#1501 |
Re: What did you do to your truck today!
created a mold for my center console to begin fiberglassing the shape. and got closer to finishing my radiator/core support cover
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#1502 |
painted around the windshiel area inside and out, finished painting the splash pan, painted the radiator core support, radiator, frame rails, also painted the drivers side fender. i also installed the grille trim and started installing the grille. also purchased some headlight and wiper switch knobs and bezels from sharpie
#1503 |
oh, and i sprayed some rust reformer paint on the inside of the replacment passanger fender
#1504 |
Washed it, then drove it all over town. Here it is at the local parts store parking lot. Had to stop, running a special on brake cleaner.
#1505 | |
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#1506 |
Bought new front drop springs from CPP! My youngest son was inspired to do his pinewood derby car from one of the posts on here. He is making his a truck!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1507 |
The Niner
![]() Join Date: Nov 2010
Fixed an oil leak, changed the oil, filled the gas tank, took her to the car wash, then put her back in the garage until the snow melts (July I imagine...)
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#1508 |
I put the correct pitman arm on my power steering box and mounted it on the truck, maybe tomorrow I'll get pump mounted on the motor,
#1509 | |
![]() Join Date: Jul 2010
![]() Posted via Mobile Device |
#1510 |
The Niner
#1511 |
installed the door hinge that i got from sharpie, notched my dash mount, welded some studs to the bottom of the dash, and installed and painted the dash (will do body work on the center later), also aquired some new mirrors for my burb
#1512 |
#1513 |
adjusted my detent cable. Rolling one tire fires and no more manually shifting at wot
'72 cheyenne super step, '05 long bed gmc |
#1514 |
What?
fixed my rear upper shock mount, then took her out for ride to another board members hacienda for a visit.
Nice day.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#1515 |
got parts for it and cool things that arent parts for it more like presents! ad painted them
#1516 |
Found a nice takeoff tailgate for my truck,
to bad its the wrong colour.
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
#1517 |
RAT1968 '68 Cab/'71 Parts
Nasty day around here today. Yesterday was beautiful, but a bad day for the wrenching. As I was installing and trying to adjust the linkage on the T350,
I found out the steering column I'd painted and otherwise massaged is full of enough slop as to not let "Park" be "Park".... I was able to make a radio block off for the newly painted dash. I made it out of a radio...I just applied a liberal amount of grinder with a cut-off blade and a half a garbage can worth of '68 radio internals. I'm thinking about making a little plaque that will match the ignition indicator. It will say, "This Radio Does Not Work". Even though it was a nice weather day yesterday that, by the end of the day had me pissed at more need for part$ I didn't count on (what's new about that?), today working in the the nasty weather day yielded some good results. Adjusted the ECE adjustable pan hard bar (I have about 3/8" equally between the inside of the wheel tub and the tires riding on 20 x 10's), and tightened down the rest of the rear suspension parts. Installed the rear roll pan, and mounted the passenger door.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 01-30-2011 at 05:05 PM. |
#1518 |
I put an new alternator on mine today.
#1519 |
continued with the body drop.finished the last couple peices of the floor supports then started some sheet metal
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 Last edited by (joey); 01-30-2011 at 06:31 PM. |
#1520 |
Finished my bed
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR" ![]() |
#1521 |
That is sweeeeeeeeeeeeeeeeeet; I never though of going 1 piece...
#1522 |
Words under my name
I took both doors apart, replaced one door handle, I was going to replace window regulator but decided not yet because I need to get new weather trim first, Pulled both door locks out, I am going to either get new ones or get these re-keyed. Installed new window visors. Took her for a ride, on the freeway, I need to get her timed, she was making a poping noise when I pushed in gas peddle when I was at around 65 mph. I bought a compression tester and timing light, I was going to do the checks but my lady needed me, so I will continue next weekend.
69 Chevy CST/10 "Project: Bloody Knuckles" ![]() 2010 VW Golf, daily driver Wrench Rookie |
#1523 |
![]() Join Date: Jan 2006
place some insulation purchased from Lowes 16 bucks did the cab floor and plenty leftover
#1524 |
Replaced my rear u-joint in the ol' '72
1972 Chevy C/10 Custom Deluxe 1973 Chevy C/10 Custom Deluxe Bowties for life ![]() |
#1525 |
