Old 09-11-2010, 07:39 AM   #176
a5Ben
Re: Project "Popeye"
Thanks for the info guys, I'm doing the S10 swap as well and want to use the original column to keep the inside as stock looking as possible, oh and cheaper
Since I haven't pulled my cab yet I haven't actually seen the inside of the shaft so your descriptions help a lot!
Ben
a5Ben is offline   Reply With Quote
Old 09-11-2010, 12:27 PM   #177
67cheby
67cheby
67cheby's Avatar
LEEVON ... not trying to say anything here just posting a little pic for you
67cheby is offline   Reply With Quote
Old 09-11-2010, 12:28 PM   #178
67cheby
67cheby
67cheby's Avatar
ok maybe i was.....JUST SAYING!!!
Old 09-11-2010, 08:04 PM   #179
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
I agree.still lovin the build.keep the pics comin.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 09-11-2010, 11:00 PM   #180
LEEVON
LEEVON's Avatar
...where's that darn "67cheby lock-out button"...
Since you guys NEED pics like a fatboy needs cake, here's the latest. Got the engine/trans mocked-up and removed the cab to start work on it. The truck oil pan is keeping me from putting it on the ground but I dropped an f-body pan off to get welded up today. The Hooker LS1 headers are perfect, no clearance issues at all. Next task is getting the brakes installed then the engine will come back out and get detailed and fitted with the flywheel/clutch assembly. I have the rear bags, brackets and panhard bar on the way from Thorbecke Bros.
Wish I had thrown the Hurst shifter on.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-11-2010, 11:22 PM   #181
ambryatim
ambryatim's Avatar
Man that looks GOOD!!!!
So, I see you have the trailing arms on there.....did you have to modify the mounts where the arms bolt to on the cross-member??
I had talked to Nate Porter about that and he said that I (we...who ever does this mod) need to make sure the arms are pointing up to the center of gravity on the vehicle to prevent any issues with binding or poor performance. He also suggested that one might have to lower the arms down because they could be at too much of an angle (upper wards) and the solution would be to drop the mounting point on the cross-member to compensate for less kick-up on the older trucks that have more of a straight ladder frame.
ambryatim is offline   Reply With Quote
Old 09-11-2010, 11:44 PM   #182
LEEVON
LEEVON's Avatar
Thanks! Sorry I never got you those angle measurements. I really don't have an angle finder. I didn't modify the mounts at all, the clearance from the arms to the crossmember you see above them is about 1" at full dump. If you wanted to go lower, blocks on the axle would solve that problem.
I'm sure the geometry is not perfectly engineered, if I put too much thought into it I may talk myself out of it. I bet it will ride much nicer than the older version of this truck's suspension though. At ride height the arms will have more angle to them, the pics are a bit deceiving but they are about level aired-out.
Old 09-12-2010, 12:25 AM   #183
ambryatim
ambryatim's Avatar
That's fine about those angles.....to be honest....I am about 3-4 months out before I even start on the rear suspension.....Just a thought though, if you do get an angle finder (home depot have some) I would just check what your 72 is at, at ride height....I am sure it will be close enough....Just thought I would throw it out there. I am looking forward to the ride of mine also.
Me I, try to be a perfectionist, but then I will sometimes loose my patience and just say, Awww...its close enough...then I will have to go back to it later to re-do it.
I am really trying to keep from doing that any more, it eats up alot of my time...LOL
Old 09-12-2010, 12:32 AM   #184
LEEVON
LEEVON's Avatar
I've got one of those angle finders, set up the chassis, engine and everything with it, just didn't have a way to measure the angle of the trailing arm mounts in relation to the crossmember.
Old 09-12-2010, 02:04 AM   #185
kustombrad
kustombrad's Avatar
Dude!!! Gonna be a way cool truck!!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 09-12-2010, 09:36 AM   #186
LEEVON
LEEVON's Avatar
Thanks! I was showing my wife pics of your truck and she was asking me how in the world we're going to find somebody to do lettering and striping that nice!
