Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 11-24-2011, 11:00 PM   #151
Captainfab
60-66 Nut
Re: Camaro Caliper Brackets
No sorry they won't. The backing plate flange bolt pattern is different as well as the brake offset.
Originally Posted by derek6787 View Post
Will these work on the 88-98 truck 10 bolt?
Old 12-21-2011, 06:34 PM   #152
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Originally Posted by Captainfab View Post
I'll see about getting a Camaro e-brake cable, and hopefully I can find time to get something figured out for you guys.
Any updates?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 12-22-2011, 12:19 AM   #153
Captainfab
60-66 Nut
Well, yes and no. I didn't have luck finding one local, but I did find one on ebay. I just got busy and haven't bought it yet. I will do that soon.
Originally Posted by 71meangreenc10 View Post
Any updates?
Smitty
Old 12-23-2011, 12:15 AM   #154
Captainfab
60-66 Nut
I got a pair of e-brake cables ordered today. I should have them late next week.
Old 12-27-2011, 10:42 PM   #155
71meangreenc10
Good deal.
Smitty
71 C30 Wrecker
Old 01-08-2012, 05:09 PM   #156
71meangreenc10
Well,
I picked one up at AZ, and its not plug and play.......will have to figure something out to make this work.
If you figure something out let me know.....
Smitty
71 C30 Wrecker
Old 01-09-2012, 12:24 AM   #157
Captainfab
60-66 Nut
I got mine last week, but I just haven't had time to do anything with it. Maybe sometime this week.
Did you happen to measure how much too short it is?
Well,
Smitty
Old 01-09-2012, 05:14 PM   #158
71meangreenc10
I can. Give me a few days.
Smitty
71 C30 Wrecker
Old 02-02-2012, 11:29 AM   #159
D13
D13's Avatar
The images I can find show the Camaro units mount on the front, 9 o'clock. The bleeder is then at the top. The ebrake cable then would come out in front of the axle and off the bottom, and take a cross car pull. Is that what the brackets are set up for? This looks like it would work well with stock springs but have issues with a flip kit. Anyone tried it either way? Any particular reason the calipers cound not be put on the other side at the 3 o'clock?
Some store calipers have the ebrake lever, some have the bracket and the lever, and some have none. The bracket and lever are quite expensive seperately.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-02-2012, 11:50 PM   #160
Captainfab
60-66 Nut
These brackets can be used to position the caliper either on the front side of the differential or the back side at the 2 O'clock and 10 O'clock position.
Old 02-10-2012, 11:35 PM   #161
Nova_Cobra64
Nova_Cobra64's Avatar
The parking brake cable setup is something I've had on the backburner for quite some time. I'm going to be digging the welder out tomorrow and building myself some sort of bracket setup to mount the camaro park brake cable. It might not end up being pretty, but I'll post the result.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 02-11-2012, 12:57 AM   #162
Captainfab
60-66 Nut
Sorry I haven't got to this yet guys, just been really busy. Hopefully soon.
Old 02-11-2012, 09:06 PM   #163
Nova_Cobra64
Ok here is what I came up with, I'm quite happy with the result:
http://www.flickr.com/photos/1711832...7629278025503/
I started with 1 1/2" angle iron, 1/8" thick. 1 3/4" or 2" would have worked better but I was making use of what I had. I cut a piece approximately 2" and clearanced it and drilled 2 holes so it would match up to where the factory brackets would go. Then I had to make a 3/4" extension for a bit more room (which is why the larger angle iron would work better). From there I cut a piece approximately 3 3/4" and welded it to the smaller piece, drilled a hole for the cable and chopped off the excess and smoothed it out a bit. Then to make a return spring I used a brake shoe hold down spring from a box of spare parts, chopped a small piece of rod (close to the ID of the spring) and angle iron about 1/4" wider. I drilled a hole in the angle iron, slightly smaller than the rod and welded the rod to it from the back side then welded the angle iron to the bracket. It is a bit tough to put in to words so hopefully the pictures help. With the caliper mounted on the rear position with the parking brake lever facing up, the camaro e-brake cables can come down on the outside of the trailing arm, and should be able to use the factory brackets. I still have to make new brackets for the trailing arm (mine were buggered up), but it looks like this should work out perfectly. Making the first bracket took me about an hour and a half with all the figuring, the second took about 10 minutes. Brake shoe springs are easy to come by, and I probably used $2 worth of angle iron. As long as a person has access to a welder and an angle grinder it's a pretty easy solution.
