Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-07-2011, 12:16 AM   #176
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
I received your payment....thanks
I probably won't get these shipped tomorrow but the following day. I have a rush job I have to get done tomorrow, and it takes 3+ hours to get these brackets ready to ship. Hopefully that will work for you.
Originally Posted by rob32472 View Post
paypal sent
Regarding the Eldorado caliper cable bracket and lever. I did hear back on one set I inquired about. Now we just need to settle on a price, so I can get them.
Old 12-07-2011, 07:18 AM   #177
rob32472
No problemo!
rob32472 is offline   Reply With Quote
Old 12-08-2011, 11:40 PM   #178
weircc
weircc's Avatar
does your kit require removing axles to install??? and is the price the same as front page
and also which wilwood caliber too use i see some different sizes??
1971 rs camaro under the knife ls3 6 speed swap
1970 396 big block shorty fleet 67 clone
2010 rs/ss camaro
weircc is offline   Reply With Quote
Old 12-09-2011, 12:27 AM   #179
Captainfab
60-66 Nut
You don't have to remove the axles to install these brackets, but you will have to, to remove the backing plates. Unless you cut them apart to get them past the axles. It really isn't difficult to remove the axles. When was the last time you changed the rear end oil? If it's been a while, it might be a good idea to pop the rear cover, R&R the axles, re-install the cover with a new gasket, and fill with your choice of gear oil......just sayin
Yes the price is still $232.00 plus $10.00 for shipping. The powder coating is still the same $28.00. You can use any D52 type caliper with this kit. Wilwood makes 2 different sizes of the dual piston D52 calipers. For the rear you will want the ones with the smaller pistons.....1.250" I believe.
Old 12-31-2011, 12:25 PM   #180
Sabaka454
Sabaka454's Avatar
Anyone run this set up with 15" wheels? I am interested in a set
Sabaka454 is offline   Reply With Quote
Old 12-31-2011, 12:45 PM   #181
Captainfab
60-66 Nut
Yes, 15" wheels will work with this conversion, as long as they are disc brake compatable wheels.
Old 01-13-2012, 11:17 AM   #182
Tmwoodall
Have you considered adding tabs to the mounting plate to allow for the standalone wilwood mechanical parking break calipers? I'd love to run this setup and match my front Wilwoods, but need to be able to pass inspection with an eBrake....
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 01-13-2012, 11:55 PM   #183
Captainfab
60-66 Nut
Yes I had thought of that some time ago. I just haven't done anything with the idea since it will add some cost to the conversion and I'm not sure if that would put it out of price range for more people.
I'm not saying I'm not going to persue it, it just may take a little time to get it to a final design. I checked with Summit, and these are on back order until the 23rd at the eaeliest.
Old 01-14-2012, 12:28 AM   #184
68 TT
Still plays with trucks
68 TT's Avatar
I looked at doing that but the widest rotor the ones I found could use was 0.81" so it didn't work out. Maybe they have another I couldn't locate on their web site. It is possible they could be modified with a machined spacer to make them work with the 1-1/4" thick rotors.
http://www.wilwood.com/Calipers/Cali...me=Mech%20Spot
They do have a hydro-mechanical parking brake caliper now though that can work with a 1" rotor.
http://www.wilwood.com/Calipers/Cali...tion%20P-Brake
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-14-2012, 02:45 AM   #185
Captainfab
60-66 Nut
Yeah, I figured I would have to have some thicker spacers machined to make them work with the 1.250" thick rotors.
Those new Wilwood calipers, have a different type of mounting....they aren't cheap either! I wonder if a guy could add a spacer to those, and use them on the 1.250" rotors? Looks like they are a 2 piece design.....
Old 01-15-2012, 12:59 AM   #186
Tmwoodall
You aren't kidding. Those are pricey. I guess I'll keep thinking. Not sure I want to go without a parking brake (not that I need or use it).
Old 01-18-2012, 07:38 PM   #187
68 TT
68 TT's Avatar
They are very proud of that caliper indeed. I would rather make the spacer for the puck caliper and use it in conjunction with my caliper of choice instead.
I thought about a differential pinion mounted parking brake setup using a single puck type mechanical caliper but for the work & parts involved it would be easier and cheaper to just run these on the actual brake rotors instead.
Old 01-19-2012, 12:47 AM   #188
Captainfab
60-66 Nut
Adding a mechanical e-brake to this conversion bracket, is high on my list of to do's. I'm going to be ordering one of the Wilwood mechanical spot calipers soon.
Old 01-19-2012, 12:49 AM   #189
Tmwoodall
Adding a mechanical e-brake to this, is high on my list of to do's. I'm going to be ordering one of the Wilwood mechanical spot calipers soon.
If you do that and still have it laying around when I go to order mine (which I WILL be doing if you update this to have ebrake) I'll gladly buy it off of you.
Old 02-12-2012, 08:08 AM   #190
truck farmer
hey, captainfab i would like to order some of your D52 disc brake brackets and the brake booster bracket for a 72 chevy pickup. do you have any left?
truck farmer is offline   Reply With Quote
Old 02-12-2012, 11:37 PM   #191
Captainfab
60-66 Nut
I replied to your PM........
Old 02-13-2012, 07:05 PM   #192
truck farmer
do you have an idea when these will ship?
Old 02-14-2012, 12:28 AM   #193
Captainfab
60-66 Nut
Ordinarily your order would have shipped today, but I am currently extremely busy. Your order will ship tomorrow, and you should receive it by Friday.
Old 02-14-2012, 07:25 PM   #194
truck farmer
thank you very much Captain. i cant wait to get them on my truck.
Old 02-18-2012, 09:24 AM   #195
truck farmer
got my brackets a few days ago, they look great. thanks for everything captain. Ill let you know how it goes.
Old 02-18-2012, 11:06 PM   #196
Mr_Rich
Mr_Rich's Avatar
Are the GM D52 calipers used on the front of the 88-98 trucks?
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 02-19-2012, 12:19 AM   #197
Captainfab
60-66 Nut
No, those are the D369 calipers. The last year for the D52's on the trucks was '87, or '91 for the V and R series
Old 02-19-2012, 03:50 PM   #198
Mr_Rich
Mr_Rich's Avatar
Thanks for that information. I'd love to install Wilwood two piston calipers on my truck. I guess that can't happen...
1989 K1500 Chev. EC
Old 02-19-2012, 11:43 PM   #199
Captainfab
60-66 Nut
If you are talking about the '89 K1500 in your sig, I do have a 6 lug rear disc conversion that uses the D369 calipers.
http://www.67-72chevytrucks.com/vboa...d.php?t=494411
But that does not get you the Wilwood dual piston calipers
Old 02-23-2012, 01:50 AM   #200
Captainfab
60-66 Nut
Has anyone had an issue with the outside pad rubbing on the hat of the rotor with this conversion?
