Old 04-28-2011, 08:24 PM   #176
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Again bad pic, but you can see how it lined up. I had also welded in pieces on the door post to make it flush with the main piece.
oldman3 is offline   Reply With Quote
Old 04-28-2011, 08:26 PM   #177
oldman3
oldman3's Avatar
Here I've installed the power window kit (Juliano's), made a wood template and checking how it works up and down.
Old 04-28-2011, 08:28 PM   #178
oldman3
oldman3's Avatar
Another short post today, tomorrow we go to the bed, with lots of modifications and about 30 pics.
Old 04-29-2011, 09:35 PM   #179
oldman3
oldman3's Avatar
Sorry getting on so late, had things come up, anyhow I've moved to the back of the bed, to start working on the taillights. This is the stock stack pocket on the 54 bed, 47-53 are different.
Old 04-29-2011, 09:36 PM   #180
oldman3
oldman3's Avatar
I cut out the pocket to this shape for my lights.
Old 04-29-2011, 09:40 PM   #181
oldman3
oldman3's Avatar
Pic 1 I made up this holder that will be welded to the stack pocket. The taillights are 3rd brake lights that I relamped and rewired for running, turn and brake lights. (lights were purchased from J.C. Whitney) The plastic housing for the lights were drilled and screwed to the holder, so they don't move.
Pic 2 Welded to the pocket and lights installed.
Old 04-29-2011, 09:41 PM   #182
oldman3
oldman3's Avatar
A good view of lights from the back and also the roll pan that will be added.
Old 04-29-2011, 09:43 PM   #183
oldman3
oldman3's Avatar
New tail gate in position. I bought this at the body shop for a 87 pickup with no Chevrolet in center, at a cheap price.
Old 04-29-2011, 09:45 PM   #184
oldman3
oldman3's Avatar
This is at the front of bed, where I made a plate to weld up the open end on rail, a new front panel from Classis Parts.
Old 04-29-2011, 09:47 PM   #185
oldman3
oldman3's Avatar
Removing old paint from outside of the bed. Drivers side in fair shape, but the passenger side had a "tin can" effect along the whole panel. Lots of heat shrink work to get it right.
Old 04-29-2011, 09:49 PM   #186
oldman3
oldman3's Avatar
All body work done to most of bed and primered. Anyone who has worked on these beds, knows how hard it is to get them decent with the thin one wall bed. Still working on the rear section.
Old 04-29-2011, 09:51 PM   #187
oldman3
oldman3's Avatar
I love the original design in the 54 and 55 1st. series bed sides.
Old 04-29-2011, 09:55 PM   #188
oldman3
oldman3's Avatar
Pic 1 This is the old rear cross sill piece for bed, was in bad shape so I purchased a new one.
Pice 2 New piece welded in place, also added a 3/16" steel piece inside the gate piece and extended to the bottom of the panel on an angle.
Pic 3 New panel installed, had to cut the opening to clear the roll pan.
Old 04-29-2011, 09:57 PM   #189
oldman3
oldman3's Avatar
Pic 1 Roll pan all welded to the back panel.
Pic 2 Side view of roll pan, welded to the bed.
Old 04-29-2011, 10:00 PM   #190
oldman3
oldman3's Avatar
Pic 1 This is normally how the stack pocket looks and some people leave it like this.
Pic 2 I wanted mine different. Here I drilled a hole to feed wires through for the taillights in stake pocket.
Old 04-29-2011, 10:03 PM   #191
oldman3
oldman3's Avatar
Not shown, but I made up a wood piece the shape I wanted. Traced the three shapes to sheet metal. Here the back piece is installed with a slight arch. The front piece comes straight down.
Old 04-29-2011, 10:06 PM   #192
oldman3
oldman3's Avatar
Pic 1 This view shows the final center piece installed.
Pic 2 View from back, shows how it curves to meet the roll pan
Pic 3 A look at the whole rear set-up.
Old 04-29-2011, 10:09 PM   #193
oldman3
oldman3's Avatar
Pic 1 How the tail gate latch and hinge is set up. Purchased from WOW Products.
Pic 2 Another view in open position.
Pic 3 Also made a plate for open end of back rail. Was going to radius the corner, didn't, and now I wish I had.
Old 04-29-2011, 10:13 PM   #194
oldman3
oldman3's Avatar
Pic 1 This is how most repop tail gates look. They need lots of TLC to correct.
Pic 2 For me it was easier to weld a plate to cover the whole thing, and it make it smooth on the inside.
Old 04-29-2011, 10:14 PM   #195
oldman3
oldman3's Avatar
Rear stake pocket, all smoothed and primered.
Old 04-29-2011, 10:16 PM   #196
oldman3
oldman3's Avatar
Pic 1 Now you can see how it all blends together, with body work done and in primer.
Pic 2 View from rear all primered.
Old 04-29-2011, 10:19 PM   #197
oldman3
oldman3's Avatar
With the tail gate down, if you look real close at the side of tailgate. The inside part has been welded and smoothed out.
Old 04-29-2011, 10:21 PM   #198
oldman3
oldman3's Avatar
Well this was months of work, maybe it kept you busy 5 mins looking at the pics. Hope you enjoyed, any questions just ask. Jim
Old 05-01-2011, 08:12 AM   #199
Indian113
Indian113's Avatar
Your pictures make it look easy,wish I had your fab skills
Indian113 is offline   Reply With Quote
Old 05-01-2011, 09:39 AM   #200
oldman3
oldman3's Avatar
Thank you for the kind words. I'm not to bad, but lots of people are a whole lot better. I was told a long time ago " if it's metal, and you make a mistake, cut it out and do it again". Kind of hard words to learn by, but it sure helped me. Jim
