05-25-2015, 04:48 PM | #1826 |
Post Whore
Re: Restoring Rusty - Voltmeter Wire Color
Guys set me straight here please.
Where does the signal to the voltmeter come from, and what color wire does it travel on? I know that the oil pressure comes from the oil pressure sending unit via a tan wire, the coolant temp, comes from the coolant temp sensor via a green wire, the fuel level comes from the fuel sending unit via a tan wire. All these wires enter the bulkhead connector and then route directly to the circuit board. |
05-25-2015, 07:00 PM | #1827 | |
Re: Restoring Rusty
No thread to prove it but I'm down to the frame and ready to come back up. I'll be installing my gauge cluster and repinning the connector in my 79 real soon. Keep up the good work and documentation "G". Last edited by Chaplain; 05-25-2015 at 08:18 PM. |
05-25-2015, 07:05 PM | #1828 | |
Re: Restoring Rusty
Thank... |
05-25-2015, 08:36 PM | #1829 | |
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
05-25-2015, 09:03 PM | #1830 |
Post Whore
05-25-2015, 09:08 PM | #1831 |
Post Whore
Re: Restoring Rusty
yes I am so anal I pulled the proper three prong pink wire instead of splicing in another wire to my old one, it forced me to learn where it goes (same on the '74 as on the '76 by the way but different on the '79)
the screw driver is wedged where it plugs in to the fuse block |
05-25-2015, 09:12 PM | #1832 |
Post Whore
Re: Restoring Rusty - Clutch Switch Delete
thought this was as good of a time as any to delete the clutch safety switch even though I had the loop thing pluged in there for decades, no sense of wiring such a heavy wire two feet up the steering column if you don't have to
super easy delete, just unplug the connection from the white plug where it plugs in to the clutch switch and take that wire and plug it in to the bulkhead connector directly, this will continue the purple wire path to the starter, job done |
05-25-2015, 09:25 PM | #1833 |
Post Whore
Re: Restoring Rusty
new printed circuit board going on with old clips and semi new light bulbs
05-25-2015, 09:27 PM | #1834 |
Post Whore
Re: Restoring Rusty
gauges going in...
in the end here's the verdict Speedo - works Water Temp - works Oil Pressure - works Tachometer - works but is inaccurate Voltmeter - does not work Fuel gauge - is missing |
05-25-2015, 09:42 PM | #1835 | |
Re: Restoring Rusty
Classic Parts has that fuel gauge -- 50 bucks. You might want to try to scrounge that!
Rich Weyand 1978 K10 RCSB DD. |
05-25-2015, 10:22 PM | #1836 |
Re: Restoring Rusty
Gregski the calibration is ez. What I did was hook up a tach under the hood and hooked up the raw factory tach right beside it . As said earlier, that little blue part you solder on has small adjustable dial on it. Just turn it until your factory tach matches the good tach, run a few different rpms and all good. Yeah that dude is an electro tech. But I did it just like I said and is quite easy once you filter out the nerdspeak .
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 Last edited by bilfman; 05-25-2015 at 10:23 PM. Reason: X |
05-26-2015, 01:14 AM | #1837 |
Post Whore
Re: Restoring Rusty
05-26-2015, 10:56 AM | #1838 |
Post Whore
Re: Restoring Rusty - Visors
well enuff of this electronic stuff, let's see what else the Greg has been working on... how about them Visors
first we had to remove the old swivel stick or bracket out of the old ones not sure if I should be mad at LMC Truck for being such cheap donkeys and not including the swivel sticks when they sell you new visors or thanking them for keeping things so modular |
05-26-2015, 10:58 AM | #1839 |
Post Whore
when we wiped the sticks off a bit we noticed they are labeled R (Right) and L for [wait for it] ... (Left)
and that's why we clean our parts |
05-26-2015, 11:02 AM | #1840 |
Post Whore
Re: Restoring Rusty - Anatomy of a Visor
so The Greg decided to cut one crispy crusty visor open and see what it is made of
Anatomy of a Visor? are you serious? it's just a .... oh wait I see, cool thanks, I did not know that's what lurked inside them little rascals ... |
05-26-2015, 11:06 AM | #1841 |
Post Whore
Re: Restoring Rusty
of course nothing's easy but everything must be black, so we used some Denatured Alcohol to wipe off the ol' swivel sticks and tapped them off so that they could be painted black, just using the same semi flat black we used under the hood on the engine bits
to slide them in was a pain, I did not know weather to lube them up with the Rich recommended white lithium grease or slip them in dry, so I split the difference and lubed one up and left the other side dry, LOL in the pics the sticks are still not slid in all the way, (as I came to find out when I went to mount them) |
05-26-2015, 12:42 PM | #1842 |
Re: Restoring Rusty
05-26-2015, 05:08 PM | #1843 |
Re: Restoring Rusty - Radiator Support
Nice score. Me jealous....lol.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
05-26-2015, 06:03 PM | #1844 | |
Post Whore
Re: Restoring Rusty
http://www.classicindustries.com/pro...ts/t70841.html |
05-26-2015, 11:43 PM | #1845 |
Hey! You found the visors I have in my 64. That's something I need to fix one of these days...
05-27-2015, 07:48 PM | #1846 |
Post Whore
Re: Restoring Rusty
Well after threatening to buy a new used voltmeter on eBay, today mine started to work!
06-02-2015, 03:17 AM | #1847 |
Re: Restoring Rusty
Updates!
06-02-2015, 10:22 AM | #1848 |
Post Whore
Re: Restoring Rusty
LOL, The Greg was hurtin' for dough at the end of the month so he had to lay low for a week or so, I mounted the huge clutch pedal spring but there was not much for a picture opportunity
but as of the first of the month he has already ordered the following 1. Brand new fuel gauge 2. Another used Tach off of eBay (for $45 bucks I had to take the risk) 3. Brand new Holley carb tunning kit [more on this later] but it does involve a Test so you all may wanna study up, hee hee |
06-02-2015, 02:11 PM | #1849 |
Re: Restoring Rusty
Rusty, how did your visors turn out?
06-03-2015, 08:47 PM | #1850 |
Post Whore
Re: Restoring Rusty
