Old 08-22-2013, 02:55 PM   #176
Sammy
Re: Project 67
Aug 2011 was my start date. I have more patience than I have dead presidents. So I have to go slow n easy.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-22-2013, 11:46 PM   #177
Sammy
Re: Project 67
Cab n doors now two toned. Wheel n column got it's share also. Every bug in the state visited me during the paint process.
Found a unbeliveable mouse nest inside the old heater. Didn't know a rodent could pack so much stuff inside such a small area. All in told 8 hand fulls of cotton n paper.
Old 08-23-2013, 12:19 PM   #178
firedog
firedog's Avatar
Re: Project 67
Looking good!
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 08-23-2013, 02:42 PM   #179
Gus350
68 C 10
Gus350's Avatar
Re: Project 67
I'm liken that two-tone
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 08-23-2013, 05:13 PM   #180
Sammy
Re: Project 67
Heater boxes, floor vents, E-brake handle, wiper rods, n other misc stuff received a make over.
Old 08-23-2013, 06:49 PM   #181
knomadd
knomadd's Avatar
Re: Project 67
That looks much better with the white roof.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-25-2013, 06:29 AM   #182
firedog
firedog's Avatar
Re: Project 67
guess I need to make time to come down there and help get the cab back on the frame so you can play with the bed now
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-26-2013, 10:42 AM   #183
Sammy
Re: Project 67
The replacement driver's side bed is in 2K along with the cab cowl ready for final paint. The two front fenders are close to ready for primer also. Surprisingly, wasn't as bad as I remembered. Close to working on the bed soon. Possible to have the major paint finished except for touch up before the first freeze. Currently the humidty is above 50% staying around 56% much too high for getting good results. And painting late at night isn't worth the effort in my redneck operations.
Old 08-26-2013, 10:50 AM   #184
TXPinstriper
TXPinstriper's Avatar
Re: Project 67
Lookin sharp....
TXPinstriper is offline   Reply With Quote
Old 08-26-2013, 11:15 AM   #185
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Project 67
I agree. The paint looks really nice!
--Josh
Old 08-26-2013, 11:22 AM   #186
Sammy
Re: Project 67
Anyone know anything about Dophin Fuel gages? Thinking I would like one of these setups but not interested if it requires changing the sending unit in my Boyd tank.
http://www.ebay.com/itm/260334771608...84.m1438.l2649
Old 08-26-2013, 02:15 PM   #187
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Lightbulb Re: Project 67
Should work fine.
On the fuel sending unit you know it just needs to be 90 ohms. The meter does not care only the sending unit itself is what controls the signal.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 08-26-2013, 05:15 PM   #188
Sammy
Re: Project 67
Yes, just trying to confirm their gauge is 90 ohm or something different. I know some have used their gauges curious if they will work on a 90 Ohm sender.
Old 08-26-2013, 09:20 PM   #189
C20-67_N_MO
Exclamation Re: Project 67
In that case, I'd be using that "Ask a Question" link on that auction. If spending that kind of money on it it's part of their job to know what it does and doesn't work correctly on.
Good luck!
Old 08-27-2013, 10:14 PM   #190
Sammy
Re: Project 67
After some research. I found out the setup does use a 90 Ohm sending unit. However from what I have read their was a issue with lighting on some of the setups. But don't know if that issue was ever solved. The eye appeal is good, price isn't out of line, but functionality is also important. So I will remain open on other ideas at this point.
Ordered another gallon of 2K primer, front clip should get primer this weekend. Holding off on the beige until the heat and humidty returns to managable standards again.
Old 08-28-2013, 09:32 AM   #191
C20-67_N_MO
Re: Project 67
Okay let me drift off your topic here for a minute.
What's your power-plant going to be? Mind you I only skim over the topics and may have forgotten if you said so previously.
Mild little SBC Gen I or you going computer controlled engine, or is that V-6 still on the table?
Old 08-28-2013, 03:29 PM   #192
firedog
firedog's Avatar
Re: Project 67
he has a freshly rebuilt 283 with 5.7L vortec heads, gm factory serpentine setup, a holley 650 carb, looking for an aftermarket intake currently to put on it.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-28-2013, 04:43 PM   #193
Sammy
Re: Project 67
Planning on 4 core Rad with dual electric fans w/ custom shroud similar to what is in the GMC. Tranny wise depends on what shows it's tail first Turbo 350 or an older powerglide.
Old 08-28-2013, 04:48 PM   #194
Sammy
Re: Project 67
Talking real fresh..
Old 08-28-2013, 11:35 PM   #195
sduckworth13
sduckworth13's Avatar
Re: Project 67
Trucks coming along nice, cab looks great.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-29-2013, 09:15 PM   #196
Sammy
Re: Project 67
Thanks for the comments. Not perfect by no means but decent with a lot of man hrs so far.
Today sorted a cab wiring harness out repaired some bad places but over all now decent. Also assembled both doors of windows, completely rebuilt the wings yesterday (one the hardest things for me to do). Leaving only the swipes and inner door panels. During operational check of the driver's door the window regulator started acting up. It will need replaced when I get the parts. Passenger side works smoothly.
Received a package with another gallon of 2K primer to finish up the truck. Possible to get a couple of coats on the two front fenders. Pop's is going to fill the GMC molding holes with welds tomorrow. Weather man claims a heat break mid week next week to low 80's. Will try n shoot the two front fenders, cowl n hood. Then attempt to start on the 6 ft bed. Soon as I can get some help moving cab n stuff around anyway. First indications are some serious repair around the external right rear wheel well. Already have the driver's bed side in primer for a swap. Looking at three weeks work on the bed inside n out at least.
Old 08-30-2013, 04:08 PM   #197
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project 67
Sammy, nice progress. Are you guys going to the Nats this year?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-30-2013, 07:24 PM   #198
Sammy
Re: Project 67
Thanks. Not this year. I really hate missing it too becoz we always have a great time too.
Got the first of the 2K primer on the front fenders today. Pops done a great job on welding the trim holes. It needs a 2nd coat after some light sanding.
Old 08-30-2013, 10:29 PM   #199
firedog
firedog's Avatar
Re: Project 67
Im trying to get away to come help but 102 degrees doesnt allow for much outside work when you are spoiled with a job that makes you sit in the AC for 12 hours a day.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-31-2013, 11:53 AM   #200
C20-67_N_MO
Nice fenders! As always looking great.
I heard that.
Kinda like to 'rough' it a bit outside any chance I can get to be out in ANY garage and in any temperature since I don't have one myself.
