Old 04-30-2020, 11:06 AM   #151
oem4me
Re: Rarest factory paint combos
Originally Posted by bigmoe View Post
I see on the 66 color chips they have a silver. Anyone ever see a factory silver 66?
Only ONE, ever. Post 24 of this thread.
Old 05-10-2020, 02:00 PM   #152
sstock
sstock's Avatar
Was it this off white (526) that was used on the two toned trucks both Chev and GMC 64-66?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 05-10-2020, 08:37 PM   #153
jocko
jocko's Avatar
Yes, 526 was the roof color for two tone coded trucks. 521 white was available as a solid body color only. Also note that the bumpers, grille (if not stainless), grille surround, trim insert, and hub caps (if not bright) were all off-white also - unless the truck was solid 521 white, in which case all of the above areas were also 521 white. Tailgate letters were off-white 526 except on a 521 or 526 (solid) truck, in which case the letters were black.
Old 05-10-2020, 11:08 PM   #154
sstock
sstock's Avatar
Perfect info, thank you Jocko.
Old 01-20-2021, 08:12 PM   #155
pdxhall
pdxhall's Avatar
Originally Posted by pdxhall View Post
Does anybody have any pics of the 62-63 only Sea Mist Jade Metallic? I have a tailgate I picked up for my truck that I believe was this color and I have only come across one truck that I believe is the color.
I solved the mystery of the rare paint color Seamist Jade Metallic that I am planning on painting my truck after staring at the tailgate I picked up ages ago as a replacement for my original. I found a touch paint place online that has an incredible catalog of paint codes. It cost about $35 including shipping which was well worth the cost. Here's what I got. I had this heater top that was primered a medium gray. The lighter pics are in direct sunlight and the others are off to angles. I think it will look great on my truck.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-20-2021, 11:29 PM   #156
cwcarpenter98
cwcarpenter98's Avatar
That looks great!! What was the place you found?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-22-2021, 09:25 PM   #157
pdxhall
pdxhall's Avatar
This is where I got the paint. Very good service.
https://www.paintscratch.com/cgi-bin/select-color.cgi
Sanity'66
Old 01-23-2021, 12:21 AM   #158
cwcarpenter98
Thanks!
Christian Carpenter
Old 12-13-2021, 01:47 PM   #159
77Blue
Originally Posted by Classic v6 GMC's View Post
Second and third pic is the 555 yellow.
Do you still have this swatch book?
Is there a color in there called oriental green? Any info on it?
Sven
77Blue is offline   Reply With Quote
Old 12-13-2021, 11:38 PM   #160
dragracer98
Junior Member
Sven
In 1957 and 1958 there was a color called Oriental Green (Color Code 703) that was used on Chevy trucks. It was also listed as a GM color. Not sure what else might have been painted with that color. The info I looked at has no mention of GMC at all. Hope this helps.
Randy
dragracer98 is offline   Reply With Quote
Old 12-14-2021, 12:35 PM   #161
darkhorse970
darkhorse970's Avatar
Well after searching ebay for years I finally found a 1966-1967 GMC data book and better yet a special paint colors book. It has 200 special order paint colors.
I’ve been curious for a while about the paint color on the truck on this 1967 GMC brochure. Can you help me figure it out?
It looks similar to the paint on this Chevy too.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
