Old 12-10-2014, 01:31 AM   #176
steve aleve
Re: You guessed it, 1950 s10 swap.
Layedout, did you have to cut the corvette coil cover to fit behind the alternator? I just picked up an alternator and it interferes with the plastic cover. I don't want to cut it if there is another way. Thanks!!
steve aleve is offline   Reply With Quote
Old 01-05-2015, 12:40 AM   #177
Layedoutsonoma91
Layedoutsonoma91's Avatar
Sorry I havent been on lately. Been busy with other projects and work. I have not got a trans for it yet. I am going to be getting one in Feb. (with taxes). The tire size is 205/75/r15
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 01-05-2015, 12:41 AM   #178
Layedoutsonoma91
Yes i had to cut the cover to fit....... sucked but had to do it.
6.0 ls swap/4l80e
Past build thread
Old 01-05-2015, 07:12 PM   #179
steve aleve
Right on. It seemed like that was the only way but I just wanted to make sure I wasn't missing anything. Thanks!
Old 01-12-2015, 08:06 PM   #180
HULK64
Layedout- GREAT build and super informative. Thanks for being so willing to answer questions!
A couple for you when you have time:
I am assuming you used a long bed frame- why did you have to move the front leaf spring mount forward?
Did you go with the cantilever setup from low rider depot? Which bags? Anything else you would recommend with that kit? What bags did you use in the front? Did you burn it in, or just bolt it?
What air management system did you end up with?
What fuel pump did you end up using to make the LS motor have enough pressure?
HULK64 is offline   Reply With Quote
Old 01-12-2015, 10:21 PM   #181
Layedoutsonoma91
The leaf springs were moved backwards to keep them from dragging the ground.
I got the LRD 6 link with airlift 2700 bags
the front you want as big a bag as you can fit, i got 2600 in the back.
you have to cut the pocket in the front out and bolt in a cup. then bolt bag to the cup.
I got a fuel pump for a syclone that goes into the tank. Then i have a corvette fuel filter for a return.
6.0 ls swap/4l80e
Past build thread
Old 01-18-2015, 10:06 AM   #182
HULK64
Awesome- thanks!
Did you have to do anything to the 6 link to adjust the wheelbase to get the wheels centered in the wells? How adjustable is the kit? Looks like you got it pretty well installed before getting the fenders placed- were you able to fine tune once installed?
Are you using drop spindles or was your body drop enough?
Are you going to put in a bed? Curious how much bed space you have left with the notch.
Did you go with a full management system or just manual adjustment and gauges?
Old 01-20-2015, 12:20 AM   #183
Layedoutsonoma91
I set the suspension first because i knew the wheelbase of the 1950 was 115 roughly so i matched that with the s10 base, then i mounted the body to center the tires in the wheel well. The kit i got is pretty adjusatble as far as pinion angle, but the location is pretty much standard on the kit.
I do have drop spindles, not sure where it would sit without them. I would imagine having to notch the frame for tierods if i didnt have the spindles.
I started on a wood bed, but since i have thos fenders in there, the wood work was proving too much for my skill set. Gonna have to get some help there.
I basically built my own airride kit. I got the size tank i wanted, got an air zenith compressor. Then got accuair valve block. I used AVS digital gauges, and a AVS switch box. Just got the valve block to eliminate as many leak points as possible. Plus it was so easy.
6.0 ls swap/4l80e
Past build thread
Old 01-20-2015, 09:03 AM   #184
HULK64
Thanks!
2" drop spindles?
Are you happy with having manual adjustment of your bags? I have heard that some guys have trouble keeping their tires wearing right since ride height always changes a little bit. Ever thought about having a management system with height sensors etc?
Old 01-20-2015, 09:25 AM   #185
Layedoutsonoma91
They are 2 '' drop spindles.
I have had air ride on many vehicles and just come to expect premature tire wear. I got it aligned at a certain psi and try to get as close to that as i can. Seems to work well.
6.0 ls swap/4l80e
Past build thread
Old 02-19-2015, 02:57 PM   #186
whodatfan
Love that color with the slight patina. Did you pick up the body in that good condition, or did you body work it and do the paint/patina yourself?
whodatfan is offline   Reply With Quote
Old 02-19-2015, 03:48 PM   #187
whodatfan
Nevermind. Went back and saw you picked it up off of the original owner. Great find.
Old 02-19-2015, 11:26 PM   #188
Layedoutsonoma91
haha thanks man. I haven't done any body work except the floors and under carriage.
6.0 ls swap/4l80e
Past build thread
Old 02-20-2015, 09:49 AM   #189
whodatfan
If you dont mind me asking, how much did you have to give for the truck? I found a 49 in about as good condition in the same exact color, but they want way more than I want to spend just for the body.
Old 02-22-2015, 11:32 PM   #190
Layedoutsonoma91
Thats nice, i paid more than i wanted to for mine. But it ran and the body was perfect. Only minor rust and the only floor rust was a flat piece that i welded in in like 10 mins. I would say that truck is worth 4500 bux around here, they are going up steadily.
6.0 ls swap/4l80e
Past build thread
Old 06-12-2015, 12:06 AM   #191
Layedoutsonoma91
Made it to one of the stops on the hotrod power tour, found some pics of the truck online. Thought I would share!
6.0 ls swap/4l80e
Past build thread
Old 06-12-2015, 08:28 AM   #192
51Chevy3100
WOW, That's awesome!
1951 3100 Patina "Under Construction"
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=636116
87 V30 1 ton Mud Truck
51Chevy3100 is offline   Reply With Quote
Old 06-12-2015, 10:58 AM   #193
99 to Life
99 to Life's Avatar
nice shots
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-23-2015, 09:20 PM   #194
CodyHicks
CodyHicks's Avatar
Love this truck.
97 GMC Sonoma, bagged, bodied and SBC
94 S10, bagged, bodied, chopped, sectioned & 6duece SBC
50 Chevy, project- bag and LS swap
Build thread for '50 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=656807
CodyHicks is offline   Reply With Quote
Old 09-03-2015, 06:46 PM   #195
Layedoutsonoma91
Originally Posted by CodyHicks View Post
Love this truck.
Thanks man! its going to a buddies shop next month to get a bunch of bead rolled panels and inner fenders made, Gonna swap to manual brakes too since the booster and master cyl. are giving me trouble. Tried replacing everything else. since it weighs so little and I got all disk brakes, i figured it would be fine.
6.0 ls swap/4l80e
Past build thread
Old 09-04-2015, 03:49 PM   #196
Wtdevil
Love this truck too!! Quick question what gear ratio are you running In the rear? I'm in a middle are building one and need to get a 4wd rear and trying to figure out what ratio to run with a ls swap.
Wtdevil is offline   Reply With Quote
Old 09-04-2015, 04:03 PM   #197
Layedoutsonoma91
I am Not 100% sure but it came out of a 98 four wheel drive blazer. If I had to guess I would say 342 s
6.0 ls swap/4l80e
Past build thread
Old 10-06-2015, 05:43 PM   #198
big_moss
big_moss's Avatar
truck came out awesome man very informative thread for sure thanks for sharing.
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 10-08-2015, 04:49 PM   #199
84blaze
Just came across this one. Looks awesome!
I remember your S10 from S10forum.
84blaze is offline   Reply With Quote
Old 10-12-2015, 08:50 PM   #200
Layedoutsonoma91
Thanks. Yeah i was on the forum for years. Graduated to the older school haha
6.0 ls swap/4l80e
Past build thread
