Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-20-2006, 03:40 PM   #151
djracer
djracer's Avatar
Re: drag truck update with pics
Originally Posted by bskylerj
Looking good. When do you plan on getting back on the road or your first race. Keep the udates and pics coming.
I hope to have it running in the next 2 or 3 weeks!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-20-2006, 09:20 PM   #152
djracer
djracer's Avatar
ttt
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-20-2006, 10:07 PM   #153
409biscayne
409biscayne's Avatar
Originally Posted by 67chevemall
The phone guy! Could ya get a bigger carb, that one is pretty small....
What carb , looked like the toilet bowl The really neat thing is seeing the kid working on it as well . Thats cool
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 02-20-2006, 10:14 PM   #154
68Stepbed
68Stepbed's Avatar
Are you still running a crank trigger or did you go back with a dizzy?
Looks good. Let us know how well it runs. It's really cool to see your youngin help out. Hope mine helps me when he gets old enough. He trys to help me now but he's only three.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-21-2006, 12:34 AM   #155
djracer
djracer's Avatar
I had a fuel injection system called a flying toilet on it last time!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-21-2006, 12:36 AM   #156
djracer
djracer's Avatar
I am still running a crank trigger! I have an extra one for a bbc if anyone needs one!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-21-2006, 01:29 AM   #157
djracer
djracer's Avatar
here's my custom made plug wires and a front motor shot
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-21-2006, 01:43 AM   #158
bigjimzlll
bigjimzlll's Avatar
where'd you find glass doors?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-21-2006, 04:59 AM   #159
djracer
djracer's Avatar
creative glassworks in oneida Tn they make grave diggers body!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-21-2006, 01:35 PM   #160
djracer
djracer's Avatar
custom length plug wires labeled at each end! and a front motor shot!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-21-2006, 02:57 PM   #161
fletch4x4
fletch4x4's Avatar
No fair... But seriously thats freakin awsome!
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 02-21-2006, 11:37 PM   #162
twotons
twotons's Avatar
what thickness are you running on your engine front plate, and are you running a mid plate? i can not tell from the pic. I am putting a 66 together and was woundering about running just a front plate and how much flex there is in the chassis, although i am fully caged.
66 long bed, old engine went 10.78 @ 129mph,
this is the new 496, made 690 at the crank on the engine dyno with 92 octane.
66 Chevy P/U 1/2 ton (new best Oct 09 9.78 @ 139 w/1.3760ft)
http://i8.photobucket.com/albums/a41...erdd5d5045.gif
twotons is offline   Reply With Quote
Old 02-22-2006, 01:23 AM   #163
djracer
djracer's Avatar
I am running a 1/4 aluminum front plate and a thin steel mid plate and I am going to have two engine limiters one on each side coming from a plate mounted in the stock motor mount holes running up to a tube mounted to the frame!
Your motor sounds impressive especially on pump gas!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-22-2006, 02:04 AM   #164
twotons
twotons's Avatar
I am going to be running the new NX Gemini dual stage plate, 150 hp on the first stage and 200 to 250 on the secound stage, the truck is all steele with a fatman stainless arm manual rack frount end, with the 11 inch disc brakes. Running a Dana 60 with ramp style posi, 4 10 gears and 35 spline stange axles. I am running a hipster brake TH 400 with a 4500 stall. the truck with my not so skinny ass in it wieghs in at 4000 pounds with 10 gallons of fuel, 2 10 pound NOS bottle and batties.
Hoping the new set up runs in the mid to high 9's with a ultimate goal of 9.90 on pump 92 octane fuel.
Old 02-22-2006, 12:11 PM   #165
twotons
twotons's Avatar
What headers are you running? I am running a set of 70 Camaro Supercomps that i had to clearance the frame a bit, 2 inch primaries and 3.5 collectors. Just curious if there is something bigger in the primary i can buy that will fit without having Stan's or Lemon's build that will cost a small fotune.
Thanxs for the imfo.
Old 02-22-2006, 01:01 PM   #166
djracer
djracer's Avatar
mine are super comps for a malibu I thing they are 2 1/8 primarys!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-22-2006, 08:37 PM   #167
twotons
twotons's Avatar
sorry but what year malibu?????????
Old 02-22-2006, 09:57 PM   #168
71Dragtruck
71Dragtruck's Avatar
What you running for compression? That's a lot of NOS for pump gas!
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 02-22-2006, 10:17 PM   #169
twotons
twotons's Avatar
it is a 10.5 to 1 motor.
Old 02-22-2006, 10:54 PM   #170
Flat 67
Junior Member
Flat 67's Avatar
Dj, what kind of mastercylinder do you have and/or what is it off of? Is it hard to stop seeing how you don't have a booster? Thanks for the response.......Flat 67
Flat 67 is offline   Reply With Quote
Old 02-22-2006, 10:55 PM   #171
EyeH8the24
EyeH8the24's Avatar
awsome ride dj ...im in tallassee almost once a week ..would love to come see that ride bro ! .....maybe even take it for a shake down hehe!
EyeH8the24 is offline   Reply With Quote
Old 02-23-2006, 12:29 AM   #172
djracer
djracer's Avatar
78-87 malibu!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-23-2006, 12:32 AM   #173
djracer
djracer's Avatar
I'm not sure what the master cylinder is off of but it has drag race disc brakes on all four corners and most drag cars don't make enough vacuum for a booster!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-23-2006, 01:31 AM   #174
twotons
twotons's Avatar
the master cylinder looks like a um um um, well i think it is a Dodge car master,lol. Lots of them get used becuase of the light wieght design and larg bore for more braking power.
Old 02-23-2006, 01:40 AM   #175
bigjimzlll
bigjimzlll's Avatar
I have a strange master cylinder..1 " bore looks just like that one..hey two tons..you ought to come down to redding CA some time..we have a nice track and It would be neat to race another quick truck.
Anderson,CA
