Old 10-24-2012, 10:56 AM   #176
McJames
McJames's Avatar
Re: Suburban K20 1986 Silverado - "Silvester"
thats makes sense.. how did you go about cutting, molding and fitting?? was it a cheap job? did you modify the plugs? i like the look of your whole retrofit you made. and thanks for the info.. thats probably why they were so cheap..
McJames is offline   Reply With Quote
Old 10-24-2012, 05:23 PM   #177
kikkegek
kikkegek's Avatar
well I choose to go with headlights with metal housing, because when you start cutting a metal housing holds up better. Plastic houses are easier to cut, you can use a Dremel, but will also crack quicker and are less strong and durable.
I took the glass of by putting them in a oven and heating it up, so the glue gets soft and use a screwdriver to open them up.
I used one of these to cut open th back:
I used JB Weld to glue the whole thing together. and used some plastig I had laying around to make the spacer to set the projector a little furhter backwards.
whole cost me about $150,-
bi-xenon projectors
wiring harnass
bulbs 5000k
shipping to netherlands
I already had the ballasts, they will cost yoy anywhere from $15,- a piece, one per headlight, to over $100,- for the real high quality ones.
check out this webstore. That where I got my parts:
www.theretrofitsource.com
great guys and super forum that is very active
kikkegek is offline   Reply With Quote
Old 10-26-2012, 11:47 AM   #178
McJames
McJames's Avatar
awesome. this will be me next project.. i was thinking about doing it to my 1965 c-10 pickup with the round headlights that might be pretty cool. as well as my suburban.
Old 12-25-2012, 05:39 PM   #179
kikkegek
kikkegek's Avatar
did some work at my buddys place (thanks Michiel)
took the dash of
gotta clean this up some time. but not now.
ahhhh... that is why my ventilation is not as wel as it could be
common problem, broken clip that holds the door. now it will never fully close and always let 20-25% warm air in, even when in AC mode. is there an easy fix for this? or only by new clip?
another common known problem is the defrost channels not being connected like in this photo.
another pic
ducttape fix...
I am also adding a extra 10 fuse accesoiry panel and a new ground-bar, just didnt take any pics of that yet.
we went tunnel cruisin on christmass eve. has sort of become a tradition. first we drive though a Den Ilp...an area with lots of nice houses and lots of christmass lights and then we hit the tunnels as loud as we can...talka bout nice contrast.
here are some pics
pics of the tunnel cruise
and heres a youtube playlist of all the movies I took.
enjoy
Last edited by kikkegek; 12-25-2012 at 05:44 PM. Reason: added the tunnel cruise stuff
Old 12-26-2012, 11:06 AM   #180
68Timber
I know the pieces fit
68Timber's Avatar
Funny you passed another square Burb in the tunnel.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-26-2012, 11:12 AM   #181
kikkegek
kikkegek's Avatar
it was actually a Suburban invasion this night. check all movies in playlist
yellow 72 Suburban fro Michiel
I believe a 87 model Suburban (dark blue, 6" lift) from Maarten
flat black 85 Suburban 6.2 Diesel from Rudy
and our 86 K20 Suburban....
Old 01-05-2013, 07:38 AM   #182
kikkegek
kikkegek's Avatar
compression test this morning:
what you guys think?
Old 01-05-2013, 09:52 AM   #183
motornut
78K & 79C Jimmys
motornut's Avatar
gotta love tunnel rumble
neat, havn't seen that kind
me,just a screw in tube with a gauge
that first line on one "low" is that a test/starting point?
i'd try cold and hot
if one stays inconsistant to the others,check it for fouling
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-05-2013, 01:15 PM   #184
kikkegek
kikkegek's Avatar
can you determine engine compression ratio from a compression test
Old 01-05-2013, 01:34 PM   #185
motornut
78K & 79C Jimmys
motornut's Avatar
don't think so,isn't one difference in volume,other is sealing ability?
John
Old 06-23-2013, 09:15 AM   #186
kikkegek
kikkegek's Avatar
I have spent about half a year on researching all kinds of leds for my led tail light project.
recently finished it and here is the result.
I ended up using real Philips Lumileds HPWT orange/red.
tested several board designs:
and ended up using this:
circuit o the back:
in tail light
they are BRIGHT AS HELL
here is the playlist on Youtube to the LED tail lights
http://www.youtube.com/playlist?list...kjVr5Ml8yjt4sN
I love them...
Old 06-24-2013, 12:26 AM   #187
kwin
kwin's Avatar
In regards to the clip on your heater door question. I just did my heater core and came across the same problem. I made a little "L" shaped bracket.i attached it to the side of the plastic bit and the door with industrial strength epoxy. You could screw or rivet to the door as well. Works like a charm! Drill a hole and place the bracket on the head side of the pin.
Keith
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
Old 06-24-2013, 03:48 AM   #188
kikkegek
kikkegek's Avatar
Keith
thanks man, got any pics of that fix of yours?
