Old 07-04-2019, 02:19 PM   #151
bruceman1968
bruceman1968's Avatar
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Just for fun check to see if you find any Blazers with a build sequence starting with a 8. Line 2 builds started with 6 and line 1 builds started with 8. (1971 Flint) I'm curious to see if all the Flint blazers were built on line 2 or both lines. I don't have any blazer SPIDs 1971 Flint that the sequence number starts with 8, but you might.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 07-04-2019, 03:17 PM   #152
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm relying on those examples documented on the Blazer SPID thread. All of the 71 MY Flint built examples begin with 6 - there are no 8s to date.
I'll check the thread for Jimmy SPIDs and will post back if there are any Flint examples from 71.
Old 07-11-2019, 01:32 PM   #153
Keith Seymore
Keith Seymore's Avatar
Blazers were built on Flint Line 2 only.
Line 1 was specific to pickups.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-11-2019, 02:48 PM   #154
bruceman1968
Thanks Keith, Always good to hear it from the source.
Old 01-17-2020, 02:06 PM   #155
Austinjay
Austinjay's Avatar
Recently picked up a 1969 GMC K2500 and i was wondering what the X in the VIN stands for? On the VIN decoder it says that space should be a dash or a special designation. Thanks for the help!
'72 K20 Ochre/white 350/350/205 4" Lift 35's
'72 GMC K10 red orange/white 400/350/205
'69 C20 Longhorn 454 TH400
'72 Blazer CST 4x4
'70 Blazer 4X4
Austinjay is offline   Reply With Quote
Old 01-17-2020, 03:04 PM   #156
bruceman1968
Jay, Does the VIN on the door jam(metal plate) have the X?
Old 01-17-2020, 03:26 PM   #157
Austinjay
Austinjay's Avatar
That's a great question! I will look this afternoon when i get home.
'72 Blazer CST 4x4
'70 Blazer 4X4
Old 01-20-2020, 01:54 PM   #158
Austinjay
Austinjay's Avatar
The VIN tag on the cab has the dash. The X must have been a default letter for the dash in the printing system.
'72 Blazer CST 4x4
'70 Blazer 4X4
Old 01-20-2020, 02:48 PM   #159
70GM
I could use help reading the vin on my 1970 GMC Jimmy. The vin does not seem to match up correctly to the 1970-1971 GMC vin decoder. Any help.is appreciated.
70GM is offline   Reply With Quote
Old 01-20-2020, 07:15 PM   #160
AussieinNC
Moderator
AussieinNC's Avatar
KE114-SZ71554
K 4 WD
E V8
1 1/2 Ton
14 Jimmy
S St Louis
Z 1970
71,554 build identity
These are available in the first few pages of the LMC catalogs if you download the PDF file of the catalog...
Hope this helps...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-21-2020, 12:49 PM   #161
bruceman1968
Jay, So your vin does not have a special destination code, as the VIN plate is the definitive answer. The X on your SPID is unusual and most likely a assembly line mistake. The VINs on the SPID, were printed at a different time from the printing on the rest of the SPID. So who ever printed the VIN on your SPID put a X where a space should have been. I don't know why or how but it's a mistake. Other 1969 GMC SPIDS from St. Louis got it right.(space, no X) Kind of a cool anominaly that makes no difference at all. And it took 50 years for someone to catch the mistake.
Old 03-01-2020, 09:37 PM   #162
foxx26
Hi. I bought a short bed chassis for my project. I want to see if it’s possible to decode it? Like what year it is etc. The number stamped on the chassis on the driver side is 2z130693. Any help is greatly appreciated.
foxx26 is offline   Reply With Quote
Old 03-01-2020, 09:56 PM   #163
jocko
jocko's Avatar
72 Fremont built truck - the last 6 digits would match the last 6 digits of the VIN of the cab plate that was previously on the chassis. If original, it should have front disk brakes.
Old 03-01-2020, 11:04 PM   #164
foxx26
Thanks! Yes original front disk brakes. The rear suspension is leaf spring. I bought the chassis for my 70 cab. It was as my dad’s truck.
