Old 02-07-2015, 02:54 PM   #151
69cunningham
69cunningham's Avatar
Re: Lss3
The radiator and support went in recently so I could see how the hoses and intake tube would fit. The 2010 Camaro LS3 upper hose doesn’t work. Oh well.
In this forum, several lower hoses have been suggested for LS swaps, the Gates 20931, 21718, 20687 and UPC 720530602270. The later fit a 93 chevy half ton with a 4.3 liter. I happened to have one of these left over from a Jeep project. It fits OK with a little trimming. I may try some of the other hoses to see if the fit is better.
69cunningham is offline   Reply With Quote
Old 02-08-2015, 09:11 PM   #152
69cunningham
Re: Lss3
I just got a flaring tool from Eastwood. I needed it since stainless is difficult to flare. My cheaper tools wouldn’t hold the tubing adequately. The standard Eastwood tool does 45 degree double flairs suitable for brake lines. I also got the 37 degree kit for AN flares.
The tool does a nice job once I discovered how to use it. The 37 degree instructions only describe double flares. The AN fuel lines require single flares.
Old 02-15-2015, 12:54 AM   #153
69cunningham
Re: Lss3
I decided to do a little body work today. The filler panel is the 38-7621 from LMC.
Old 02-15-2015, 01:00 AM   #154
Drifters
Re: Lss3
Very nice project!
Drifters is offline   Reply With Quote
Old 02-17-2015, 09:13 AM   #155
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
I had problems finding a correct lower hose for mine. I finally ended up making a brass adapter to go from the stock radiator to the stock LS hose. Please keep us posted if you find a better fitting hose.
Very nice work on the stainless lines. I really like that setup.
Excellent work on the fuel filler patch. Keep up the good work.
mcbassin is offline   Reply With Quote
Old 02-22-2015, 12:12 AM   #156
conman585
conman585's Avatar
Re: Lss3
As far as the upper rad hose check out the 2002 Chrysler Voyager 3.3 liter (PN 72044). It worked on a guy's LS3 Nova setup. Seems like the dimensions would fit w some minimal trimming.
conman585 is offline   Reply With Quote
Old 02-28-2015, 10:02 PM   #157
Crash'd Artwerks
Re: Lss3
Any progress lately?
Crash'd Artwerks is offline   Reply With Quote
Old 02-28-2015, 11:14 PM   #158
69cunningham
Re: Lss3
Things are moving slowly. I just got my latest order from Summit, some brake lines and a clutch master cylinder. I should have some pictures soon.
I'm going to get the Voyager radiator hose tomorrow that conman585 recommended. It looks like it will work with an extension in it.
Old 02-28-2015, 11:31 PM   #159
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Lss3
Awesome project!
ChuckDriver is offline   Reply With Quote
Old 02-28-2015, 11:46 PM   #160
conman585
conman585's Avatar
Re: Lss3
Here's where I saw it.
http://ls1tech.com/forums/conversion...6-0vvt-49.html
Old 02-28-2015, 11:58 PM   #161
69cunningham
Re: Lss3
Thank's.
Old 03-02-2015, 12:37 AM   #162
69cunningham
Re: Lss3
A while back I discovered the following pedal installation:
http://www.hotrod.com/how-to/interio...kar-pedal-set/
I’m not interested in the Lokar pedals, but am in the clutch master cylinder install. Here’s a picture of my hydroboast.
Old 03-04-2015, 09:59 PM   #163
69cunningham
Re: Lss3
I got the clutch master cylinder part way installed. I used a ¾” unit from Howe Racing (524412). It just fits behind the CPP Hydroboost. I hope the ratios work out.
Old 03-21-2015, 10:59 PM   #164
69cunningham
Re: Lss3
The clutch is finally working. I discovered that the master cylinder didn’t have the stroke that Summit Racing listed. It was only an inch. First I was worried it wouldn’t work. The cylinder bottomed out an inch before the pedal reached the floor. The clutch disengaged an inch higher. Once the pedal stop was installed and the rod re-adjusted, the cylinder bottomed just as the pedal reached the floor.
Old 03-21-2015, 11:19 PM   #165
Drifters
Re: Lss3
Your trucks coming along very nice!
Old 03-24-2015, 09:38 PM   #166
smokinstang70
smokinstang70's Avatar
Re: Lss3
Awesome job man...
"Love Affair" Build Thread
smokinstang70 is offline   Reply With Quote
Old 03-25-2015, 07:46 AM   #167
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Killer work on the clutch pedal setup. Also love the boost setup! That looks like a quality piece. Keep up the good work.
Old 04-04-2015, 09:07 PM   #168
69cunningham
Re: Lss3
I finally figured out the top radiator hose. It’s made from two hoses and a coupler. The neat thing about the coupler is that it has a 1/8” pipe fitting intended for a temperature gage, but I’m going to use it for the steam port. The engine side hose is from a 2010 Camaro (AC Delco 22736M) The Radiator side is from a 2002 Chrysler Voyager 3.3 liter (PN 72044). Thanks conman585 for the recommendation. The coupler is a 34mm unit from UPGR8 Racing (U8301-3404). The steam fitting an 1/8” NPT X ¼” hose barb from Earl’s Performance (AT984204ERL).
Old 04-16-2015, 09:24 PM   #169
69cunningham
Re: Lss3
Things have been moving slowly over the last few weeks, but they have been moving. The steam vent is done.
There was a set back with the rear end. The pinion has been dripping oil. I had to take it out so the Rear End Shop could replace the seal. I should get it back in the truck this weekend. I hate working on something that was supposed to be done.
Old 04-16-2015, 09:27 PM   #170
69cunningham
Re: Lss3
I got the electronic gas pedal installed. At first, I was going to build a bracket the bolted to the mounts for the original pedal however it didn’t seem strong enough. I removed to old net plate so the bracket could be welded directly to the firewall. The GM pedal pad is not the most beautiful thing. Lokar makes a replacement, but at $115 I think I will consider something else. There might be a way to adapt a stock 71 pedal pad.
Old 04-18-2015, 10:48 PM   #171
69cunningham
Re: Lss3
The rear end went back in today along with the brakes. Hopefully it won't leak again.
Old 04-19-2015, 03:10 AM   #172
kitsbeach
kitsbeach's Avatar
Re: Lss3
Hey 69cunningham, I saw in a post by hart_rod that the 71-72 gas pedal swaps perfectly with a 98-06 truck pedal. See post #22 here:
http://67-72chevytrucks.com/vboard/s...3&postcount=22
Nice job so far on your truck.!
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 04-19-2015, 07:53 PM   #173
69cunningham
Re: Lss3
Thanks Ken-
I saw hart_rod's bracket. Unfortunately it doesn't work with the late model GM electronic pedal that came in 2009 Cadillac CTSV's.
Old 04-22-2015, 04:57 PM   #174
kitsbeach
kitsbeach's Avatar
Re: Lss3
Thanks Ken-
Oh darn.
Kitsbeach (Ken)
Old 04-25-2015, 09:22 PM   #175
rkleypas
Re: Lss3
Beautiful build. I dig your attention to detail. Is your ls3 the e rod package? Are you running a stock front accessory package? If so, was any notching required for the ac compressor?
rkleypas is offline   Reply With Quote
