Old 11-17-2009, 02:41 PM   #151
AJs72K5
AJs72K5's Avatar
Re: Project: Agent Orange
Originally Posted by Wildstreak View Post
Do ya think using the taller adapter will cause any motor angle problems? I have a 700r4-np208 and dont really like the low adapter either but worry that swapping to the tall adapter might screw with the drive-line angles....
No worries. I'm running the tall adapter with a 700/241 on the factory crossmember. The tall adapter with the factory crossmember and tranny mounts is roughly the same height as the short adapter with the spacer/mount on the crossmember VT had pictured previously. My front driveshaft is actually 2" longer than my rear. I'm running CVs front and rear now.
Bottom line, what the tall adapter gives you is the use of your factory crossmember(s) and tranny mounts.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 11-17-2009, 06:56 PM   #152
Wildstreak
"something witty here"
Wildstreak's Avatar
Thanks AJ
whats a good price to pay for one of these tall thin adapters? I found one but I just wanna make sure Im not goin to pay too much for it. I like this adapter more, it gives way more ground clearance I would think compared to the other crossmember style.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 11-17-2009, 07:06 PM   #153
vtblazer
vtblazer's Avatar
I just picked up the one in the pic for $65.00 shipped, thanks to AJ's heads up and provided link.
vtblazer is offline   Reply With Quote
Old 11-17-2009, 08:44 PM   #154
AJs72K5
AJs72K5's Avatar
Nice score, fo sho. I managed to get mine cheaper...but, I've seen them listed on ebay for as high as $150.
- AJ
Old 11-17-2009, 09:30 PM   #155
Wildstreak
Wildstreak's Avatar
$65 wow thats a damn good deal, 150 seems to be the usual price Ive found on a few sites....
57 chevy 4x4
68 burb 2wd:
Old 11-20-2009, 08:55 AM   #156
vtblazer
vtblazer's Avatar
Clocking ring ordered from DIY.
Currently also working on cage mock up.
Old 11-20-2009, 12:12 PM   #157
Wildstreak
Wildstreak's Avatar
well this may be a dumb question, but what is that for?
57 chevy 4x4
68 burb 2wd:
Old 11-20-2009, 12:24 PM   #158
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Looking forward to pics.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 11-20-2009, 12:27 PM   #159
AJs72K5
AJs72K5's Avatar
Mine showed up yesterday.
It's called a clocking ring. It's for either a 241 or a 208 transfer case. It allows you to rotate (clock) the transfer case up to give you more ground clearance.
Not a great pic, cuz of the exhaust pipe in the way. But, here's the before:
And the after with the clocking ring installed, rotated up to the first hole, You can see the case is completely above the exhaust pipe now...but more importantly, the bottom of the case is just above the bottom of the crossmember now.
- AJ
Old 11-20-2009, 01:02 PM   #160
Wildstreak
Wildstreak's Avatar
well that there solves a question that has been in the back of my head for a week now lol. I really didnt like how my 208 was so much lower and wanted to do this from the start. Now that Im taking it apart for that tall adapter I should look into one of the kits as well. Are they easy to install?
57 chevy 4x4
68 burb 2wd:
Old 11-20-2009, 01:15 PM   #161
AJs72K5
AJs72K5's Avatar
The first time I did mine, it took me an hour to remove the case, install the ring, and rehang the case.
When put it on, make sure you use RTV on both the case and the adapter side. Additionally, use RTV on the threads of the studs and the holes that you don't use on the ring to ensure you don't get any leaks.
- AJ
Old 11-23-2009, 02:05 AM   #162
Wildstreak
Wildstreak's Avatar
Im going to have an 8" lift most likely, do you think there would be driveshaft angle problems if I use the clocking ring to raise my transfer? what are you using for lift vt and aj?
57 chevy 4x4
68 burb 2wd:
Old 11-26-2009, 10:47 AM   #163
vtblazer
vtblazer's Avatar
Received both my tall adaptor & clocking ring on Wednesday, perfect timing heading into a long weekend.