Old 02-06-2021, 03:18 PM   #165
Ryanz
Originally Posted by GMCPaul View Post
KUDOS TO Bruce for a REALLY GREAT JOB!!! I myself spent 1-2 years working on developing this same chart for the VIN's and then became frustrated and set this aside when the business was expanding. My frustrations were caused due to discrepancies I discovered on 67 GMC VIN's used at the Pontiac assembly plant as they appear to be the only assembly plant that used the shortened 7 digit VIN on all 67 models and at the same time I discovered that Canadian VIN's differed and I had no way to double check their info. entirely.
I wish he had reached out sooner to me for help on confirming information on a few things as I collaborated with Bruce very slightly on this project to help him with info I personally had from doing this research and I know for a fact that he has 3-4 years of heavy research to develop this chart. None of this info was readily or easily available prior to now and he did this purely to help other GMC owners to be able to decipher their VIN's easily and accurately so he defiantly deserves our HEARTFELT THANKS!!!
A Tremendous Job Bruce, My hats off to you!!!
Paul @ GMCPauls
Bringing this original thread back up because it is still relevant and a HUGE help today Paul and Bruce! You are a god damn beauties. Thanks for doing this. Any idea why my my serial number portion of my Canadian GMC 71 starts at 20,000 instead of 10,000 - KS104-11 20539
Ryanz is offline   Reply With Quote
Old 02-06-2021, 10:41 PM   #166
bruceman1968
Ryanz, Yes, because it rolled over after 10,000 trucks were built(for the USA market). Your truck was 10,539 to be assigned a vin number in 1971 at Oshawa for the American market. GMC's built at Oshawa for the Canadian market used the Chevrolet VIN format and used a 9 between the Chassis and Engine codes to denote GMC. They also used 100,001 as a starting number.
But because your truck was going to the USA, it uses the USA GMC format which has a starting number of 10,001. That's 10,001 with the first truck. So 20,539 - 10,000 is 10,539. Thanks for the kind words, Bruce
Old 02-06-2021, 10:55 PM   #167
Ryanz
Hey Bruce - thanks for this. Somehow I'm having a hard time following. If there were less than 1500 made of these stepside Chev 4x4's in 71 in the US - how is it possible it's number 10539? Or are you just saying GMC's in general? Not 4x4 Fendersides.
Old 02-06-2021, 11:04 PM   #168
bruceman1968
Yes GMC's in general. As far as the serial number is concerned they don't care what type of truck, just if it's a light duty truck or not. 1/2 ton or 3/4 ton, fender side or wide side, v8 or six cylinder. They don't care when issuing the serial number. If it's a light duty truck it gets the next number in the sequence.
Old 02-06-2021, 11:07 PM   #169
Ryanz
Gotcha! I’m going to pay the fee to find out more about mine specifically, and how maybe short box 4x4 fenderside GMC’s were made in Canada in 71. That has to be worth something no?
Old 02-06-2021, 11:13 PM   #170
bruceman1968
Yes, Info on the trucks built in Canada can be purchased still. But I doubt it will tell you production numbers. Mostly just how the truck was optioned.
Do you have the sticker on the inside of the glove box door? It will have the options on it.
Old 02-06-2021, 11:16 PM   #171
Ryanz
Yes - attached. What I’m most interested in finding out is how many of these GMC’s were made in a short box 4x4 GMC in Canada. Has to be very minimal.
Old 02-10-2021, 06:50 PM   #172
CapnCowboy
CapnCowboy's Avatar
Talking Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Thank you so much for this thread!!
All of you folks that post questions as well as answers ROCK!!
I love my treuck and I love all the fans of trucks! Thanks again!
CapnCowboy is offline   Reply With Quote
Old 03-05-2021, 07:15 PM   #173
Jefro63
New Member
Chevrolet and GMC medium and heavy duty trucks, I picked up a 1970 Chevrolet C50 and looking at what I think is a 1973 gmc 5500. Can you decipher the vin#?
CE503-Z124050
Jefro63 is offline   Reply With Quote
Old 03-06-2021, 09:29 AM   #174
67C10GS
67C10GS's Avatar
I’m kinda curious about the medium duty trucks as well.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10”
67C10GS is offline   Reply With Quote
Old 03-06-2021, 10:54 AM   #175
Steeveedee
Who Changed This?
Steeveedee's Avatar
CE503-Z124050
Here you go-
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
