Old 03-12-2011, 03:15 PM   #151
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Finally starting the 68swb fleet
subscribed
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-12-2011, 04:03 PM   #152
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Originally Posted by Seventy Two View Post
Nice build. I'm in!
Look at you guys all jumpin in to the build, looks like I better get my butt in gear and get back in the garage a bit, forecast for weather is warming up, but the snow twists my rubber sled arm, I'll try and atleast get the front suspension in next week
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-04-2011, 10:12 PM   #153
spike38
spike38's Avatar
You getting motivated yet?
Or still having too much fun.
Spike
spike38 is offline   Reply With Quote
Old 06-04-2011, 10:27 PM   #154
tantrumpipeline
I am actually replacing some parts on my work truck tomorrow and then I have 2 weeks to get my driveway clear or the city is going to fine me and remove my cabs and parts outta the driveway so should be a rolling chassis to some degree, going to grind and paint my trailing arms tomorrow evening
20 Duramax tow pig
52 short project
Old 06-04-2011, 11:24 PM   #155
spike38
spike38's Avatar
Trust me, Sometimes a kick in the a$$ is a good thing
Looking forward to your updates
Spike
Old 06-05-2011, 01:49 AM   #156
tantrumpipeline
I am way behind you now, but it's motivation and I am able to bug you for info on steps
20 Duramax tow pig
52 short project
Old 06-05-2011, 09:13 AM   #157
spike38
spike38's Avatar
I'll help anyway I can. And besides, It's not a race.
It's just a matter of enjoying the journey.
Spike
Old 06-06-2011, 12:49 AM   #158
tantrumpipeline
For sure racing isn't how I want to do this build. I spent a good hour grinding on the trailing arms and something let loose in my garage lost all power so I'll be back at it tomorrow after my electrician come over, hoping its just a short in my extension cord or something simple, either way I have more outlets than just the garage There's a lot of grinding to be done after welding the braces so I'm hoping to get some paint on them tomorrow night and install the steering components, grind my rotors for the 338's and paint the steering box, I'll post pics of the progress if the weather is nice enough
20 Duramax tow pig
52 short project
Old 06-07-2011, 11:56 PM   #159
DCoffey
DCoffey's Avatar
Hey, if you are looking to change direction a little i got a line on some stuff. I know its a little late because you have done so much **** to your frame but I am throwing this out for you, a swb porterbuilt dropmember frame as a roller, assembled for $4500 and add 12" willwood front and rears for another $1000. That all the bags, crossmembers, rack and pinion, steering components, spindles, all put together and painted. In Calgary. All the stuff is from porterbuilt fabrication, my order was over $6000. Would also save you on grinding rotors possibly.
67' Shortbox build thread:http://67-72chevytrucks.com/vboard/s...=1#post4281123
DCoffey is offline   Reply With Quote
Old 06-08-2011, 12:19 AM   #160
tantrumpipeline
I wish I had the spare cash for it and I would definitely be in for that, I do have another 2 buddies just kicking off a 69 and a 72 both are LWB so I'll run it by them, save them hacking a frame to fit and that's a sweet deal. How's your build coming? Trying to keep at mine but work's taking off again, atleast we have light til after 11 outside and other than the snow a few days ago it's perfect for working in the driveway
20 Duramax tow pig
52 short project
Old 06-09-2011, 01:35 AM   #161
tantrumpipeline
nothing major, work has picked up so after the gym it's hard to stay motivated. After a bit of ginding, some preventative rust converter, primer and paint they're ready for installation hopefully tomorrow. Also began the box teardown, only one box side worth saving but that was understood when it was purchased
20 Duramax tow pig
52 short project
Old 06-09-2011, 02:19 AM   #162
spike38
spike38's Avatar
Trailing arms look great!!
Spike
Old 06-10-2011, 02:19 AM   #163
tantrumpipeline
Thanks, I put another coat of black on them tonight and started some work space clean up, may coat them in silver to match the steering components though haha, may accent nice with the rest of the silver, hoping for some better updates next week on my days off. Ordering my needed passenger fender and poly body mounts tomorrow.
20 Duramax tow pig
52 short project
Old 06-15-2011, 01:17 AM   #164
tantrumpipeline
Nothing overly major to update, installed the rear suspension as a mock up, not sure if I installed the rear spring retainers correctly? trailing arm and lower retainer bolts are 3/4in too short so tomorrow I'll try and get off work early enough to get to the fastener store, get my rotors machined at the brake shop, and pick up some paint to coat up the remaining steering components. Also installed the cpp transmission mount loose, had to get the box off the floor and outta the way sorry about the lack of pics I'm having computer issues, unsure how to make them 100kb from 1.8mb I also ordered my fender in and received my body mounts
20 Duramax tow pig
52 short project
Old 06-15-2011, 01:33 AM   #165
tantrumpipeline
pics of the disaster in progress bolts are offically my nemesis
20 Duramax tow pig
52 short project
Old 06-15-2011, 05:47 AM   #166
spike38
spike38's Avatar
Looking like progress!!!
Spike
Old 06-15-2011, 11:40 AM   #167
tantrumpipeline
Little bit I need to get off early to get the rotors machined and get the fasteners but with any luck today or tomorrow that'll be done
20 Duramax tow pig
52 short project
Old 06-17-2011, 12:36 AM   #168
tantrumpipeline
rotors are machined, best $40 I've spent in awhile, way nicer look than the grinding I would have pulled off Tomorrow I should have the steering box and components in, front brakes and wheels and hopefully the cab on
20 Duramax tow pig
52 short project
Old 06-17-2011, 12:49 AM   #169
trukzguy
trukzguy's Avatar
Lookin good,keep it up.
Jay
Barrhead,Alberta,Canada
1967 GMC 400sb
Porterbuilt stage 2 front and rear suspension
http://67-72chevytrucks.com/vboard/s...d.php?t=419519
trukzguy is offline   Reply With Quote
Old 06-17-2011, 01:33 AM   #170
VA72C10
VA72C10
VA72C10's Avatar
Nice progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-17-2011, 01:39 AM   #171
tantrumpipeline
thanks guys, I'll try and get better pics tomorrow in the garage, as it comes together
20 Duramax tow pig
52 short project
Old 06-17-2011, 01:58 AM   #172
alwaysbroken
frame looks great!
chevys the way to go.
alwaysbroken is offline   Reply With Quote
Old 06-17-2011, 02:02 AM   #173
spike38
spike38's Avatar
Looks good man!
I love the before and after of each piece.
Spike
Old 06-19-2011, 11:15 PM   #174
tantrumpipeline
started in on the steering and front end, CPP shipped the wrong tie rod sleeves and the tire shop the wrong lug nuts, not a major, installed the steering box and started with the rest of the steering, hoping I can find the stock sleeves in my scrap pile tomorrow and should have lug nuts tomorrow, I will post pics of the chassis tomorrow, with any luck the cab will be temporarily on as well
20 Duramax tow pig
52 short project
Old 06-20-2011, 01:13 AM   #175
David67
David67's Avatar
Everything's looking really nice. I loved puting my cab back on. Temporary or not, it's a good source of motivation to see it start to look like a truck.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
