Old 12-04-2014, 11:27 PM   #151
patdaly
Re: 86 Silverado K20 12V CUMMINS Build
Originally Posted by Dieselwrencher View Post
You can get them from Snap-on for $189. When I purchased mine I paid $489. Yes, I'm more than bitter about that.
FWIW, back when I first got into my Cummins, the kits were still almost 500 bucks as well, made my own from instructions given to me on DTR, under 70 bucks complete. Works just as good as the pro kit
Here is the PM from a fellow dieselhead.
"Hey no problem, I dont mind helping.
Well, You can get a delivery valve socket from piers diesel for $30.
2. For the dial indicator, Harbor Freight sells them for $10, and it works just as good as an expensive one. It has been used ot the forum more than once. The only prob. with it is it is in inches. That isnt a big deal, because if you search on DTR people have converted the mm to in. measuremens.
3. For a dial indicator holder, you can use a drain plug from our cummins. I went to autozone and they had one for $5.00. You just drill out the center so the dial indicator slides in there. Then you need to drill and tap a small hole for a set screw in the side of the drain plug, so the indicator doesnt move.
4. For the gear puller, any cheap steering wheel puller will work. You can get them from auto parts stores, for under $20.
I did mine this way and it worked out great. I looked on ebay and came across a metric dial indicator for cheap, after I did it with the inch dial indicator.
There you go, under $70.
Also, I dont recommend it, but I have read on here people use a set of chanel-locks and a rag to get the delivery valve holder off. The only prob. with that, is re-torquing the holder, to much and you will tear the o-ring and you can only get it at a bosch dealer, I guess its some weird size."
I am sure prices have gone up a tick since then, but not that much.
patdaly is offline   Reply With Quote
Old 01-25-2015, 08:20 PM   #152
crewcabsftw
crewcabsftw's Avatar
well this is too funny. brimc, i just happened to stumble across this thread and thought that truck looked familiar. i remember that truck came up on kijiji years ago and i went up to see it twice as well! it was up in the wasaga beach area if i remember correctly? i was dragging my heels over the money and just when i was ready to pull the trigger and give the guy his asking price, i called him he told me that it had just left the driveway. man was i kicking myself haha. glad to see it went to a good home though!
'79 Crew Cab K30 4l80 with tci controller/ps drop241/350tbi (with an LM7 swap in its near future)
crewcabsftw is offline   Reply With Quote
Old 01-26-2015, 06:22 PM   #153
brimc
brimc's Avatar
Well that is funny. I too dragged my feet for sometime then after he reduced his asking price, I gave him a lowball offer he accepted. Thought I did alright because I actually just paid him and jumped in the truck and drove it home. It drove great. Wasn't till I found out about the dead cylinder that I felt I paid too much. All in all I'm glad I got it. It is taking me a very long time but I know it will be worth it in the end. Thanks for the interest. Hopefully have some updates soon!
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 02-06-2015, 07:44 PM   #154
brimc
brimc's Avatar
Nothing really to update. Just getting the cab prepped. Final sanding on the bottom and finish prep the new cab corners and rockers. Plan on spraying the bottom first gravel guard sound deadner then paint. Flip it up then paint the entire cab. Want to have the entire body painted this spring.
BRIAN
Old 02-06-2015, 07:57 PM   #155
6BT 56
6BT 56's Avatar
Tired of winter yet. Much more tolerable than last year tho. How's your new heater working? I made a waste oil burning unit for my shop this winter. Had it working a few weekends now. It sure has been a welcome addition to my shop this year.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 02-07-2015, 06:58 AM   #156
brimc
brimc's Avatar
Tired yes. Winter just seams to take a lot more out of you. The heater in the garage works very good. Better then I expected. The built in thermostat regulates the draft to the firebox very good. It holds a good bit of wood too so it will go several hours before dieing out.
BRIAN
Old 02-07-2015, 09:53 AM   #157
6BT 56
6BT 56's Avatar
Did u ever get a transfercase ? You were looking for a divorced gm 205 ? I know sumone that has a trailer of treasure that he has been holding out on me. I could get in there and go scouting if ur still looking.
Old 02-08-2015, 08:21 AM   #158
brimc
brimc's Avatar
I backed off looking in this last year or so but anything I could find was just too far to even consider the drive or shipping. If you can find one of those that would be awesome
BRIAN
Old 04-19-2015, 09:11 AM   #159
brimc
brimc's Avatar
Well winter finally let up and I found some time to work on the project. The other day I pulled the cover off the frame and rolled it outside to clean up the garage some. I decided to hook up the battery and see what it would do. A couple cranks and the Cummins fired right up! No grids, no smoke, no problem. Hearing that engine idle smooth was music to my ears!
I also got the cab completely welded, sanded and prepped for the next step-paint. I again used por15 but only on the "rusty" areas and the "new" metal and mig welds. Time will tell on that call. Got the first coat of filler on the cab corners and rockers.
