Old 03-14-2008, 07:37 AM   #151
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: '67 step-side replacement rear bumper
Originally Posted by kyull67 View Post
Your getting close! I'll bet you're really looking forward to that first drive.
You have no idea....
Well, wait... maybe you do
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 03-15-2008, 07:37 AM   #152
Richard8971
Today was a very good day. Got the tune-up finished on the 305 and the oil changed. I fired the motor for the first time sence December of '06. She started right up and sounds awesome! I took some time after work to dry fit the S-10 brake booster and it looks like it will be a pretty stress-free install. I should have the booster in and brakes bled by this weekend.
Hope you have a good one...
D
Sherlock Holmes
Old 03-16-2008, 10:18 AM   #153
Richard8971
I never thought I would be quoting myself but, did I say it would be a pretty stress-free install????
First off, the push rod in the S-10 booster isn't long enough to reach the brake pedal. So I dry fit the booster and put in my old push rod and measured where they would need to be cut for proper length. Sence the old rod was thicker than the new rod, I drilled a hole in the old rod to accept the S-10 booster rod. I then welded the two together and now I can safely bolt up the booster using my existing hardware... everyone got that???
Second, there are some "braces" in the firewall that are in the way of where the S-10 booster needs to bolt into... What a pain in the...
You know? My manual brakes worked just fine. What is it in us that forces us to modify, change and "improve" our belongings, esp our rides, despite the fact that it will require alot of money, time and headache from us? It just doesn't add up...
Hope you enjoy the pics....
D
PS. Did I mention my truck was running again???
Sherlock Holmes
Old 03-17-2008, 06:26 AM   #154
Richard8971
The brake lines from the master cylinder to the proportioning valve had to be remade because the fittings on my stock valve wouldn't fit into the S-10 unit.
Discovered something else fun today. Now my shift lever on the column hits the booster and won't allow it to go into park. Hmmmmm.... I didn't realize that it was going to be a problem. The steering column had to be taken out so I could get the booster bolted in...
Back to the drawing board...
D
Hey, did I mention that the truck runs???
Sherlock Holmes
Old 03-24-2008, 05:44 AM   #155
Richard8971
I got my steering column shift/power booster dilemma figured out. I cut a slit in the lower shift lever and bent it just far enough to clear the booster when the shift lever is in park. I then cut a piece of sheet metal to fill as a brace. I welded it and then checked it again for clearance. I was hanging over the radiator support and grille while I was welding. Not fun.
I also got the shift linkage in and got that all bolted up as well as the transmission cooler. I still need to bleed my brakes, they are at about 80%...
Today was a very good day. I can now move my truck in and out of the shop on it's own power. Now granted the TV cable isn't installed yet as I'm still waiting on a special Holly bracket so I can hook the throttle and TV cable up with the correct geometries. I know I can't drive it yet, but soon...
very, very soon...
Sherlock Holmes
Old 03-26-2008, 05:56 AM   #156
Dadsredwagon
Dadsredwagon's Avatar
nice write up. wish I had half your talent , great body work! do you have disc brakes up front?
thx
Dadsredwagon is offline   Reply With Quote
Old 03-26-2008, 07:24 AM   #157
Richard8971
thx
Thank you for the complements! I don't have disc brakes yet, that is a future modfication. I want to do it though, thats one reason why I went with a power brake setup.
I got the TV cable bracket today and found out something interesting...
The Holley carb I have is a 4360 (if I remember correctly) model and was a direct replacement for the quadrajet carbs on Chevrolet engines.... or so I was told from the Holley tech line...
That being said, they told me that Holley does not make a linkage mod for that carb for my 700R4. I looked at my carb closely and it does have a ball hookup at the bottom of the throttle linkage. So I thought to myself, (after being "encouraged heavily" from a good friend. Well, he basicly called me a puss for not trying it...) what do I have to loose to measure the TV cable fully extended and see if it lines up with the ball with the throttle opened wide. Sure enough it was in the correct position and when the throttle is at idle, the TV cable is fully released with no slop either direction. Does that make sence?
