Old 06-10-2013, 08:59 AM   #151
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 85 lwb turbo 5.3 build
Looks like it cleaned up nice.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-12-2013, 11:42 PM   #152
85burb
85burb's Avatar
Thanks. I got the ecm mount plate in the mail too. I also cleaned up the factory wires and put them in loom. Cant wait to have it in and running.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 06-15-2013, 05:40 PM   #153
85burb
85burb's Avatar
Kind of a big update. I got the motor installed today for the last time. I put the new flywheel on and the motor just about fell in to place. Took under 30 min to put it in my self. I got the water pump in and then attempted to find my o2 sensors and could not. I know I put them someplace but I am not finding them anywhere. I also am not sure where to run the steam line off the head. I was going to tap the water pump but with the pump and intake I have I cant find a clean looking place to put it. On my burb I ran it to the rad tank. The small rad I have in this truck does not have the port for a heater hose. I am kind of stuck on them two issues. I will pick up my upper hose today and manifold flange gasket.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-17-2013, 11:35 PM   #154
85burb
85burb's Avatar
Made some good progress today. Installed the intake, harness most of the way, passenger side manifold is in, ecm is mostly in, heater hose are cut and test fitted, brake booster line and pcv lines are done. Not a hole lot left to do. Just need a few more things and it will be time to fire up.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-23-2013, 09:45 PM   #155
85burb
85burb's Avatar
Got more done today. Removed driver side collector cause it is hitting the frame. I need to have it cut and repositioned. Installed the batt cables and ran the ECM power wire. Cranked the motor over a few sec to test the starter. All I need to do is get o2 sensors and wire up the fuel pump and flush the lines. Will post pics later.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-23-2013, 11:27 PM   #156
85burb
85burb's Avatar
pics
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-24-2013, 11:13 PM   #157
96twodoor
96twodoor's Avatar
digging the build, following along trying to learn something along the way
96twodoor is offline   Reply With Quote
Old 06-24-2013, 11:16 PM   #158
85burb
85burb's Avatar
Thanks.
I worked in bossier city for about a year and a half. Was contracted to Bj service.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-29-2013, 06:05 PM   #159
85burb
85burb's Avatar
Got it started today. Ran under a min. No cooling system yet. My oil psi gauge is not working in my dash. I disconnected the sender from the harness and put my volt meter on it and off it read .8 ohms and on it was like 55-60 ohms. So it has pressure. I also seen oil coming out the push rod when I took the oil cap off of it so it has to be my gauge. I grounded the wire out and the gauge did nothing. It should peg out unplugged or grounded correct?
http://www.youtube.com/watch?v=VVVE-...ature=youtu.be
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-29-2013, 11:12 PM   #160
85burb
85burb's Avatar
Got more done. Got the cooling system all set up. Got the power steering hoses and fluid in after taking the bracket on and off about 45 times. All I have left is finalize the wiring and I am sure there is more.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-30-2013, 07:28 PM   #161
85burb
85burb's Avatar
I am almost done. I secured the fuel lines and fuel pump power wires. Got the break line secured after removing the factory fuel lines. I have all the wires secured and ran except the fan and one o2 sensor cause the collector needs modified to not hit the frame. Also need the speedo wires hooked up or removed. I have not decided what I am going to do with that. Ran the motor and I don't have any coolant leaks or power steering leaks. I did have a bit of trouble getting it to burp all the air out. It tried to over heat for a little then it finally started pushing water threw the top hose. But it is working good now. I don't have a fan on yet so could not run it too long. I am pretty happy with how it runs so far. It did not die when I blip the throttle like my burb did. Cant wait to drive this thing.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-14-2013, 06:17 PM   #162
85burb
85burb's Avatar
Got to drive it a few times today. Having a bit of a fuel filter clogging issue but pretty much got it fixed now. I guess I did not get the fuel lines cleaned out as good at they needed to be. But over all it runs quite amazing. The video was not full throttle. With no bed it is extremely hard to get traction under any hard acceleration but if I punch it in 3rd it pulls hard. I am amazed with the power of this 5.3. anyways here is a short video.
http://www.youtube.com/watch?v=sOxmm...ature=youtu.be
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-15-2013, 01:35 AM   #163
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That video barely sounded like you got to 4k, sounds like the boost didn't hardly have time to kick in! It sounds good but I can imagine that once you actually start to draw some air it sounds entirely different.
Get her out on a nice long street, I want to hear this thing under some load where we've got noticeable boost. The little 5.3's SCREAM under boost, like a pissed off snake. It's gonna be sweet.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-15-2013, 08:06 AM   #164
85burb
85burb's Avatar
No turbo yet. Had to sell to pay a bill.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-15-2013, 07:48 PM   #165
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That will teach me to jump from my last post to your last post without reading a bunch of stuff in between haha. No wonder I can't hear it!
It still sounds good though, and now that I've actually gone back and looked at everything, its pretty clean too. Hopefully you'll get back at the turbo tho when the time is right, gotta execute the original plan!
Old 07-15-2013, 07:51 PM   #166
85burb
85burb's Avatar
It will get some kind of forced induction when money comes to me. Had to get truck going. Will need a trans before too long. Then a bigger rear end.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-10-2013, 11:07 PM   #167
85burb
85burb's Avatar
It has been a while. Still slowly getting parts. Ordered a better fuel filter due to crap being in the lines and tank. It was plugging the old one fast. Got most of the junk out and put a much larger filter with a better element in it. Also my bed bolts came in. Now to figure out what I want to do about putting a hole in the floor that I can fill the tank up with and have covered. Running out of ideas.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-23-2013, 11:23 PM   #168
85burb
85burb's Avatar
I got the massive fuel filter installed and the bed installed. Also chose to put a billet fuel filler cover that would go over the jeep factory area. will take a few pics tomorrow.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-16-2013, 11:16 PM   #169
85burb
85burb's Avatar
The truck took a 25 min drive to the muffler shop tonight. Hope they finish it tomorrow. Cant wait to be able to drive this thing. It has been a long time.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-18-2013, 12:47 AM   #170
BigDan3131
BigDan3131's Avatar
Since this is going to be a daily driver if I were you I would either make a pan for the fuel cell or make a container it can sit in to protect it all the way around. Those cell's aren't really made for the application you have.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-18-2013, 12:49 PM   #171
85burb
85burb's Avatar
Got truck back today. 70 bucks less the the quote. Looks amazing and sounds great. Got it inspected and is fully legal to drive.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-18-2013, 01:21 PM   #172
okieraptor
okieraptor's Avatar
Need a vid, we wanna hear it too!!!!!
82 chevy longbed(grey truck)first truck when i was 15!
okieraptor is offline   Reply With Quote
Old 10-18-2013, 01:30 PM   #173
85burb
85burb's Avatar
Got two. Need to put them on YouTube. Then will link them. Sounds good
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-18-2013, 11:53 PM   #174
85burb
85burb's Avatar
pic flipped the correct way
http://www.youtube.com/watch?v=WbZ1E...ature=youtu.be
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-19-2013, 12:29 AM   #175
okieraptor
okieraptor's Avatar
Does sound good!!!
