Old 05-03-2010, 11:25 PM   #151
highperf4x4
Re: Chucks SWB Fleetside
Can you tell me how the wiring will connect? Do you just run one wire to the tach connector on the HEI cap and one ground? And if so, do you know how accurate it will be?
highperf4x4 is offline   Reply With Quote
Old 05-04-2010, 11:38 PM   #152
thelonerife
thelonerife's Avatar
Somebody can correct me if I'm wrong but the connector that goes on the back of the tach has two terminal connections. One is power and the other connects to the dist. The terminal that is going to the dist. can be changed to fit an hei easily.
thelonerife is offline   Reply With Quote
Old 05-04-2010, 11:45 PM   #153
highperf4x4
Thanks. I'll be watching how yours turns out.
Old 05-08-2010, 12:03 AM   #154
thelonerife
I got the tranny crossmember in today, and the frame bracket is dry now. I've started painting the a arms and should finish up with those tomorrow.
Old 05-08-2010, 12:09 AM   #155
VA72C10
VA72C10
VA72C10's Avatar
Looking good. keep at it!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-08-2010, 12:30 AM   #156
highperf4x4
Looks great!
Old 05-08-2010, 11:18 PM   #157
thelonerife
Thanks Guys. Your comments are appreciated! I put in the tranny crossmember and the frame linkage bracket. The arms are done and are waiting for the crossmember to be mounted. Its a job cleaning that thing.I put in an order for drop spindles and they are backordered 2 weeks. I bought some grade 8 bolts and still need some more. Good excuse to go to Lowes.
Old 05-08-2010, 11:22 PM   #158
VA72C10
VA72C10
VA72C10's Avatar
Looking good. Yeah, it does take time...I had 70 hours in my frame...but it's a good payoff when it's done and together.
I think I spent well over $100 at lowes on Grade 8 stuff...no tractor supply or northern tools that close to me...
Old 05-09-2010, 01:18 AM   #159
highperf4x4
Looks great. You make it look awful easy. I haven't done a frame off yet so I'm keeping a close watch. Make it look easy for me!
I like the way you think!
Old 05-09-2010, 12:18 PM   #160
texastrendz
i have been following your build for a while and have a question. what paint are you using on you frame? i see that is looks like red oxide primer you are using, are you sanding the red oxide before to coat? or are you just spraying it. thanks. looking good so far.
texastrendz is offline   Reply With Quote
Old 05-09-2010, 04:56 PM   #161
thelonerife
I am using rustoleum rusty metal primer. Its great to fill with and if you take your time and prep it good it lasts.I am wet sanding it then painting gloss black on it. It will dull down to a semi gloss or satin finish after a while which is what I want. Thanks for following and ask again if you have anymore questions.
Old 05-09-2010, 10:45 PM   #162
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
just read the whole thread. great work!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-10-2010, 11:05 PM   #163
thelonerife
I got the 2''drop springs in today. I still am waiting for the drop spindles from ECE. They are back ordered. I got the front crossmember on and all bolted up. I also got in a nos license plate bracket for no bumper trucks.
Old 05-10-2010, 11:06 PM   #164
thelonerife
more
Old 05-10-2010, 11:17 PM   #165
highperf4x4
You sir................ are making that stuff.................... look good.
Old 05-11-2010, 11:45 PM   #166
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
awesome build
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-16-2010, 01:33 PM   #167
thelonerife
Thanks guys, I took the rear bumpstops off and the rear shock mounts.. I need to get the rear springs off and the original panhard bar. I ordered a c notch kit for it off ebay for 97 shipped. I need to order some more stuff next week from ECE.
Old 05-16-2010, 02:12 PM   #168
faribran
do you have a spare short, fleet bed.. or do u know someone in your area that does?
faribran is offline   Reply With Quote
Old 05-16-2010, 02:56 PM   #169
thelonerife
Just Southernc10 with the step bed
Old 05-16-2010, 03:58 PM   #170
thelonerife
He just called and said he sold it a few minutes ago.
Old 05-16-2010, 04:58 PM   #171
DPowers
DPowers's Avatar
Lookin good Chuck- can't wait too see it in person.
DPowers is offline   Reply With Quote
Old 05-16-2010, 06:11 PM   #172
68GMCCustom
I'm waiting on b/o ECE drop spindles too..along with a few other things. Hopefully not too much longer tho.
Kurt -
Old 05-16-2010, 07:11 PM   #173
thelonerife
Looks like they would step up production a bit. Their going to lose business if people want to take another brand. I don't.
Old 05-16-2010, 10:36 PM   #174
68GMCCustom
they offer western chassis spindles if you need them now...but I don't know that co. well enough, so I'll stay with the one I have heard good things about.
Kurt -
Old 05-16-2010, 11:53 PM   #175
thelonerife
thats me too.