Pics clearly show that the motor 'is' in the stock location and it was just the tall valve covers making thing's look tight.
Now I need to decide whether to move the engine forward or just re-drill new holes in the frame for the tranny cross member.
I think the next 'diagnostic' step is to trial fit the dizzy, if that goes in easily and has enough clearance with the cap on it, I'll leave the engine where it currently sits, if not the whole assembly will get moved forward.
Happy turkey day folks, enjoy!
Old 11-26-2009, 12:11 PM   #164
Big J
Its lookin' like a Blazer!
Big J's Avatar
Lookin' good Kurt. Unless you adjusted the firewall behind the dizzy with a hammer we know its gonna be tight. I guess its a question of paper tight or credit card tight, lol. I adjusted mine before painting, lol. Its got wonderful clearance and because of the filler and sanding you'd never know it. Be careful, have fun and don't smash any fingers.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 11-26-2009, 12:33 PM   #165
vtblazer
vtblazer's Avatar
More room than expected...seen worse.
Valve covers are decent to get off too.
The tightest area is definetly the pass. side valve cover.
Thing's might settle a bit when I actually weight the cross member mounts and that would make the dizzy even closer, maybe the safest thing to do is just move the engine up.
Old 11-26-2009, 12:36 PM   #166
Big J
Big J's Avatar
It may be better to just move it up like ya said. Don't know for sure but maybe it could touch when you get it all twisted up. That is nice clearance on the dizzy.
BAZINGA!
My Build
Old 11-26-2009, 01:05 PM   #167
AJs72K5
AJs72K5's Avatar
If you leave the engine in the stock location, the tranny crossmember would have to be moved ~2.5". Why not move the engine forward 1", which would give you plenty of clearance, and then move the tranny crossmember back the difference?
- AJ
Old 11-26-2009, 01:09 PM   #168
vtblazer
vtblazer's Avatar
...cause I only wanna have to drill 4 holes, not 8.
Kidding, thanks though, it's certainly an option and a good one too.
Old 11-26-2009, 03:12 PM   #169
Jtrux
I'm a poor spectator
Jtrux's Avatar
Yeah with my HEI you could fit a credit card between the cap and firewall, it was tight.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-26-2009, 07:33 PM   #170
vtblazer
vtblazer's Avatar
Everything moved forward 2.5"s.
Not the perfect solution but now I know what it makes for room.
T-case lever hits the floor x-member support, need to pull the t-case back out and find out if I can index it, if not maybe shortening it is the answer.
*Note in these pics that the transmission cross member is in the stock location, everthing has been moved 2.5"s forward as the 700r mandates.
Somewhere in between should work good, hoping to align it so the drive shafts end up being the same length.
Old 11-26-2009, 09:41 PM   #171
vtblazer
vtblazer's Avatar
Looks like only moving it forward 1" does the trick.
Makes a ton of room around the engine/dizzy/valve covers.
Still leaves 5.5"s between the water pump & the fans.
Allows me to leave it clocked up in the #2 position, although a wee bit of clearancing on the floor needs to happen.
Even clocked up the most it will go, the 241 still hangs 2.5" below the frame rail though.
This position also allows for both drive shafts to be almost equal, meaning I'll need only three.
Two to run & the third as the spare which will then fit either end.
The shift lever will need to get shorter too.
Old 11-26-2009, 11:12 PM   #172
Big J
Big J's Avatar
Glad you've got it worked out. Can't wait to get back to work on mine.
BAZINGA!
My Build
Old 11-27-2009, 06:45 AM   #173
swyfor5
swyfor5's Avatar
Kurt, those are some awesome pic's! Looking good!
swyfor5 is offline   Reply With Quote
Old 11-27-2009, 09:28 AM   #174
Thealien
Thealien's Avatar
Thanks for the pics, you've been busy!
Looking forward to some similar "fun"
Old 12-11-2009, 09:24 PM   #175
litebulblsc
litebulblsc's Avatar
Found this on page 3, any updates?
litebulblsc is offline   Reply With Quote