Old 06-24-2013, 02:07 PM   #189
zaccaglin
zaccaglin's Avatar
circuit o the back:
in tail light
I love them...
Did you home make those or buy them? If homemade would you consider making more and selling them? I know shipping would be crazy tho but those are exactly what I've been looking for.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 06-24-2013, 04:45 PM   #190
kikkegek
kikkegek's Avatar
I home made them myself, because I didnt like the LMC versions and the Dakota Digital version ROCK, but cost $250,-
I have had a lot of requests and I am looking into maybe making a small batch, but first want to see how these hold up...
I would have to design a circuitboard and have those printed in a small batch. That would save me a lot of time.
Old 06-24-2013, 09:27 PM   #191
zaccaglin
zaccaglin's Avatar
Well if you choose to do that put me in line!!! I would love a pair and would be willing to pay. Like you i think the dakota digital ones are a bit overpriced. Or if you choose to do a how to writeup or video that would be awesome. Thanks, Mike.
Zaccaglin
Former Rig:
Old 07-10-2013, 02:07 AM   #192
kikkegek
kikkegek's Avatar
got a good deal on a second hand engine here in the Netherlands:
http://67-72chevytrucks.com/vboard/s...d.php?t=587778
Old 09-19-2013, 01:57 PM   #193
kikkegek
kikkegek's Avatar
finally after three years without I have gotten my hands on a second hand headliner and put it in yesterday. So happy.
not prefectly straight, but 100% better then before.
Old 09-22-2013, 12:26 AM   #194
steve9484844
Headliner looks good, did you add an extra support above the drivers seats? I was just thinking about that to avoid issues down the road.
steve9484844 is offline   Reply With Quote
Old 09-22-2013, 07:08 AM   #195
kikkegek
kikkegek's Avatar
yes I got it with the headliner and still had my own. I also bought two aluminium strips for extra support. The are 2m long and 30mm wide and 2mm thick. I will add pictures later when I have added them. These ceilings are big in the Suburbans and these old headliners needs extra suport.
Old 11-03-2013, 09:51 AM   #196
kikkegek
kikkegek's Avatar
big update.
had the underside of the car treated with Fluid Film three years ago, but the guy did a horrible job. I just redid the wells myself.
look at the rust.
covered the wheel:
final result :
2 coats of ACTION stop rust (dutch product)
1 thick coat of Rustoleum (Combi Color is the Dutch version)
1 thick coat of Brantho Korrux
also painted the core support with some paint I had left over from the wheel wells.
then I wanted to swap the weatherstrips of the cargodoors, but saw the rear cargo floor was all wet
so stripped it all out
bubbles?
bubbles everywhere? is this rust?
so sanded it and checked what was undeneath
thank god no rust, just bubbles in the paint.
nice thick coat of Rustoleum
painted the side of the doors and put the new weatherstrips on.
@#$@#%$W#R# and yes, doors wont close anymore with new strips...took a lot of adjusting the door hinges but now its pretty fine and have to push a little to close them
ordered 10 m2 of Alubutyl in Germany
http://www.alubutyl-24.de/pages/bake...lerpreis-6.php
and applied it to the floor.
then started looking for a affordable rubber flor for the dogs
found it at a local place in The Hague
http://www.haaglanden-rubber.nl/
http://www.haaglanden-rubber.nl/asso...loper_b12.html
cut it to shape with the wheel wells
et voila, a nice rubber floor.
car started wors and wors recently and seemed like either bad batterys of alternator.
had the batteries checked and they both were bad. took two out and placed only one back. I dont need the accesoiry battery since I dont haul trailers. had to do some rewiring.
but still had a bad loading voltage. did some readin and research and seemed like my field connection wasnt connected. The qire was on the alt, but stopped behind the dash.
I remebered I had insulated a hard brown wire under the dash three years ago, because I didnt know what it was for. seems this is the resistance wire for the alternator. reconnected it and the charge voltage is back to allmost 14V now.
was a mess in the front of the car during my search for the charge problem, hahaha
had the shortblock I got this summer bored to 4.030 and honed. and picked it up again
[img][/img]
nice and clean, ready to be rebuild
finaly had some time to pick out some parts for the rebuild.
hope they get here soon.
deciced to go with the CompCams XE250H cam they told me to get...
Old 11-12-2013, 04:20 AM   #197
y5mgisi
Second Chance Program
y5mgisi's Avatar
All that you are doing looks very good!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-12-2013, 04:33 AM   #198
kikkegek
kikkegek's Avatar
thanks man!
Old 11-24-2013, 04:05 PM   #199
kikkegek
kikkegek's Avatar
today we had the first "Dutch Suburbans & friends" meeting and cruise.
had a great time, with great friends.
Old 11-25-2013, 07:41 AM   #200
68Timber
68Timber's Avatar
Awesome!
John
74 Honda Z50 build
