#176 |
Re: How about some pics of bagged 60-66
Got it figured out! Shocks are on the way now from O'Reilly's. They are shorter than stock for the rear. I'm mounting my lower shock to the rear end, you did yours to the control arms. As far as the front goes I'm going to use the stock shocks but move the upper mount to the top of the frame, and bolt the lower shock point to the outside of the stock shock mount location (i'm going to reinforce to lower mount) to give me clearnce from the brake line mount. It hits it when aired out. I'll post pis soon. Hoping to have the rear done tonight!
Jason |
#177 |
i just noticed i never really took any good pics of how my rear shocks are mounted but here is one pic
![]() if you bought shorter shocks than factory and you plan on mounting them to the rear end i believe they are gonna limit ur upward movement.. i think my truck has like 13 or 14 inches of travel at the rear end... way more than the trucks with the bags mounted at the rear end
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#178 |
chevy only
![]() Join Date: Sep 2006
CHEVY ONLY... Nothin Else ! |
#179 |
chevy only
#180 |
chevy only
64 dually getting closer
#181 |
dino thats turning out to be one bad ass dually
#182 | |
Stirrer of the Pot
no joke, the first thing i noticed was an insane amount of lift ![]() |
#183 |
I would greatly appreciate it if some of you that Z'd your frame could take a picture of how you mounted your radiators, that would help me out a bunch! I'm trying to figure out how to make my radiator fit but I'm afraid to do anything because I don't have the motor or Trans in and its been so long since I took it out I can't remember where everything goes. I've lowered the front horns just in front of the radiator support but now the radiator is way too high to close the hood. I've searched like crazy and either people are putting custom radiators in or they did something different that I'm doing. Either way I'd really appreciate some help. Thank you
Posted via Mobile Device |
#184 |
Stirrer of the Pot
i found that the radiator in my '62 did not fit the horns on my '68 frame, the frame seemed to be about 1/2" too narrow. I was going to just notch the frame a tad so the radiator would sink into the horns, could you do that? In the end, I did nothing. the radiator sits high, but the hood closes...
#185 |
I also thought about that but I wasn't sure if doing that would cause problems with the power steering.
#186 |
The best picture so far!
Hope to get the front clip on soon! |
#187 |
killer patina!
#188 | |
![]() Join Date: Aug 2010
----------------------------------------------- "I wanna be like Dino when I grow up" |
#189 |
this is my 1963 c10 it is going to get bagged soon. and a rat!
hope it fits in with all of these get trucks. ![]() |
#190 |
#191 |
thanx man!!!
#192 |
Getting close!
#193 |
Chevy Only Tx
I really dig your truck^^^^
Chevy Only Tx......... |
#194 |
My Goldie..Body dropped and bagged
Nicknamed the Hussy... |
#195 |
![]() Join Date: Dec 2008
#196 |
#197 |
The bed is just some plywood, two pieces, so I can get to the gas and air tank and other components. It is just using some metal strips that were originally there and some that were welded in that the plywood sits on. The plywood has a little clamp that ties them together so they don’t jump out. I am thinking of sanding and clearing the plywood right now it is just untreated. I can post some more pics when I get home.
#198 | |
C10 CLUB Y QUE!
#199 | |
#200 |
Very clean,..
