06-19-2023, 09:37 AM | #1601 |
Post Whore
Re: My Dusty 71 GMCe Electruck
pin out diagram lifted from Lingenfelter High Flow Varimax Intercooler Pump Upgrade Kit Installation Instructions
YouTube video: Tesla Model S Water Pump Part II |
06-19-2023, 11:18 AM | #1602 |
Post Whore
"Due to the thermal expansion of rubber coolant hoses, LPE does not recommend using
worm gear clamps to clamp the hoses to the intercooler pump. Because worm gear clamps do not apply constant tension to the hoses, the hoses can leak when exposed to cooler temperatures. LPE recommends the use of the OEM constant-tension clamps or spring clamps as superior alternatives to the standard worm gear clamp." |
06-19-2023, 11:21 AM | #1603 |
Post Whore
got all the hand slicers installed
06-19-2023, 11:22 AM | #1604 |
Post Whore
so tested it out with a bucket, it worked
plumbed it on the truck, it didn't work |
06-19-2023, 11:23 AM | #1605 |
Post Whore
Time to troubleshoot
of course the place that sales the 3/4" I.D. clear hose by the foot was out of the 3/4" I.D. clear hose, so off to Home Depot I went (like a fool) and instead of buying just one foot of it I had to buy a spool, at California prices mind you ! |
06-19-2023, 11:26 AM | #1606 |
Post Whore
so now we can see what is going in to the water pump as well as what is coming out... we shall call this Science !
06-19-2023, 11:31 AM | #1607 |
Post Whore
don't ask me how I got rid of that air bubble as this is a family friendly forum
Tesla Model S Water Pump Part III video |
06-19-2023, 11:47 AM | #1608 |
Congrats! Nice problem solving skills.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-19-2023, 02:13 PM | #1609 |
Now I know who took all of the worm gear clamps.
06-19-2023, 02:16 PM | #1610 |
Post Whore
06-19-2023, 08:03 PM | #1611 |
now I know where I can get 3/4 id clear hose if I need some .....
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-19-2023, 10:14 PM | #1612 |
06-20-2023, 09:28 AM | #1613 |
Post Whore
06-20-2023, 09:35 AM | #1614 |
Post Whore
with the plumbing done and the pump pumping it was time to affix the first gen Chevy Volt onboard battery
unlike it's cousin the DC DC converter the charger's feet are flat on the aluminum plate so I couldn't wedge a nut under them to hold the bolts in the plate so I had tap the aluminum plate so that I could screw them in, last thing we need is bolts falling down on a 351 volt battery pack |
06-20-2023, 09:39 AM | #1615 |
Post Whore
after two trips to ACE Hardware where I bought the wrong length bolts twice, I finally managed to get the 1 1/4" long ones that would not bottom out on the acorn nuts, cause that's what matters most here when building an electric vehicle and is time well spent
also that "water proof" battery tray lid now has more holes in it than fancy Swiss cheese Last edited by Gregski; 06-20-2023 at 09:48 AM. |
06-20-2023, 12:00 PM | #1616 |
Post Whore
had to do a little minor repair on the first gen Chevy Volt onboard battery charger, the coupling for the regular car battery cables was loose and I needed to get inside to turn the nut on it
Chevy Volt Gen 1 Onboard Battery Charger |
06-21-2023, 09:30 AM | #1617 |
Post Whore
Just took that old B&M shifter off the shelf
I hope to install it all by myself Today's aftermarket ain't got the same soul I like that old time rock 'n' roll |
06-21-2023, 09:35 AM | #1618 |
Yeah, that old part doesn't need to go into that new electric vehicle, so just send it to me.
Gonna be cool.
06-21-2023, 09:37 AM | #1619 |
Post Whore
not your father's B&M
06-21-2023, 09:41 AM | #1620 |
Post Whore
06-21-2023, 09:42 AM | #1621 |
If a check will work, it's in the mail....
06-21-2023, 09:44 AM | #1622 | |
Post Whore
“nature abhors a vacuum” |
06-21-2023, 09:51 AM | #1623 |
Post Whore
So I'm thinkin' something like this, should be totally fine as long as I can grow my right arm another 6"
06-21-2023, 09:58 AM | #1624 |
I really want to convert my C10 to an EV, as it fits my entire ethos, but this looks so incredibly daunting that there's just no way I could take it on. Very impressive MacGuyvering skills you have!
06-21-2023, 09:58 AM | #1625 |
Post Whore
a quick shave, cause you can't weld rust or paint
and a bit of gentle persuasion |
