Old 06-24-2016, 08:59 PM   #1601
Possmguts
Possmguts's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Hey bud... the holes in the fire wall for the vintage air... is that a panel or do you have to drill those? Thanks
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 06-24-2016, 10:45 PM   #1602
Vic1947
Vic1947's Avatar
Originally Posted by Elliot949 View Post
You gotta love body/frame/mechanical shops... they really have a different outlook on things..
Ain't that the truth!
Mine is a panel that came with the kit and the holes were predrilled. If I'd started with a blank sheet of material, I might have relocated them, although you run the risk that the lines to the evaporator may not work as well.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 07-03-2016, 04:18 PM   #1603
Vic1947
Vic1947's Avatar
I'm past ready to get going with the LS3 install, so even though the frame isn't 100% just yet, I decided to mock up some stuff and just see how it all might fit... just in case the frame ever gets fixed.
I needed some help getting the trans out of the shipping container and attached to the engine, so I called Scott and he was at the house before I could hang the phone up. Together we rassled the trans into position and dropped the assembly between the frame rails. I was pleasantly surprised to find that everything cleared all the obstructions and the Caddy oil pan doesn't hang below the front crossmember. The CPP sheetmetal towers and their adjustable motor mounts took some finessing to get into position, but I think once the frame is tweaked back into position, I shouldn't have to massage them too much to line up with the stock holes.
I took some photos of Yeller one day when Vern dropped by, and I can tell I have my engine back about 1.5" to 2.0" from where Chip dropped theirs in. Since I plan to run an aftermarket front drive assembly, I have no need to worry about the stock A/C compressor location. My main concern at this point was to see if I could use my existing driveshaft without modifying it. I swapped out the yoke yesterday and it looks like it will fit perfectly.
Victor
Old 07-03-2016, 04:34 PM   #1604
Vic1947
Vic1947's Avatar
The stock exhaust manifolds that come with the C&C package should work great. Normally I'd pop for headers, but I'm so over budget, I'm going to skip them for now. There are a few hiccups which is to be expected. The sheetmetal towers from CPP don't want to line up with the holes in the crossmember. Plus, the passenger side tower is lifted up off the frame rail somewhat. Hopefully, when the frame gets pulled back into position, some of the misalignment will self correct. If not, I have a BFH that will make it work.
The other thing that's a bit more unexpected is the CPP tubular transmission mount. I'm using an Energy Suspensions poly trans mount and when bolted up in the stock location, it appears that the rear of the trans is hanging down too far. I have a jack under it at the moment, and it could use a 3/4" spacer between the trans mount pad and the crossmember. Spacing it upward like that gets the transmission pan level and even with the frame rails. It also gets the driveshaft in a slightly better position where it goes thru the loop. Nothing is set in stone right now, so I'll have to measure the angles and see what's what later on.
Victor
Old 07-03-2016, 06:49 PM   #1605
sduckworth13
sduckworth13's Avatar
Glad that driveshaft is going to work out for you Vic.
Scott
sduckworth13 is offline   Reply With Quote
Old 07-03-2016, 11:38 PM   #1606
jeh
jeh's Avatar
Mock up looks good Vic, it's a shame with whole frame tweak thing going on. I bet your ready to get her on the road!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 07-04-2016, 08:46 AM   #1607
Elliot949
Elliot949's Avatar
Man Vic... that is looking GREAT!!!!....
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 07-04-2016, 08:53 AM   #1608
snipescastle2
snipescastle2's Avatar
Talking Re: Crusty Rusty Leaky Squeaky 67 Step
Looking great Vic! You'll be interested to know my whole alignment issue was a "Brain Fart" on my behalf....had the upper control arms swapped, right for left.
So, we'll try the alignment shop once again, this time should be a pretty quick visit! Your LS1 install looks to be a very straight forward process. Did they pre program the pcm for your engine mods, or do you have to take it somewhere for that?
Have a great 4th!!!!!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 07-04-2016, 09:29 AM   #1609
Vic1947
Vic1947's Avatar
Ben
Don't feel bad, Ben. I had the relay rod rotated 180 degrees on the silver truck. It aligned okay, but never really felt quite right and would scrub the tires when you turned while backing up. Sometimes that stuff happens when you buy a project in boxes or don't take enough photos. Or in my case, take the photos but don't refer to them.
The LS setup came with a preprogrammed module and all I should have to do is hook it up. GM calls it Connect and Cruise, but there's a lot of little stuff that isn't included. However, the main components are.
Victor
Old 07-04-2016, 03:04 PM   #1610
Possmguts
Possmguts's Avatar
Ben
LOL... Im really glad to know Im not the only one to do that lol... was just told mine was wrong and I got it all fixed up yesterday. Before and after pic...
Old 07-04-2016, 03:14 PM   #1611
Vic1947
Vic1947's Avatar
Step by step, inch by inch, looks like you're making it happen. I'm lovin' the hood and the louvered visor!!!
