Old 11-01-2015, 04:00 PM   #151
Hankster
Hankster's Avatar
Re: "The Convict"
Originally Posted by LT7A View Post
Just read thru your thread. It's a good story: He gets the girl and the truck. I look forward to see where you take it from here. You've gotten after it quickly, and covered a lot of ground.
Thank you. As of right now the tags are out of date and she is sitting.. PLanning to do the idiot lights to gauges swap pretty soon. I need to get some more pictures up. I had the diff welded up and it completely changed the attitude of the truck. Not very much came out of the rear end when we opened her up, and what did come out looked like muddy water!
Originally Posted by naphtali5725 View Post
keep that flag a flying man! last time i checked, this is supposed to be America...
Yes sir! Thats right!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 12-28-2015, 01:09 AM   #152
Hankster
Hankster's Avatar
Re: "The Convict"
Did the gauge swap, fuel gauge still don't work and neither does the speedo. The truck has been parked again for a little because I have to get a new steering gearbox and straighten out the driver side frame horn.
Current Build
Old 11-04-2016, 12:19 PM   #153
Hankster
Hankster's Avatar
Re: "The Convict"
Been a while huh? Anyone remember I got the th400 built? Well the truck is parked because it has a broken bell-housing. I had the 12 bolt welded up because it apparently was just lsd not posi, and stopped working. Now I believe I may have stripped an axle spline, but I havent pulled it apart to check. IF anyone wants, I'll upload some pictures of the poor bell-housing
Current Build
Old 11-06-2016, 08:58 PM   #154
98GMCSierraGuy
Re: "The Convict"
What was the original rim/tire size that was on it when you first got the truck? Sorry to hear about your 400, mine isn't doing so hot at the moment either as I'm basically driving around in first gear
98GMCSierraGuy is offline   Reply With Quote
Old 11-07-2016, 11:15 PM   #155
l92powered77
Re: "The Convict"
Whats up Hank
Sorry to hear about the tranny. Hope you get it running asap. I never have been at the helm of a 454 burnout
Truck looks good. Be safe and be fast
You do any fishing or hunting around your parts. Your in a good area
l92powered77 is offline   Reply With Quote
Old 11-08-2016, 06:17 PM   #156
Hankster
Hankster's Avatar
Re: "The Convict"
15x10 with 295/50r15s
Originally Posted by l92powered77 View Post
Whats up Hank
Naw, I never did any hunting in Texas. I need to update my location again. I'm back in Florida, near Pensacola.
Current Build
Old 12-07-2016, 03:23 AM   #157
Hankster
Hankster's Avatar
Re: "The Convict"
Got the trans out.. Got a real job and been working. Bought a 4l80e for the truck. Gonna run it using a jakes performance control box. http://shop.jakesperformance.com/Man...80E-JP-MCB.htm Should make for a fun truck. All the performance of a turbo 400, with the addition of full manual, and over drive!
Current Build
Old 12-09-2016, 02:51 PM   #158
Hankster
Hankster's Avatar
Re: "The Convict"
Got me a driveshaft for the 80e, dropped it off to get my yoke swapped over. Been messing with my buddies miata aint messed with my turd any. Got the new flexplate on, old one was cracked baddddddd.
Current Build
Old 12-16-2016, 03:34 PM   #159
Hankster
Hankster's Avatar
Re: "The Convict"
Got the 4l80 in and buttoned up. Everything was going good until it started leaking. Its leaking from the return trans cooler line? The fitting is tight, and so is the trans cooler line. Should there be an O-Ring on the fitting? Thread Tape? Someone help me out here.
Current Build
Old 12-17-2016, 03:20 PM   #160
Hankster
Hankster's Avatar
Re: "The Convict"
Got everything fixed up. Its so nice to drive this thing with overdrive!
Current Build
Old 12-17-2016, 04:05 PM   #161
UKNOWME
UKNOWME's Avatar
Re: "The Convict"
So you're manually shifting each gear?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-18-2016, 11:40 PM   #162
Hankster
Hankster's Avatar
Re: "The Convict"
I am, It works great so far!
Current Build
Old 12-19-2016, 12:35 AM   #163
UKNOWME
UKNOWME's Avatar
Re: "The Convict"
Interesting I'm curious how well that works out long term. I can understand a race vehicle but seems like a daily driver would get tiresome after a while.
1964 Chevy c10
Old 12-19-2016, 05:40 PM   #164
Hankster
Hankster's Avatar
Re: "The Convict"
We shall see how it goes.
Current Build
Old 12-19-2016, 05:43 PM   #165
Hankster
Hankster's Avatar
Re: "The Convict"
http://67-72chevytrucks.com/vboard/s...d.php?t=725181 Someone HELP me with this POS. Thanks.
