Old 11-29-2010, 09:19 PM   #176
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
To make the proper dimensions for a short bed you need to cut 8 inches out of the back and 12 inches out of the front. The tape I used was 7 and 7/8ths wide apart, allowing for 1/16th blade width on the cuts for 8 inches. 1/8th less on the front cut also. My favorite tool for long straight cuts is a Sawzall with a very long metal cutting blade. Lay it in the metal at a really low angle and it doesn't push/pull the metal back and forth. A 4 inch grinder with a 1/16th thick cut off wheel works almost as well if that is what you want to use.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-29-2010, 09:23 PM   #177
drewskiren
drewskiren's Avatar
Uh Oh, isn't that a little too short?
Drew
Old 11-29-2010, 09:28 PM   #178
VA72C10
VA72C10
VA72C10's Avatar
definitely a clean bed....and the right way to do these projects (find great sheetmetal to start with). Purists will be upset you cut a clean bed but that's the way to assure you have the best product.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-29-2010, 09:35 PM   #179
drewskiren
drewskiren's Avatar
Friday morning arrives and I thought I should take a pic of the tools of the trade.
As I start to clamp it back together I encounter what I expected on the body line at the top no longer lining up. Rokcrln shows what to do in his post, (highly recommended), simply move the metal around to line up and tack a spot. He doesn't cover it, but you should definitely work the 2 parts together from top to bottom. If you were to tack it in the middle or down at the bottom you can end up with a pooch in the metal somewhere in the middle of the panel. Take your time and don't heat the metal too much with several close welds in quick succession.
Drew
Old 11-29-2010, 09:41 PM   #180
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! That was a super nice bed! That will be nice to know in 10yrs after the truck is done what you actually started with. Is that just aluminum speed tape you used?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-29-2010, 09:42 PM   #181
drewskiren
drewskiren's Avatar
The stiffest part of the bed is the bed corners, so I started there knowing that area is a constant.
Next I lined up and tacked the top bed rail, then the inner bedsides. Last will be the outer skin that I will need to wingwarp around to make it look right. Remember to go top to bottom
Drew
Old 11-29-2010, 09:48 PM   #182
drewskiren
drewskiren's Avatar
I can't tell you how fired up I was when I cut it open!
Not sure what Speed tape is, I just pick this stuff up on my jobsites, it is a metallic tape my HVAC contractors use to seal the ductwork in my houses . I love this tape, super sticky, forms well, and the price is icing on the cake. I just wish they would leave more.
Drew
Old 11-29-2010, 09:57 PM   #183
drewskiren
drewskiren's Avatar
Night time on Friday. Whew!
One thing I forgot to mention was that while I had the bedsides wide open, I went ahead and undercoated the stink out of them up inside just for good measure. When else would I have such a golden opportunity??? That's what the black spray is on the edges.
Mostly tacked back together now.
I used the orange straps to pull the parts together to get the tight spacing for a weld. You need about 1/16th space when butt welding for good penetration.---- Heh Heh, he said butt.
Drew
Old 11-29-2010, 10:04 PM   #184
drewskiren
drewskiren's Avatar
Here is a pic of what happens on the bottom edge at the rear as you work the body line out to match up. I will simply trim this as a long straight line later.
I figured out later that it is best to make most of your welds, but not solid. Wait until after you grind them down the first time to fill in completely with solid tacks. The problem is that when you have small mounds of tacks and you try to aim for that 1 last hole, you end up welding on top of a weld and that just makes more you have to grind off later.
Drew
Old 11-29-2010, 10:35 PM   #185
drewskiren
drewskiren's Avatar
AHHHH grinding. I promise its much more fun on the dance floor.
This is the pits, but must be done slowly and randomly to NOT heat up the metal. If you see blueing, stop! Move on to another area and try not to do it again.