Old 09-12-2010, 10:31 AM   #187
99 to Life
99 to Life's Avatar
u-joints if you are doing s-10 pws, go to the scrap yard an find a conversion van chevy late 80's maybe early 90's. take the upper and lower u-joint off of their steering. That bottom u-joint fits right onto the s-10 box. the upper you will have to shim and also square off the steel tube that comes out of the original column. Basically you have to find a way to connect the top ujoint to the bottom of the original steering column. There are tons of ways you can do it. Then just find a d shaft from say a full size chevy truck that way you have plenty of length to work with, cut it to fit in between your ujoints. The aftermarket ujoints are alot smaller than these chevy van ones, plus they are about 60 bucks and up a piece. Check out my build and you can see how I ran mine, if you need.
Popeye, I am sure there are plenty of people on here that can answer your suspension angels. I would check out Yarils Customs, he had done some similar stuff to you, but not with trailing arms I don't think. Anyway keep the work and sorry for typing so much on your thread.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-12-2010, 08:49 PM   #188
LEEVON
LEEVON's Avatar
Worked on the truck a little today and wound up making this, a salute to 9/11 victims:
Old 09-12-2010, 08:57 PM   #189
ambryatim
ambryatim's Avatar
That is cool LEEVON...I like it. You should get it Bronzed.
Old 09-12-2010, 09:32 PM   #190
CHIZZLER
CHIZZLER's Avatar
Thats freakin killer.chassie looks good to.
61-crew cab D-max
Old 09-12-2010, 09:38 PM   #191
ratty 46
No that is KICK ASS LEEVON. Well done. I watched the 9/11 special last eve ..... It still stings. Yet .... our mamby-pamby leader apologizes & asks for tolerance.
I could go on & on ..... let me step down off the soap box.
But on a positive not that is wicked kewl dude.
Ratty 46, A LOYAL AMERICAN
ratty 46 is offline   Reply With Quote
Old 09-13-2010, 12:51 AM   #192
OrrieG
OrrieG's Avatar
I watched the special too. Seeing those firemen walking towards the second Tower after the first had already collasped almost made me loose it. True bravery and heroes there, no BS, no posers. 430+ NYFD lost that day. Rest in peace men.
OrrieG is offline   Reply With Quote
Old 09-13-2010, 08:19 AM   #193
LEEVON
LEEVON's Avatar
The special "102 minutes that changed the world" was very good. I had my family watch and there were no dry eyes.
Old 09-13-2010, 09:35 AM   #194
67cheby
67cheby
67cheby's Avatar
hey i have a home made cab dolly setting behind my shed if you want to borrow it for a while
Old 09-13-2010, 11:39 AM   #195
LEEVON
LEEVON's Avatar
Ummm....heck yeah! I didn't bother posting about my cab fiasco but I put two pallets together with some casters from Harbor Fail on the bottom. I had a heck of a time getting the cab onto the pallets by myself. Happy that the job was done, I started rolling it around the garage and it rolled like butter so I headed out to the driveway. Then I hit a bump and a wheel and all it's bearings shot out, then another. I grabbed a sledge and beat the other two off. So my wife came home and asked how I did all that by myself and was it going to stay in the driveway? I don't think she believed me that I was happily rolling it all over the place a few minutes before.
So long story short I was trying to figure out another system.
Old 09-13-2010, 11:42 AM   #196
67cheby
67cheby
67cheby's Avatar
mine has 10inch casters on it ....it will roll
Old 09-13-2010, 11:49 AM   #197
bjcaldwe
bjcaldwe's Avatar
I did something similar with my old 5 window cab. I have a lip going into the garage and it knocked off one how side of castors lol. Luckily, it was far enough in that I slid the cab and pallets far enough to close the garage door.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 09-13-2010, 07:49 PM   #198
solidaxel
solidaxel's Avatar
I hear that !!\350 engine on a 3 wheel engine stand and a expansion joint in the floor = one broken block !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-27-2010, 11:12 PM   #199
LEEVON
LEEVON's Avatar
Little by little...swapped the cam, pushrods, and valvespings. The cast LS valve covers came today from PML covers and they are very, very nice and solid. I of course got impatient and had to mount them so I did a little painting (heads, covers and oil pan aluminum with clear). The block will still be painted blue like the wheels...so this is just a teaser.
I was able to get the bag brackets, panhard, tank and compressor mounted this weekend also. The Thorbecke Bros panhard is a very nice piece, thanks Ricky!
TONS of little things left to get the chassis done but it's getting there.
Old 09-28-2010, 08:08 AM   #200
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice progress!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