I used short strand fibreglass over the welded seams for sealing and strength. I will go over that with a lightweight filler next to level it out.
I also got the entire bottom side of the cab floor and firewall sprayed with undercoat/sound deadner. Then sprayed a gloss black topcoat.
I think it turned out pretty good. Hopefully I will get more to update soon!
BRIAN
Old 04-20-2015, 02:21 PM   #160
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work! That's a good feeling that winter is nearly out of here. Hearing the engine fire up is always a good motivational tool too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-20-2015, 11:01 PM   #161
y5mgisi
Second Chance Program
y5mgisi's Avatar
Good stuff! What product did you use?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-02-2015, 06:14 PM   #162
brimc
brimc's Avatar
I used this. $42 gallon. Seems to go pretty far. Spaying it everywhere will hopefully seal it up good and help with soundproofing like it says on the can. Time will tell tho.
BRIAN
Old 05-03-2015, 01:34 PM   #163
brimc
brimc's Avatar
Cab completely finished. No going back now. Body paint is gloss black body armour look. I surprised myself. It actually turned out better than I expected.
Also got the front inner wheel house painted too.
Now onto the rest of the body parts and get the cab back on the frame for good.
BRIAN
Old 05-05-2015, 06:20 PM   #164
Dieselwrencher
Nice work. What is the product you used? The pic doesn't show up for me.
Ryan
Old 05-05-2015, 08:19 PM   #165
brimc
brimc's Avatar
Dominion sure seal ltd. Premium rubberized rocker guard black. Applied it with a Shultz gun then two coats gloss black tremclad mixed with Dupli-color reducer. This stuff is very forgiving and hides everything. If you apply with dry coats and keep the top coats dry also it looks and feels like bedliner. I like it a lot so far and is very easy (and cheap) to apply. I'm planning on using this in winter and our roads are very bad for sandblasting. Rust protection and sound deadner in one. And if I get a scratch in the paint in will be black underneath. We will have to wait and see how it stands up.
BRIAN
Old 05-06-2015, 09:00 PM   #166
Dieselwrencher
Thanks. I am thinking of putting Al's liner on my bed floor top and bottom. I'm always open for cheaper/better ways too.
Ryan
Old 05-06-2015, 09:33 PM   #167
brimc
brimc's Avatar
This stuff is good but will not stand up as good as bedliner. I will be using bedliner in the box but I think I will just spray paint only on the bottom side of the box floor because there is less need for protection or sound deadening there.
BRIAN
Old 05-06-2015, 09:57 PM   #168
brimc
brimc's Avatar
I'm finally getting to the stage of putting things together where things start to look like a truck again.
Got the rear window installed along with the cab trim.
Then I decided to put the cab on the frame.
[URL=http://s1284.photobucket.com/user/brimc_99/media/Mobile%20Uploads/E57F33EF-00C7-4D66-BD82-1E46F88C9851_zpstmfpxmls.jpg.html]
It might not look it but that is very high with those 35" tires and new 4" springs. That cab lift on the end of the engine hoist works awesome!!
So stoked now. Starting to look like a truck again.
Hopefully things start moving along better now that the good weather is finally here
BRIAN
Old 05-07-2015, 12:18 AM   #169
Got Smoke?
Got Smoke?'s Avatar
Got any more pics of the cab hoist setup????
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
Old 05-07-2015, 03:29 PM   #170
brimc
brimc's Avatar
The only other pics I have are back on the early pages of this build when I made it to take the cab off the first time. It is only 2 2X4's bolted to the end of the engine hoist. The wood lets the door flanges bite into it and there is no movement at all. I can move the entire cab by myself no problem.
BRIAN
Old 05-07-2015, 03:41 PM   #171
brimc
brimc's Avatar
So moving right along on the cab I decided to go out and buy some of this after several hours of internet education on sound and heat protection.
It is 6" X 16'
$13 a roll. So why not. I can judge for myself after I drive it when it is finished.
If nothing else it sure cleans it up under the dash. I think I will do the entire floor and back wall before I put the interior back in too.
BRIAN
Old 05-07-2015, 08:59 PM   #172
COS399
COS399's Avatar
Nice progress! Keep it up. I can't wait to see it all together and running.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-09-2015, 09:01 AM   #173
Wrecked1982
Wrecked1982's Avatar
nice build
1981 c30 dually, 350 sm465 ex tow truck now yard mule
1985 k35 dually, 454 th400 np205
1985 D30 cucv M1008, 6.2 th400 np208
1999 toyota tacoma, lifted 6'' 31'' tires
2003 toyota echo, reliable and damn cheap on ga
z
Wrecked1982 is offline   Reply With Quote
Old 06-24-2015, 06:46 PM   #174
brimc
brimc's Avatar
Got lots to update once I get some pictures uploaded and some time.
But for now this little video update will give you an idea of what I've been up too.
BRIAN
Old 06-24-2015, 08:48 PM   #175
gerfunken
gerfunken's Avatar
What a wonderful sound....
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
