Old 01-25-2010, 12:20 AM   #151
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: I wana drive 65.
Heck I would ride this short bus.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-25-2010, 12:24 AM   #152
70 Suburban
Rods
im sure you would.....
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-26-2010, 09:53 AM   #153
70 Suburban
Rods
picked up my motor plates.... local shop cut them for me cheap I hope they work with factory a/c braket if not then ill make somthin happen. If its not to cold I will start on the engine swap. However i did look at the dash and I think i can use the 64-66. I kinda like the way it looks when the stuff is test fit.
Old 02-10-2010, 03:59 PM   #154
Tazfink
Tazfink's Avatar
Subscribed!!!!
Tazfink is offline   Reply With Quote
Old 02-10-2010, 05:54 PM   #155
70 Suburban
Rods
So the engine is in the frame. Started the wiring. I will be using all factory wiring (08) i want to use the auto dimming lights and daytime runnginlights ect. I also am installing the 08 colomn in there too. Looks and feels great. Only problem i have is with the brake pedal in the way. I think i can shift the colomn just off center to compinsate for it and still look good. If not the i will do somthin to the pedal shaft. I am using the 72 booster mount for now untill i can see what else will work.. Btw the stock booster and brackets are for sale.
Old 02-11-2010, 12:29 AM   #156
highperf4x4
How can you set the colum off center? Takes lots of pics as you go!
highperf4x4 is offline   Reply With Quote
Old 02-11-2010, 12:38 AM   #157
70 Suburban
Rods
I have the cross brace from the 08 I am goin to cut off the colomn mount and build a bracket.
Old 02-11-2010, 01:06 PM   #158
my67chevytruck
Under Construction
my67chevytruck's Avatar
sounds like your making some good progress. keep at it.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-11-2010, 01:09 PM   #159
70 Suburban
Rods
Its slow. I want to get the frame streeeetched soon.
Old 02-11-2010, 08:50 PM   #160
highperf4x4
Me too! Let's git-r-done!
Old 02-11-2010, 09:01 PM   #161
70 Suburban
Rods
i will be looking at using another frame that I have. if so then I will be starting on this asap. line next weekend I will be stretching it if not then I will have to just get the drive shaft made up and start driving it
Old 02-11-2010, 09:57 PM   #162
70 Suburban
Rods
here is a small update.. engine in. wiring started. colomn simi mounted. dash kinda in place
Old 02-11-2010, 10:14 PM   #163
DPowers
DPowers's Avatar
Looks good- how much firewall clearance you gonna have?
DPowers is offline   Reply With Quote
Old 02-11-2010, 10:17 PM   #164
70 Suburban
Rods
lots. about 4+ inches
Old 02-11-2010, 10:24 PM   #165
70 Suburban
Rods
there is alot to use on the original harness. like the headlight switch dash switch. not sure how the brake lites know when to come on yet. I found out that the fuep pumpharness goes into the abs/roll over control to turn the pump off.. well i cut all that out so I will have to rewire some stuff...im not so sure i want to use the a/c now because it so damn big. but i like the factory dual climate option... any ideas.
Old 02-11-2010, 10:39 PM   #166
DPowers
DPowers's Avatar
Maybe it won't be as noticeable once everything is in place and buttoned up??
Old 02-11-2010, 10:42 PM   #167
70 Suburban
Rods
true i was thinkin of moving my whole dash forward
Old 02-12-2010, 01:11 AM   #168
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I can't help with electronics, but I can set back and watch this come together. Thinking out of the box. Awesome job!!
Alan's Classic is offline   Reply With Quote
Old 02-12-2010, 08:46 AM   #169
70 Suburban
Rods
Thanks alan your build has been an insperation for ideas here..
Old 02-12-2010, 10:10 AM   #170
283 Man
283 Man's Avatar
Thumbs up Re: I wana drive 65.
nice build!!!!
283 the mighty small block
283 Man is offline   Reply With Quote
Old 02-12-2010, 10:41 AM   #171
70 Suburban
Rods
thanks I hope to have some real progress for yall
Old 02-12-2010, 10:58 AM   #172
Chevy Fleetside
Chevy Fleetside's Avatar
I had an 88 Suburban that I cut up and scrapped. I noticed that the frame is straight and lonnnnnng. Maybe if you come across one you can use that frame instead of making yours longer. Just a thought. Looks like you might have to much time into the one you have going anyway.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-12-2010, 11:03 AM   #173
70 Suburban
Rods
i have a 91 sub but I think it would take more little modifing then it would be just to use my extra frame and just reattatch the back half. I want to use the factory cab mounts for the extended cab.
Old 02-13-2010, 02:56 AM   #174
Captainfab
60-66 Nut
I would stay with the older frames.......it would be easier IMO.
Old 02-13-2010, 08:55 PM   #175
DPowers
DPowers's Avatar
Agree
