Went ahead and grabbed my booster, steering column, u joints, heim joints and DD shaft so we can attack the drivers side when this is finished. No where near final yet, just showing a little progress.
06-19-2020, 06:50 AM | #142 |
looking good
Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
06-19-2020, 07:43 AM | #143 |
Looks great. Keep at it..
Marc
06-22-2020, 04:28 AM | #144 |
Thanks, fellas.
One more piece, moving forward. Ididit steel column (not SS, going to paint it), 30", 1" DD shaft, tilt and turn signal with universal GM harness, no shifter. I'll start this once I finish the passenger side. Kicking around the idea of making my own wheel, but we'll see about that. More later - Dan
06-22-2020, 08:23 AM | #145 | |
Marc
06-23-2020, 10:55 AM | #146 |
Youngrodder - I didn't think I'd like a chrome column either. Thanks for looking-
A little header progress. Passenger side is fitted up. I kicked out the rear tube for length; that keeps all 4 tubes within a few inches of each other. I may change it, so I'll not weld them up yet. Pics are pretty self- explanatory, so I'll shut up and study on the drivers side a bit. . . . More later - Dan
06-23-2020, 11:09 AM | #147 |
Looks good Dan... That header look slick. Well done
Marc
06-23-2020, 12:21 PM | #148 |
Very nice job on the headers.Looks great!
Desert |
06-23-2020, 12:53 PM | #149 |
Good job on the headers.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-23-2020, 02:27 PM | #150 |
Post Whore
Really nice...I had a buddy that built his own headers for his wagon from scratch...lots and lots of work hrs in them..yours look great
