Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-01-2011, 07:09 PM   #151
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: 1973 K20 Build Thread
Then I removed the spindle bearings. You are going to need a long punch or drift. I used my Gorilla pry bar and hammer. It fits in the spindle perfectly. I tapped out the bearings with a small hammer, being careful not to scratch the surfaces.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-01-2011, 07:16 PM   #152
TheWhiteElephant
God is good!
After I painted the exposed spindle surfaces, I installed the new bearings. I got mine from Superior Axle in a kit with the spindle seals...
I had to use a block of wood, a dead blow hammer, the old spindle bearing, and finally a socket to install the new bearings...
I also applied a light coat of bearing grease on the surface to help things a bit.
Mando
Old 06-01-2011, 07:36 PM   #153
TheWhiteElephant
God is good!
Then I painted the backing plates. I also had the spot welds on them re-welded prior to painting them because they had cracked.
Be sure to put the new washer in with the chamfered side facing inside...
Mando
Old 06-01-2011, 07:42 PM   #154
TheWhiteElephant
God is good!
Then I sprayed the hubs with high heat Rustoleum...
I didn't want to go out and have the studs pressed into the new rotors, so after tapping them in from underneath, I finished them off like this. I used several washers so that I wouldn't have to thread the lug nut too far. I also smeared some anti-seize between the hub and rotor.
I used a rented bearing/seal installer and installed the inner bearing cup into the hub. Here are the correct part numbers for the outer bearing, inner bearing, inner bearing race/cup, and inner bearing seal from top to bottom.
Mando
Old 06-01-2011, 08:33 PM   #155
TheWhiteElephant
God is good!
Then I packed the inner bearing with grease, installed it into the hub, and then pressed the inner bearing seal with a block of wood.
Then I attempted to slide the rotor and hub assemblies onto the spindles for the next 2 hours and cussed myself silly. They just wouldn't go in. I damaged both seals before I finally gave up in defeat.
The next day I went out and bought National seals instead of the "Made in Indonesia" Timkens. The Nationals are made in the USA. By no means am I blaming the seals, but it was actually a blessing in disguise because you can see the huge difference in quality. The side shown is the part that faces inside...
Here was the fix. DO NOT SKIP THIS STEP!!! I polished the surfaces that the inner bearings ride on with 220 grit emery paper.
This made all the difference in the world. Unbelievable how the slightest bur can cause all sorts of headaches. The assemblies slid right in...
Mando
Old 06-01-2011, 08:50 PM   #156
TheWhiteElephant
God is good!
Then I sprayed the calipers with caliper paint before installing them and torquing them to the proper values...
Mando
Old 06-01-2011, 11:34 PM   #157
MTCK
MTCK's Avatar
Great pics and write up! I love the stance now! How is the ride?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-02-2011, 12:17 AM   #158
67chevy1series
67chevy1series's Avatar
nice build!!!!!!!!!!!!!!!!
67chevy1series is offline   Reply With Quote
Old 06-02-2011, 06:38 PM   #159
bharrison1
bharrison1's Avatar
Great job thanks for the info!!
bharrison1 is offline   Reply With Quote
Old 06-02-2011, 11:12 PM   #160
TheWhiteElephant
God is good!
Thanks! I've always liked the look of the old Ford High Boys and wanted a similar look. I haven't driven it with the lift installed yet, but I'm not expecting a smooth ride.
I'll keep you posted.
Mando
Old 06-03-2011, 02:49 PM   #161
TheWhiteElephant
God is good!
Time to rebuild the original hubs. Replacement parts for these are scarce. I wanted to keep the originals. Originals were in good shape with the exception of the plastic dials and the missing gaskets. I got these new dials from Dennis Carpenter. I kinda like the fact that they are Ford models. I did not find any Spicer pieces anywhere. The red looks cool, though.
Found these NOS metal gaskets on ebay...
Disassembled everything, degreased, and cleaned everything up.
I sprayed the lockout bodies in semi gloss black...
Mando
Old 06-03-2011, 02:57 PM   #162
TheWhiteElephant
God is good!
Bought some rubber fiber paper and made some new gaskets. They go between the outer chrome piece and the lockout body. The metal ones go between the lockout body and the wheel hub assembly.
O-rings were in good shape.
Mando
Old 06-03-2011, 03:03 PM   #163
TheWhiteElephant
God is good!
Don't forget the snap ring...
Got some new bolts at the hardware store. They were identical to the OEM ones. I couldn't find identical dished washers, but that was probably a good thing since they are allegedly known for not keeping the bolts on. Instead I used these stainless lock washers identical in size to the originals.
Mando
Old 06-03-2011, 03:07 PM   #164
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Lots of progress you have going on down there, everything looks great!
I read that someone one here used to make those dials out of aluminum but i don't think he does any more, those would of been cool to have.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 06-03-2011, 03:26 PM   #165
TheWhiteElephant
God is good!
Got a whole new set of original material brake lines and a combination valve from Inline Tube. I'm very impressed with the quality. They fit just right. I also got a new set of extended stainless steel kevlar coated brake lines from Offroad Design. I highly recommend these to anyone with a 4 or 6 inch lift. I'm in the middle of routing all the brake lines.
Mando
Old 06-03-2011, 03:28 PM   #166
TheWhiteElephant
God is good!
Thanks, Tony. I read this, too. I looked all over the place and couldn't find these sources. One of the Bronco sites is making them for the internal hubs, though. All I did was buy an extra set of the plastic ones from Dennis Carpenter. I'm not going to wheel this thing so I "should" be okay.
Mando
Old 06-03-2011, 03:45 PM   #167
TheWhiteElephant
God is good!
During all this time I also degreased, cleaned, and wire-wheeled the entire frame in my driveway. Not fun. Then I painted the frame with Eastwood's Rust Encapsulator and gave it a second coat with semi gloss Rustoleum. The front 1/2 of the frame was really nice but the rear 1/3 or so if it had very rough surface rust. No heavy scale, though. The bed crossmembers are shot, though.
Take note of the rear brake line. It had heavy, scaly surface rust and was about to go.
Mando
Old 06-03-2011, 04:07 PM   #168
thinair
thinair
thinair's Avatar
Good looking truck.
thinair is offline   Reply With Quote
Old 06-03-2011, 04:33 PM   #169
TheWhiteElephant
God is good!
Originally Posted by thinair View Post
Good looking truck.
Thanks!
Mando
Old 06-03-2011, 04:55 PM   #170
spudz
spudz's Avatar
I like how your building this truck to be used and not just pretty. BTW, I am in need of extended brake lines for my 4in lifted k5 blazer and those look like what I need!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-03-2011, 08:27 PM   #171
my4by2
my4by2's Avatar
I just love this truck more & more!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 06-03-2011, 09:03 PM   #172
BIGBERTHA
Nice freakin build man! I enjoy watching it! Keep em comin!!
Marshall
1976 Chevrolet K10 4wd
2006 Chevrolet Impala (wife)
IF IT JAMS FORCE IT!! IF IT BREAKS, IT NEEDED TO BE REPLACED ANYWAY!!
BIGBERTHA is offline   Reply With Quote
Old 06-05-2011, 12:02 AM   #173
speedfreekk
nice build, keep it up.
speedfreekk is offline   Reply With Quote
Old 06-05-2011, 11:29 AM   #174
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Lookin great in red! Good work! Are you going to replace your tie rods and ends?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-05-2011, 10:56 PM   #175
TheWhiteElephant
God is good!
Thanks, everyone.
I sure am, I just did that today. Got everything from Rockauto.com. I'll post an update here in the next few days.
Mando
1973, 1973 k20, ball joint, ball joints, rough country