Hmmmm....
I ran through the list of things I still need to do to my truck.
1. Install the inner fenders
2. Take the masking tape holding the tailgate closed off and install hidden latches
3. Install the power steering lines so I can have power steering
4. Install the vacuum line to the power brakes so that they work
5. Install my stereo speakers
6. Hook up the linkage for the heater controls
7. Hook up my speedometer
8. Find out why my fuel guage isn't reading fuel in the tank
9. Find out why my temp guage isn't working
10. Bleed the brakes as they are still "squishy"
11. Install door weatherstripping so my cab doesn't leak
12. Install my seatbelts
13....
I suppose there are still more things but those are the most pressing.
I just had to do it... I had too...
I fired the truck up and drove the sucker home. God that felt so good. I had no idea how fast I was going, if my engine was running cool or hot, if I could stop safely enough if someone pulled out in front of me or if I was frying my transmission because the TV cable wasn't adjusted right...
But I got to drive it...
D
Sherlock Holmes
Old 03-26-2008, 08:04 AM   #158
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Congrats on being this Far along with your Build, I bet you were Grinning from ear to ear on the Way Home
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 03-26-2008, 09:03 AM   #159
Richard8971
Rick
Thanks Rick, and yes I was...
Sherlock Holmes
Old 03-30-2008, 09:03 PM   #160
Richard8971
No update pics yet, but I'll post some later once I get back from the shop.
I need to get down to the DMV and get new tags for the truck. I'm going to finish up on some of the little things that need to be done to the truck this weekend. Inner fenders, hooking up the booster vacuum line, figuring out why my tank guage doesn't read... those kind of things.
D
Sherlock Holmes
Old 03-31-2008, 08:07 AM   #161
Richard8971
Well I got an update on a rebuild kit for my Holley 4360 quadrajet. The closest one I could find was in Kentucky and would take 7-10 days to get to me. I'm not really into hard to find parts for my vehicles...
So I did some searching and found a lightly used Edelbrock 1409 and stuck it on the intake. I like... That was worth the hundred bucks I spent on it. At least now I can find parts if needed and they are really easy to adjust. Really made a differance in the way the truck sounds and responds.
I also got my inner fenders in and got my door weatherstripping in. I was at the salvage yard on Friday and I found a nice set out of a '98 GMC 1500 pickup. They had to be trimmed down some because they were too long, but they fit perfectly. That was 10 bucks well spent.
Progress is being made...
D
Sherlock Holmes
Old 03-31-2008, 08:39 AM   #162
toomanytoyz
Luv the Crewcabs
Truck Looking Good, Thanks for the Info on the Door Seals, I will pick up a Set for my Wrecker the Next Time i go to the junkyard................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 04-05-2008, 07:18 AM   #163
Richard8971
Ok guys, I'm gonna take Kyull67's lead and post a pic of me so you guys can put a face with the work. sad huh?
The car is a '48 Ford 2 door coupe we had just painted. The guy on the left is Fred, my business partner in the body shop. I'm the goober on the right (closest to the door)...
I'll post more pics of the progress soon, I got the power brakes working and the power steering in too!
D
Sherlock Holmes
Old 04-05-2008, 05:35 PM   #164
67ChevyRedneck
67ChevyRedneck's Avatar
Ain't you done yet?
She looks great! Can't beat orange/white with some chrome!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-07-2008, 06:19 AM   #165
Richard8971
Originally Posted by 67ChevyRedneck View Post
Ain't you done yet?
Heck no I ain't done! Will I ever be done???
I won't really be "done" until my 283 is rebuilt and installed. Everybody and thier monkey keeps telling me to build a 350. No thanks... A nicely built 283 is a strong reliable engine. In the meantime, I need to rebuild my brakes, my right rear grabs too hard (can't seem to get it adjusted correctly) and I have a leaky cylinder in the left rear brake. My transmission leaks as does my rear main oil seal on the engine. Im not in a big hurry to replace the front drums with disc brakes. Who needs to stop safely anyway?