Current Build
Old 02-03-2017, 04:22 PM   #166
Hankster
Hankster's Avatar
Re: "The Convict"
It was a bad connection on the dimmer switch! It's been fixed for a while just haven't been back on here. I may be going 8 lug, not sure yet!
Current Build
Old 05-01-2017, 01:50 AM   #167
85raiderburban
85raiderburban's Avatar
Re: "The Convict"
Got the Big Block in!! Thanks to the help of my dad! It looks gooooooood! Sadly the headers wont fit my truck, so I'm probably gonna just run factory exhaust manifolds for now.
Feels great to upgrade, i know the feeling also. Just wanted to mention,the photos attached here show a Mark IV (68-1990) 454. No Gen V (1991-1995) had a mechanical fuel pump on the side of the block like your does. The only 454 newer than 1990 that had that provision was the aftermarket Vortec 7.4 L29 (1996-2000 Gen VI). The factory blocks did NOT feature this. And i doubt that is what you have as that iron boat anchor intake you have on there is a factory smog motor intake. My RV bb had this one until i swapped it out for a rectangle port 396 aluminum intake. Just sayin.....
it doesnt, i shift mine manually with these toggle switches. Having to prgram a damn computer would get tiresome especially when it keeps throwing codes and puttin tranny in limp mode.
I never realised how crappy the quadrajunk was..
When their clogged up and on they're last leg, it can be that way suddenly out the blue. Been there done that. But i still got an 800 cfm QJ on my bb. Throttle pin bypassed, those soda can sized secondaries really wake it up. Yours probably only had the primaries opening. A QJ can also be hacked to 900 cfm, that is if your into sloppy mechanix.
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado)
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior
85raiderburban is offline   Reply With Quote
Old 09-26-2017, 12:17 PM   #168
Hankster
Hankster's Avatar
Re: "The Convict"
I have run the numbers on the back of the block and heads many many times. it is a gen v engine, but its a gm crate engine with the fuel pump provision. Yes, it is def a mark IV intake. I plan to put an aftermarket intake on at some point. I have had a lot going on late. I moved back to texas, and had to leave the truck in Florida. Sitting with no starte, and no battery. I need to go get it and start daily driving it again.
Current Build
Old 09-26-2017, 02:27 PM   #169
85raiderburban
Re: "The Convict"
Wow, very rare part as it is unheard of that ANY gen v would have the provision. Im willing to bet its a "leftover" mark iv with the gen v casting. I had a 96 502 H.O. (leftover block prior to gen vi production) when i bought my '80 sub and it didnt have the provision. On a side note i have a '75 pontiac 455 thats supposed to have the 500xxx casting but has the 70-74 485428 casting = leftover block from 74 used for 75 factory cars. The factory does that and so does the aftermarket.
Old 10-03-2017, 01:11 AM   #170
Hankster
Hankster's Avatar
Re: "The Convict"
That's what I figured had happened. lol
Current Build
Old 11-12-2017, 07:14 PM   #171
Hankster
Hankster's Avatar
Re: "The Convict"
Update.. spider gears cracked where the rear end was welded, so we re-welded it. It lasted 40 minutes and went boom. So we re-re-welded it and fixed the cover (photos attached) and it last a day or so and I believe it broke a c clip. Gonna go see Tony Kee (Texas Square bodies) and get a rear end, and maybe some un-cut coil springs.
Current Build
Old 02-05-2018, 12:32 AM   #172
Hankster
Hankster's Avatar
Re: "The Convict"
Found a bangin' deal little closer to me for a 12 bolt, got some new coil springs as well. So it's back to stock height. Hopefully not for long.
Current Build
Old 02-06-2018, 05:55 AM   #173
85raiderburban
Re: "The Convict"
Oh damn, what happen to the gears, u welded them to make it posi? And it didnt last?? I say find a 14 bolt full floater and youll be set.
Old 02-07-2018, 05:17 PM   #174
Hankster
Hankster's Avatar
Re: "The Convict"
Welded it a while back, held on for a long time (2-3 years). Specially the way I drive. Re-welded it when it broke like three times (in a month or so) for the heck of it. Thought about going 14 bolt FF but didn't wan to go 8 lug. Next thought was 14 bolt SF (6 lug) but the one I got from a 88-98 was to wide. Bought another clean 12 bolt to start over. Going to actually Get a spool for this one.
Current Build
Old 03-04-2018, 10:04 PM   #175
85raiderburban
Re: "The Convict"
your gonna need the trans go vacuum modulator to drop line pressure since by default with jakes box it will be full line all the time. NOT good. But dont drill the case wit the tapped fitting that comes in the kit, drill thru the pan on the pass. side like i did and run regular vac hose to the intake.
