Old 04-19-2022, 05:35 PM   #1476
3757chevy
3757chevy's Avatar
Re: Post your 60-66 craigslist finds
No facebook here. Can't see?
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 04-19-2022, 10:23 PM   #1477
60short
Revitalizing a 6T C10
60short's Avatar
Condition
Used - Fair
C10 stepside and c20 propane trucks and a a suburban. Make offer no lowballer
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 04-19-2022, 11:01 PM   #1478
3757chevy
3757chevy's Avatar
MIKE
Old 04-20-2022, 10:19 PM   #1479
60short
60short's Avatar
cLicky CliCky
Chevy Belair transmission - $50 (Santa Barbara)
Transmission I acquired. Pretty sure it came out a Chevy Belair
looks like one of them OD transmissions - does anybody know if this is the same length as a standard 3 speed ( ie drive shaft length changes?)
Old 04-20-2022, 10:50 PM   #1480
vetnat
I am fairly certain the 3 speed OD transmission is the same length as the long tailshaft 3 speed transmission, like the one pictured here. I believe the spline count is different, so you need a different slip yoke, but otherwise fits with the current driveshaft.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 04-20-2022, 11:02 PM   #1481
cwcarpenter98
cwcarpenter98's Avatar
Originally Posted by 60short View Post
cLicky CliCky
That's a good deal for that transmission! I would buy that in a heart beat if it was close by
Yes, the 4 bolt side cover overdrive transmissions are the same length as the long tail shaft 3 speeds. I have two of the overdrive transmissions. The one currently in my truck came out of a 65 C10. I forget the count, but it has finer splines on the output shaft than the standard 3 speed I pulled out of my truck. The other overdrive that I have has the same spline count as the old 3 speed I pulled out.
I believe the output shaft spline count ran from 55-64 and then changed in 65. Another difference I noticed is that the input shaft necked down on my 55-64 overdrive trans but did not neck down on the 65 I put in the truck.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-20-2022, 11:04 PM   #1482
60short
60short's Avatar
I was hoping you would chime in, you have most of the knowledge ive seen here on these beasts, ...
Ive sent him an email, Im in the middle of trying to sort a transmission swap, but $50 is $50, and probably worth the risk
Old 04-21-2022, 12:01 AM   #1483
cwcarpenter98
Thanks, I did a lot of research on them before I made the decision to acquire one. I've had it in my truck for over three years now and picked up a second as a backup or for spare parts if needed. The only thing I haven't done with one yet is to rebuild it, but that will come eventually
But yeah, $50 is $50. The overdrive book by Randy Rundle is a great resource for digging into the details on how it all works.
Christian Carpenter
Old 04-21-2022, 07:59 AM   #1484
NewBayColony
NewBayColony's Avatar
I put one in my 72 because it has 4.56 gears. I love it. Now it has good pickup around town but I can cruise down the highway. I was lucky I did not have to change anything driveshaft wise just the shifter linkage. Mine came out of a 63 Impala. Good Luck!
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 04-27-2022, 12:39 AM   #1485
vetnat
1965 GMC firetruck on Facebook.
https://www.facebook.com/commerce/li...are_attachment
Old 04-27-2022, 12:42 AM   #1486
vetnat
Pic
Old 04-30-2022, 11:14 PM   #1487
Desert dog
https://tucson.craigslist.org/pts/d/...476044065.html
Desert dog is offline   Reply With Quote
Old 05-02-2022, 03:08 PM   #1488
sweetk30
sweetk30's Avatar
looks like a N.O.S. ranch hand bumper for a 60-66 . upstate ny area .
https://www.facebook.com/marketplace...3437773312393/
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-28-2022, 09:16 AM   #1489
factorystock
factorystock's Avatar
Clean 3/4 ton, these don't come around every day. Not mine. Signs of an ex camper hauler, large mirrors and extra tank, which accounts for the much much better than average condition. A set of 19.5's would be in its immediate future if I was in the market. https://sacramento.craigslist.org/ct...485754110.html
factorystock is offline   Reply With Quote
Old 05-28-2022, 09:44 AM   #1490
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
And in a nice dry area of California.
Sadly though, who ever buys it will probably convert it to a half ton, put an LS in it and lower it - ruining the 'grandpa truck' beauty of it.
66 C20 Service Truck:
Old 05-28-2022, 10:27 AM   #1491
factorystock
Right, the grandpa looking truck becomes an ex-grandpa looking truck, seen it many times. Large percentage of the original buyers of these 3/4 ton camper boom type trucks were veterans from WWII and Korea, they wanted travel, explore and enjoy the large beautiful country they fought for and put there lives on the line for.
Old 05-28-2022, 11:13 AM   #1492
forestb
forestb's Avatar
You guys are a couple of decades off. Those are now great grandpa trucks��
forestb is offline   Reply With Quote
Old 05-28-2022, 09:51 PM   #1493
jocko
jocko's Avatar
64 GMC Motorhome $6K
She's a beaut Clark!
Old 05-30-2022, 07:50 AM   #1494
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-30-2022, 12:21 PM   #1495
factorystock
Read the GMC camper ad ( very clean original piece by the way Jocko), looks like somebody already destroyed the clutch. Note position of pedal. Never liked the way the 4 speed gear shift pattern was for rookie drivers, some latter patterns had the more accurate L 1 2 3, I could see how somebody could blow a clutch or U joint pronto.
Old 05-30-2022, 04:12 PM   #1496
forestb
forestb's Avatar
I think it was ruined at the manufacturer when they put the camper on it
Old 05-30-2022, 04:29 PM   #1497
oem4me
I actually love it! Considering the low initial cost and wide open potential for a build-to-suit camper interior, it wouldn't take much to create an awesome food service rig for vintage car shows etc. Picture a big walk-up window under that awning, or maybe on the driver side.
I'll take two hot dogs and three beers please! LOL!
Old 06-09-2022, 10:30 AM   #1498
jweb
jweb's Avatar
66 stepside in San Diego
https://sandiego.craigslist.org/csd/...494089108.html
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 06-22-2022, 01:38 PM   #1499
MusicMan70
MusicMan70's Avatar
Nice Panel up in Medford
https://medford.craigslist.org/cto/d...499607272.html
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-21-2022, 09:44 AM   #1500
Bridgeman57
Bridgeman57's Avatar
Thumbs up Re: Post your 60-66 craigslist finds
Found this 61’ for $12. Going to look at her tomorrow. What do you guys think. I feel it’s worth way more then that in its current state. Minor Surface rust above window and on bottom of doors he says. 350 with a Muncie 4 speed with Bluetooth radio 🤙🏻
Bridgeman57 is offline   Reply With Quote