Victor
Old 07-04-2016, 03:36 PM   #1612
snipescastle2
It's all good! Happens, but you get back up and fix it. At least it's the cheaper
Solution than having to buy all new control arms! The money I spent on the alignment I lost, but hey! At least I got the problem solved and my tires will last
A lot longer now! Now to fix that pesky alternator charging issue....
Have a good one!
Ben
Old 07-04-2016, 04:02 PM   #1613
Possmguts
Possmguts's Avatar
Thanks... I know when you get that frame issue squared away the parts will be flying and that thing you're working on will be done in like 3 days lol
Old 07-05-2016, 08:23 AM   #1614
mcbassin
Still Learning
mcbassin's Avatar
New power plant looks right at in your frame Vic! Sweet!
mcbassin is offline   Reply With Quote
Old 07-05-2016, 03:19 PM   #1615
Xeen
Xeen's Avatar
Vic when I installed the CPP sheet metal mounts they lined up perfectly, so yeah when you get your frame fixed you will be golden.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-06-2016, 12:35 PM   #1616
Low Elco
Supermatic! To be truthful, we had a 350/700r4 in Yeller before, So I was running under the assumption that the transes were ballpark the same length. So I reused the driveshaft and set everything from there. Plus, y'all have no idea how bucks-down Yeller really is. We really didn't want to cut the shaft. Irony is, 6 months later I got one for $27 from PNP. Anyway, In hindsight, the motor'd be a lot closer to the firewall if I had it to do again. Looks killer, Vic!
Low Elco is offline   Reply With Quote
Old 07-06-2016, 02:32 PM   #1617
Vic1947
Vic1947's Avatar
Thanks, Chip. The cool thing about Yeller is that it doesn't look like a "bucks-down" build, even though I know you spent countless hours scrounging the yards for parts. I worked for a guy who liked to say, "Anyone can smother a fire with money... takes a clever person to put one out using just their smarts." I'll end up with more in Crusty than I planned, but unloading Maybelline was the price I had to pay. When it came to setting the engine, I essentially did the same as you. Didn't want to pay to have the driveshaft modified, so the rest of the drivetrain is based off it. Lucked out and had holes in the right place for the trans crossmember, plus the motor mounts had just enough adjustment to fit the towers. Next up is dropping the cab onto the frame to check the bellhousing clearance. If it's good, I'll mark where everything sits and hope it all goes back together during final assembly.
I called Leroy's Frame Works again yesterday and he assured me he hasn't forgotten me. He mentioned he'd been in the hospital a couple of days and was still catching up.
Victor
Old 07-06-2016, 09:49 PM   #1618
Vic1947
Vic1947's Avatar
Set the cab in place on the frame and it looks like the engine placement will be fine. Maybe move it forward 1/4", but I need to fine tune the body mounts to know for sure. The coil covers miss the firewall by about 3/8" and it looks like the HydraStop unit will clear with no issues. There's plenty of room between the tunnel and the transmission also. Can't think of much else right off hand, but if something comes up, I'll deal with it at the time.
Victor
Old 07-07-2016, 12:17 PM   #1619
Low Elco
Thanks for the props. Glad to see it all fits. I'm almost surprised you're not notching the firewall to get some of that good "racy" weight dist. They leave a nice generous pocket behind the motor, don't they?
Old 07-26-2016, 01:24 PM   #1620
Vic1947
Vic1947's Avatar
I've made an appointment for a week from Wednesday to finally get the frame straightened. Found some nice folks in Grain Valley with the equipment and willingness to put it back right. Fingers crossed that this is the one.
Victor
Old 07-26-2016, 01:26 PM   #1621
Low Elco
Is it the Kustoms guy by I-70? Heard good things about them. Sorry Jim Didn't work out. Holler if you need to haul it.
Old 07-26-2016, 02:01 PM   #1622
Vic1947
Vic1947's Avatar
Yup, Bill at Kustom Cruisers. When your dad talked to Jim, he was absolutely covered up and I don't fault him at all for putting his business first. Just glad I stumbled across these folks. When your website has a blown Chevelle, a Harley and a custom truck sitting in front of the shop, it's a good sign they're our kind of peeps.
Victor
Old 07-26-2016, 03:23 PM   #1623
Jason7121
Jason7121's Avatar
If you don't mind me asking what diameter driveshaft are you running and steel or aluminum
Jason7121 is offline   Reply With Quote
Old 07-26-2016, 03:25 PM   #1624
Elliot949
Elliot949's Avatar
Glad it is all coming together Vic... can't wait to see it rolling along again.
Old 07-26-2016, 04:22 PM   #1625
Vic1947
Vic1947's Avatar
It's 3.5" and steel. Saw some of the carbon fiber ones made by QA1 on Power Tour last month and did some serious drooling.
Victor