My distribitor I believe is off a tooth. (At least according to my next-door mechanic) I can't seem to set the timing correctly. My truck is running kinda sluggish, if I retard (or advance, as the case may be) it too much, I have pep but its impossible almost to start when it's warmed up. Guess it's one or the other for now...
As much as I love the older trucks, I am often reminded of the fact that my truck is truly over 40 years old. Getting the bleed valves open on the brakes was a nightmare. I thought I was going to strip most of them or break them with as much pressure I was applying to get them to open up.
Still need to get my rims on too. I'm just waiting for them to arrive. Thanks for the complements!
Later for now, Don
Sherlock Holmes
Old 04-07-2008, 10:34 PM   #166
67ChevyRedneck
If you have a leaky left rear cylinder, and a right rear is grabbing too hard... there may be nothing wrong with the right rear, it's just that it feels like it's grabbing 'cause the left rear isn't doing much. I'd fix the left rear first and the right rear may be just fine
Jesse James
Project "On a Dime"
Old 04-08-2008, 05:32 AM   #167
Richard8971
I do believe you are correct sir... I figure I'll go ahead and replace the drums on the rear and pads (and rebuild the left brake caliper) sence they are getting old and look like they need attention. The front brakes look like they are in better shape, so I'll do those later.
D
Sherlock Holmes
Old 04-09-2008, 06:16 PM   #168
Richard8971
You guys might like this one...
I took the truck on some errands yesterday and when I came out of the hardware store a couple of older guys were outside in the parking lot discussing how nicely I redid the cab to fit a smaller rear window...
As I walked toward my truck they stopped talking and asked if it was my rig. I said yes and they complemented me on my sheetmetal work on getting a small rear window to fit...
I asked why they thought I had did a refit and one of them said, "Well, my '71 had a large back window..."
Well, you know the rest...
D
Sherlock Holmes
Old 04-09-2008, 06:27 PM   #169
kyull67
kyull67's Avatar
Silly regular people. I've had several people say things like, "Hey that's a nice '74 pickup you've got there." And then argue with me about what year it really is!?
kyull67 is offline   Reply With Quote
Old 04-09-2008, 11:31 PM   #170
70rs/ss
70rs/ss's Avatar
I caught the S-10 booster, just wondering why you didn't use a 71-72 power booster? Is the s-10 better? The reason I ask is that the non power brake boosters and power boosters are a direct bolt up (one for the other with no issues), I put one in Rick's (toomanytoyz's) truck and bolted on with no issues with the rod or the auto linkage? I know a little late, but just wondering, if the s-10 is better as I am doing my 2wd Blazer after the 67 is gone.
70rs/ss is offline   Reply With Quote
Old 04-10-2008, 05:54 AM   #171
Richard8971
Well, thinking back, maybe I should have gotten a booster out of a 71-72... lol
The reason (so I was told) to go with an S-10 booster is that they require very little vacuum to operate correctly. That and it was given to me... free is always a good reason to use a part.
All in all, it wasn't that bad of an install, but a direct bolt up would have been sweet as well.
Don
Sherlock Holmes
Old 04-10-2008, 09:19 AM   #172
Richard8971
Gonna park the truck for a spell while I work on getting the small stuff done...
I'll post new pics as I can...
D
Sherlock Holmes
Old 04-10-2008, 05:27 PM   #173
67ChevyRedneck
D
I like this post better than what it originally said
Jesse James
Project "On a Dime"
Old 04-10-2008, 05:30 PM   #174
toomanytoyz
Luv the Crewcabs
That Make's 2 of Us..............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 04-10-2008, 11:32 PM   #175
Richard8971
Thanks guys, steps are being taken to avoid that. I felt it was best to take that post down until I knew for sure what I needed to do.
D
Sherlock Holmes
