08-14-2013, 02:48 PM | #1 |
Champagne Taste on Beer Budget
Re: Project 67
Great progress there Sammy.
Have you ran the fuel lines or just getting everything in place for a test fit? Piece by piece it's coming together nicely.
Coming Soon: Project 1970 Country Truck |
08-13-2013, 02:09 PM | #2 |
Re: Project 67
Nice! We always like to see progress. Keep up the good work. Loving the Coys too.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
08-13-2013, 07:56 PM | #3 |
Re: Project 67
Think I will leave the tank as is unpainted. But been known to have stuff powder coated at the last minute. The other port is a return line if needed. The Coys are sweet C-57s no fitting issues. Look at the black Chrome version..will make ur pants wet with envy!
The tractor paint gloss black n the gloss white is sweet to paint with. Takes a lot longer to dry than other stuff though. After 5 hrs it is still sticky to the touch even with the additive to speed up the drying process. Says 24 hrs to dry on the can. Added the additive still takes at least 12-14 hrs dry to the touch. Hopefully it stays n lasts for a long time in reflection to the elements of the weather. And I personally wouldn't use it on a primered surface even says says not recommended on bare metal surfaces. Very happy with using this paint if sprayed it needs to be used with the recommended reducer becoz it is so thick. Sure would be nice on a frame!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
08-14-2013, 07:26 AM | #4 |
68 C 10
Re: Project 67
Thanks Sammy I had ordered the same tank as you excect mine filler was in the middle.Guess I dont know much about FI yet.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
08-14-2013, 09:52 AM | #5 |
Re: Project 67
When you are working a project like this you constantly get asked about the color. Finally found something n placed a order for a gallon of Shoreline Beige. May not be enough but should get me through the cab and the front fenders. And see how badly I can do this in my garage. ( Single Stage ACRYLIC URETHANE )
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 08-14-2013 at 09:57 AM. Reason: @ |
08-14-2013, 10:01 AM | #6 |
Re: Project 67
In my comment about the tractor paint, I would only use it on a Primered surface. Mistyped with a brain malfunction.
08-14-2013, 07:59 PM | #7 |
Re: Project 67
Haven't ran the fuel lines or F to R brake lines yet. Pulling the cab off for the paint this week for my painting efforts next week and will likely run the brake and fuel lines then. Have you installed your tank yet, Scott? I have a steel blazer fuel line with a inline filter thinking of using half way up my frame rail.
08-18-2013, 05:15 AM | #8 | |
Re: Project 67
No not yet. In fact I did not get in on that group buy Boyd tank like I originally planned to do. Life happens you know. For now I'm just using the stock tank.
08-18-2013, 12:16 AM | #9 |
Re: Project 67
Paint is here.
Jeez never knew red 67/68 grill bow ties emblems were so hard to find! I give two away a few years ago..sorry now I did that.
08-18-2013, 01:32 AM | #10 |
I have a radical idea!
Re: Project 67
Are you wanting a new one or a decent used one? If a used one will do ya, I have several of them, and I'd ship you one if it would help...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-18-2013, 08:47 PM | #11 |
Re: Project 67
No doubt a decent used one is fine. Thanks.
Just had to experiment with this paint today. Not sure I can handle it. LOL maybe a white roof will brake it up some..Anyway got the inside of the doors n interior of the cab along with the rockers. I will study more on adding some white to the roof to break up the color. Still wet but looks more like sand color to me now that I sprayed it. Grill came out decent very happy with how it turned out. Of course a few cell Pics for the pic hounds.
08-18-2013, 08:49 PM | #12 |
Re: Project 67
more
08-18-2013, 10:25 PM | #13 |
Re: Project 67
I think white top and bottom, but then will have to put the cst trim on to dress it out.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
08-18-2013, 10:29 PM | #14 |
Tot Roddin'
Re: Project 67
I agree
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-18-2013, 10:35 PM | #15 |
Re: Project 67
Is the grill white or the same color as the truck?
08-19-2013, 10:28 AM | #16 |
Re: Project 67
Post #161 shows the grill as white.
08-19-2013, 11:54 AM | #17 |
Re: Project 67
This morning after it has dryed looks much better. But for sure at least the white top. Kinda reminds of my days in "Desert Storm" but glossy. I have it taped n prepped for the door tops n pillars. Check now on a quart of paint. Ohh so not looking forward to buying trim for dressing it out it so darn expensive.
67 C-30 contact me reference to a used Red Bowtie. Thanxs for the comments n suggestions.
08-19-2013, 10:23 PM | #18 |
Re: Project 67
Finished the exterior doors in beige. Really turned out nice. Prepped the upper doors n cab roof for white. Placed a order for the paint be here later in the week. Pics then.
Cab, cab interior, firewall, and the doors used almost a half a gallon of paint. Just guessing another full gallon may not finish this project. To change the interior color requires so much additional work. Lots more prep n materials too.
08-20-2013, 07:23 PM | #19 |
Re: Project 67
Pics
08-20-2013, 07:28 PM | #20 |
Re: Project 67
Funny how things disappear. Spent a decent amount of time looking for the elbow bracket n clip for this door lock!
08-21-2013, 07:54 AM | #21 |
Re: Project 67
Let me know, and I will look thru my leftovers.
08-20-2013, 08:06 PM | #22 |
6>8 Plugless........
Re: Project 67
Nice work and the color looks nice! I feel your pain on where did these pieces go?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-20-2013, 08:56 PM | #23 |
Tot Roddin'
Re: Project 67
Nice!
08-21-2013, 09:58 PM | #24 |
Re: Project 67
Scott, It will be next year before I even worry about locking doors. Just keep an eye out.
Today I got real deep into the steering column. Found out the differences between the 67 n later year column's shaft. The original shaft for this truck was bent bad maybe 3 degrees. Completely gutted the entire column since it was red in color anyway and will need painted. Used a pipe to cure the wobble. Also the main eye let style linkage on the tube was broken off flush. Luckly I had another auto column with enough good parts to salvage. Cleaned all the parts, tomorrow I will use the 2K primer on it and the cab side of the heater box. I think I will paint the column white when I paint the cab roof n upper doors. Heater box I will use the tractor gloss black paint back to somewhat close to the original color.
08-22-2013, 06:07 AM | #25 |
Re: Project 67
All I have to say is you have much more patience than I ever will.
Going to just get mine old truck running and enjoy it. Great craftsman ship Ron!
