Old 04-01-2013, 11:41 PM   #176
Desperado454
Desperado454's Avatar
Re: Parked Indefinite
Originally Posted by 6772owner View Post
Man that truck is awesome, great work!
Originally Posted by KevinD85 View Post
love the truck.
would love to do that one day
Thanks guys!
Flipped the box on today and as expected I'm going to have to lower the sides down/raise the floor. Have an idea of what to do and will hopefully get started tomorrow
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 04-02-2013, 05:44 AM   #177
dustnx
dustnx's Avatar
Amazing work so far man, I've read every post from the beginning, you have awesome fab skills!!! Will be subscribing !! Keep up the awesome work
Dustin
Current Projects:
79' Chevy C10 SWB - 454BBC with TH350 tranny. just a few mods. LOTS of work in progress!!
89' Pontiac Firebird - 350SBC swap with 700R4, few bolt ons. On back burner for now. (Daily Driver)
dustnx is offline   Reply With Quote
Old 04-02-2013, 04:17 PM   #178
Desperado454
Thanks!
One side down
'28 Model A Build
-Brooks
Old 04-02-2013, 08:12 PM   #179
canadian trucker
A day should have 30 hours.
Sick, priceless and speechless. Can't think of any other words.
Oh wait..... Awesome.
canadian trucker is offline   Reply With Quote
Old 04-02-2013, 11:53 PM   #180
Desperado454
Right arm, appreciate it man!
Rounded out the day by dropping the driver side and bulkhead down to match the rest. I thought this was going to be a bit of a job, but turned out to be piss easy! Few pics:
'28 Model A Build
-Brooks
Old 04-11-2013, 10:59 PM   #181
96twodoor
96twodoor's Avatar
looks great man
96twodoor is offline   Reply With Quote
Old 04-11-2013, 11:34 PM   #182
MalibuSSwagon
Big enough exhaust for ya?!
MalibuSSwagon is offline   Reply With Quote
Old 04-12-2013, 07:21 PM   #183
bohmankid
bohmankid's Avatar
This is the type of thread that gets other guys out to work on their trucks.
Wow, great job. Tons of custom work. I'd like to see a vid of this going down the track!
bohmankid is offline   Reply With Quote
Old 04-15-2013, 09:08 AM   #184
Hertzdaddy
Wake up, wave magic wand, presto, bedsides dropped! Or is there more to it than that? Do tell or post pics please.
Hertzdaddy is offline   Reply With Quote
Old 04-15-2013, 04:45 PM   #185
83swb
Looks like he just separated the floor and tubs from the bedsides and raised the floor and tubs as one piece.
83swb is offline   Reply With Quote
Old 04-15-2013, 06:40 PM   #186
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm guessing he cut the inner bedsides at the lip where the floor bolts, and removed x amount and welded the lip back on. Then did the same to the front bed panel. That's just my guess though.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-16-2013, 11:28 AM   #187
N2TRUX
Happy to be here
N2TRUX's Avatar
Details on the bed floor please.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-16-2013, 01:42 PM   #188
Desperado454
Sorry for the lack of update guys, just hasn't been much progress to share. Anyways, as far as the box raising, I decided to move the floor up 3.5" so it would be even with the body line on the inside of the box. Even though I only had a body channel of 2" to deal with, the extra 1.5" gave me some extra room underneath for exhaust, fuel cell, axle, etc. Also it made it so the wheel tub would land on the upper body line inside the box. Just had to make some 1.5" risers which you can see here:
Back to the box itself, I wanted to avoid welding along the entire length of the box side, so when I just drilled new holes 3.5" up from the old ones. On the uppermost holes, where you can't reach underneath to put a nut on, I just welded nuts where they needed to be:
For the bulkhead i bought some 1/4" x 1" flat bar to make up for the gap that occurs when you lower it down the 3.5'". I drilled and tapped the bar to correspond to the holes in the box floor and drilled bigger holes in between so I could plug weld the bar to the bulk head. Here's a pic of it bolted back in place with the bar in between:
I was going to do the same thing with the gaps in between the tubs, but haven't got around to doing it yet, but here's a pic the shows the bar better:
Last thing I had to do was cut a square section out of the floor at the back so the box sides could slide down. Didn't get a pic of that unfortunately, but maybe you can see it in this pic:
Hope that clears it up!
'28 Model A Build
-Brooks
Old 04-16-2013, 01:43 PM   #189
Desperado454
Did a little bit yesterday actually. I painted the bottom of the hood, and in between the bulkhead and cab:
'28 Model A Build
-Brooks
Old 04-17-2013, 12:14 AM   #190
Desperado454
Started making a filler door for the fuel cell. Found an old cabinet hinge and decided to use it. Still have to finish the lid part, but here's what I got done:
'28 Model A Build
-Brooks
Old 04-17-2013, 01:54 AM   #191
bilfman
bilfman's Avatar
Your build is so killer! Can't wait for the first burnout vid, I'll post my dually burnout right after
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-17-2013, 01:57 AM   #192
maxxxy
maxxxy's Avatar
Nice work on the bed!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-17-2013, 08:28 AM   #193
Greenlee
Greenlee's Avatar
Nice work! I like that you still have a usable stock looking bed, unlike many that you see on here.
Greenlee is offline   Reply With Quote
Old 04-17-2013, 11:21 PM   #194
Desperado454
Hmm...could be interesting
Thanks!
Think I'm pretty much done with the fuel door, though I might try to even out the gaps a little more. Here's how it came out:
'28 Model A Build
-Brooks
Old 04-17-2013, 11:53 PM   #195
maxxxy
maxxxy's Avatar
I'm really digging the fuel door. How do you get it opened without prying up on the edge?
Max
Max's bagged 81
Old 04-18-2013, 09:10 AM   #196
Hertzdaddy
Originally Posted by greenlee View Post
nice work! I like that you still have a usable stock looking bed, unlike many that you see on here.
posted via mobile device
x2
Old 04-18-2013, 11:04 AM   #197
Bomp
Bomp's Avatar
Nice job on the fuel door mod.
Your moving along quickly and will be on the road soon.
Bomp is offline   Reply With Quote
Old 04-25-2013, 01:05 AM   #198
Desperado454
You got me! I haven't quite figured that part out yet, but for the meantime i just have a magnet on it. Something to grab on to for now, but easy enough to take off when I know what I'm going to do
'28 Model A Build
-Brooks
Old 04-25-2013, 01:10 AM   #199
Desperado454
x2
Thanks man!
'28 Model A Build
-Brooks
Old 04-25-2013, 01:11 AM   #200
Desperado454
Thanks Bomp! Hoping to be driving this thing soon!
'28 Model A Build
-Brooks
