Old 01-13-2008, 06:52 AM   #151
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: progress pics
Cool! At least you finally got it back. Can't wait to see some pics!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 01-21-2008, 10:38 AM   #152
jlaird
jlaird's Avatar
Re: progress pics
Not any progress on my end. I wanted to show these pics with the chassis put together, but I'm having some painting issues, so all my parts are not finished. So here is just the bare frame. Excuse the dust. Also are pics of my engine I just picked up from the builder. Its a 350 with summit racing vortec heads and an edelbrock intake. I'm going monday to talk with the builder about the exact specs on the internals. Last pic is a shelf of parts waiting to be used.
jlaird is offline   Reply With Quote
Old 01-21-2008, 12:57 PM   #153
Slmd92DIME
Slmd92DIME's Avatar
Re: progress pics
That motor looks really good. Nice and clean look. Good Job
Slmd92DIME is offline   Reply With Quote
Old 02-12-2008, 10:23 PM   #154
billdo
billdo's Avatar
Re: progress pics
hey i have been following your build for a while and i wanan know any one can give me input how tall is your tires for a "lay frame " truck cause im gonna do it to my 67 thanks send me pm's if possiable thanks guys
billdo is offline   Reply With Quote
Old 02-13-2008, 04:17 AM   #155
jlaird
jlaird's Avatar
Re: progress pics
about 29.5" tall
progress pics soon fellas!
Painting sucks!!!!!!
Shoulda, woulda, coulda had it powder coated!
Old 02-13-2008, 10:38 AM   #156
billdo
billdo's Avatar
Re: progress pics
let me ask another question i know u didnt z your frame thats what im gonna do but what if i zed and sectiond my engine crossmember to the point where i would have to tranny tub the cab do you thiink the motor will be to low. it was just a thought i love your set up mines gonna be a little diff but u give me ideas great build. any one could answear this
Old 02-13-2008, 11:53 AM   #157
jlaird
jlaird's Avatar
Re: progress pics
Theres no need to do both a z and a sectioned crossmember. You can lay with either one.
Old 02-13-2008, 12:37 PM   #158
Gauder the Goof
Re: progress pics
Nice build. I didn't notice anyone else comment, but I have to tell you that you are laying some nice welds.
Gauder the Goof is offline   Reply With Quote
Old 02-13-2008, 08:23 PM   #159
billdo
billdo's Avatar
Re: progress pics
not sctioni it to the point where the crossmember moves up in the frame i wanna section it to moce the motor mounts down basicaly to drop the motor into the crossmember so there is no need to tun the cab and then you can keep your stock drive line set up and your radiator will be in the same spotso you can run a fan but the front member where the pully is will have to be modified. i think it may work but may need shorth headers
i need some input and thoughts i hope you dont mind me doing this i cant start my own threads yet i need to join as a supporting member soon.
Old 02-13-2008, 10:05 PM   #160
jlaird
jlaird's Avatar
Re: progress pics
I would start your own thread with this question. You don't need to be a site supporter to start you own thread.
Old 02-18-2008, 10:48 AM   #161
billdo
billdo's Avatar
Re: progress pics
hey whats the diameter of the ring u used for ur arm mod and are u running a drop spindel
thanks
Old 02-18-2008, 09:47 PM   #162
jlaird
jlaird's Avatar
Re: progress pics
thanks
8.5" but it really depends on the diameter of the bag you are running. You just want a safe distance around the bag so it doesn't rub. Yes I am running a 3" DJM drop spindle
Old 03-09-2008, 09:03 PM   #163
billdo
billdo's Avatar
Re: progress pics
did u purchase upper control arms because ur ball joints are binding cause i did the same lower arm as u and i cant get mine to come as close ot the crossmember and i wanan know how to fix it im thiinking about pie cutting the upper to make the arm streight cause the ball joint mounts on an angle im mad confused on what to do
Old 03-09-2008, 11:55 PM   #164
jlaird
jlaird's Avatar
Re: progress pics
billdo, I'm not quite following what your saying. You can't get what close to the crossmember? The reason I got the uppers was because the cost to rebuild the stockers with new balljoints and crosshafts was reason enough to just spend a little more and get the tubulars.
Old 03-10-2008, 12:28 AM   #165
billdo
billdo's Avatar
Re: progress pics
my bad my lower control arm will not come as close to the crossmember like yours there is 3 inches or so from lower a arm to crossmember. thats all the travel i get cause my upper ball joint just stops
Old 03-10-2008, 02:50 AM   #166
jlaird
jlaird's Avatar
Re: progress pics
Oh, gotcha. What do you have going on for the lower bag mount? My crossmember is close to the lower arm because I cut bag pockets in the arm.
Old 03-10-2008, 04:35 AM   #167
bagged81
Signals in the bumper.
bagged81's Avatar
Re: progress pics
Originally Posted by jlaird View Post
What is the loop piece made from? Can you buy thicker tubing pre-bent like this? Looks good.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 03-10-2008, 05:14 AM   #168
jlaird
jlaird's Avatar
Re: progress pics
I got that from suicide doors.
http://*****************/SteelTubingBent.php
Old 03-11-2008, 04:42 AM   #169
billdo
billdo's Avatar
Re: progress pics
i know i did the same bag pocket step for step as u but my upper ball joint wont let me go as low
Old 03-11-2008, 06:29 AM   #170
jlaird
jlaird's Avatar
Re: progress pics
Did you do the crossmember section also? If not, that may be the reason.
Old 03-11-2008, 08:26 PM   #171
billdo
billdo's Avatar
Re: progress pics
that shouldnt matter because the travel should be the same you just moving the crossmember up in the frame and i zed mine.
Old 03-17-2008, 06:17 PM   #172
jlaird
jlaird's Avatar
Re: progress pics
Heres some updated pics of the front suspension:
So the only thing powdercoated is the frame. Everything else I sprayed with POR-15, then topcoated with POR Chassiscoat semi-gloss black. You can hardly tell the difference between the powder and por. Actually an average person would never know. Point being, it was a surprisingly good match.
The silver parts are POR Sterling Silver. It's a little too matte for my liking, but oh well. I'm imagining it will probably mark up easy. Here's a good view of the CPP sleeves that I clearcoated over the bare metal.
Heres a view of the new upper and lower shock mounts. I modified the lower mount and made a new upper mount for more travel and better alignment of the shock. The shocks are good ol monroes and I put poly shock bushings in.
Close up of the upper shock mount:
Super-duper cool performance online tubular engine mounts:
Manual steering box! oh yea!
Old 03-17-2008, 06:38 PM   #173
BigSky71
LAIDOUT
BigSky71's Avatar
Re: progress pics
Looks very nice, great work and attention to detail!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-17-2008, 08:25 PM   #174
Slmd92DIME
Slmd92DIME's Avatar
Re: progress pics
Looks very clean. I really like the way the por 15 turned out. I didnt know that they made it in silver though?? Great work
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Old 03-17-2008, 08:29 PM   #175
babyblueoval
babyblueoval's Avatar
Re: progress pics
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