Old 02-12-2012, 12:23 AM   #164
Captainfab
60-66 Nut
Nice job
I did not realize that you were in need of a replacement for the factory bracket that holds the end of the cable. I have a set of Camaro calipers that have the factory bracket that I could duplicate if that is something that is needed. I just assumed that everyone had that bracket.
Old 02-12-2012, 10:42 AM   #165
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Nice work on the bracket however I notice in the last picture you have the caliper mounted upside down. The bleeder screw has to be on top of the caliper!
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 02-12-2012, 11:15 AM   #166
Nova_Cobra64
Good eye. I wasn't sure if they had to be mounted a specific way or not, that was going to be today's research project so you made it easy for me. I started thinking it would be better to mount them with the ebrake lever down so they wouldn't be as visible through the wheels. It might create a bit more slack in the cable but I'll update on the results.
Old 02-12-2012, 10:53 PM   #167
Nova_Cobra64
Ok, I swapped the calipers from side to side, bleeder up, parking brake lever facing down. Made brackets and mounted the cables then mocked up the intermediate cable. I think ideally it would be best to find a shorter cable with the same type of ends. There is probably 10-12" of slack in the position I have them in, if the calipers were mounted in the forward position you could probably go 16" shorter. The camaro cables will work, but going shorter would allow for a cleaner install. Pics have been added to my flickr (link in earlier post).
Old 02-12-2012, 11:44 PM   #168
Captainfab
60-66 Nut
Hmmmm. From what other members have said, I was under the impression the Camaro cables were too short. It might be easier to shorten the intermediate cable to accomodate the Camaro cables.
Old 02-17-2012, 12:04 PM   #169
68 Four on the Floor
68 Four on the Floor's Avatar
I'd like to order a set of these. Paypal coming your way...
68 Four on the Floor is offline   Reply With Quote
Old 02-18-2012, 12:34 AM   #170
Captainfab
60-66 Nut
Your payment has been received. Your caliper brackets will ship tomorrow. Thanks
Old 02-18-2012, 04:51 PM   #171
71meangreenc10
If you use the factory connector on the trailing arm to mount the cable and the factory caliper brackets for the calipers, then the cable itself is long enough, but the crimping of the outer skin makes the cable too short, I am almost to the point of mounting everything up, then Ill take some pics. As mentioned the whole cable assy itself is pretty long, youll just have to see it to see what I am talking about.
Ill take the factory PB mounting brackets if you want to get rid of them...
Smitty
71 C30 Wrecker
Old 02-18-2012, 04:54 PM   #172
71meangreenc10
You cables will have a better chance because you fabbed up a different cable mount to the trailing arm, did you mount the cable mount in the factory location? But you are correct that the camaro cables have alot of slack as a whole unit....
Smitty
71 C30 Wrecker
Old 02-19-2012, 12:23 AM   #173
Captainfab
60-66 Nut
I still haven't had time to even look at this. Just been way to busy working 7 days a week.
I think I will hang on to the factory cable bracket, in case I need to start making them.
Smitty
Old 02-21-2012, 09:01 PM   #174
Got my brackets today. Everything looks great cant wait to install. Will post pics when thats done.
Old 03-19-2012, 02:33 PM   #175
rocknss
rocknss's Avatar
Captainfab,
I would like to order a set if you have any available.
Thanks,
Steven
rocknss is offline   Reply With Quote