Drew
Old 11-29-2010, 10:36 PM   #186
classicchev
classicchev's Avatar
HAHA, your shop looks like mine. Woodworking stuff and materials scattered behind poly. Im a contractor also, my shop doubles as a cabinetshop, spray booth and a place to work on my crap.
Looking good, the more I look at this , the more I want a 67 72 crew, instead of a 79....
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 11-29-2010, 10:37 PM   #187
drewskiren
drewskiren's Avatar
I ground some on Saturday (5 hours) and about the same on Sunday after church. I am nowhere near finished. I am grinding and then welding up holes as I find them, then grinding some more. Now I understand to try for better, smoother welds. This is my first real welding job, so cut me some slack.
Drew
Old 11-29-2010, 10:46 PM   #188
drewskiren
drewskiren's Avatar
Cool Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Darren
You know you want it baby!
Drew
Old 11-29-2010, 10:49 PM   #189
Dieselwrencher
Nice work! Keep at it. When I used to work in a body shop, my old boss always had us grind down the welds with a cut off wheel because it heats up the panel less and you have more control on top of the welds. It did seem to work better after I tried it.
Ryan
Old 11-29-2010, 10:49 PM   #190
drewskiren
drewskiren's Avatar
I couldn't stand it, I had to see what it looks like.-- An Arizona tailgate on a California bed!
Drew
Old 11-29-2010, 10:50 PM   #191
brn agn
brn agn's Avatar
Here is an idea for you (if you have not tried it yet). I have found that grinding the welds down with a thin cutting disc on the angle grinder will prevent the metal from getting overheated. After I get the welds close to level, I finish them off with a flap disc. It may be worth a try to see if you like it better. Either way, you end up digging black stuff out of your nose and ears for the next few days!
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 11-29-2010, 10:52 PM   #192
Strut
Strut's Avatar
These would have made that alot easier....
Amazon.com: Northern Industrial Butt Weld Panel... Amazon.com: Northern Industrial Butt Weld Panel...
I use them alot myself... Work really well.
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 11-29-2010, 10:58 PM   #193
drewskiren
drewskiren's Avatar
Red face Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Bound to make it slower, but safer. I'll try it out, thanks.
Drew
Old 11-29-2010, 11:00 PM   #194
drewskiren
drewskiren's Avatar
Amazon.com: Northern Industrial Butt Weld Panel Clamps - 4-Pc. Set: Home Improvement
I have these, but grew tired of fiddling with them. If you look closely you can see them in the bed. A real pain to put together. A flat magnet or a prying screwdriver were faster and easier.
Drew
Old 11-29-2010, 11:25 PM   #195
Strut
Strut's Avatar
Yeah, I know what you mean... They're good for holding the metal though.
1972 Chevy C10 SWB
2008 Yamaha R1
Old 11-29-2010, 11:55 PM   #196
Dieselwrencher
At first I thought it would be slower too. Once I got the hang of it I could move the cut off tool up and down or side to side and take off the high spots and then level it out. It actually goes along pretty fast. Like already mentioned, those flap discs are pretty sweet for finishing it off. I grind everything with flap discs anymore it seems like.
Ryan
Old 11-30-2010, 12:08 AM   #197
drewskiren
drewskiren's Avatar
I have flap discs in the picture, just haven't ground down far enough to use them yet, still finding holes to weld up. I need to finish up quick, I'm ready to move on to the next phase.
Drew
Old 11-30-2010, 01:01 AM   #198
67chevy1series
67chevy1series's Avatar
that looks sweet so are you putting top and bottom trim on
67chevy1series is offline   Reply With Quote
Old 11-30-2010, 01:12 AM   #199
drewskiren
drewskiren's Avatar
Yes I am. Should look something like this.
Drew
Old 11-30-2010, 01:12 AM   #200
Dieselwrencher
One question I have just because I'm curious, that's all. What is your plan to get the body line straight on the rear section where it doesn't line up? I'm guessing cut and weld? Post #183, last 2 pics.
Ryan
