Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-27-2015, 11:15 PM   #176
RedRoad
RedRoad's Avatar
Re: 72 K30 Build
Ive seen guys put 3 or 4 car batteries in series and weld broken frames on the trail in a pinch.
RedRoad is offline   Reply With Quote
Old 01-28-2015, 12:02 AM   #177
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Ok, i hope you didn't take my post badly as i didn't mean to come off in a bad manner, i know when it comes to body i can't weld for crap. i probably wouldn't have posted that at all but your comments about nipples and scar tissue earlyer made me feel you wouldn't get upset about it.
EDIT, Overhead welding isn't easy, i suck at it.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-28-2015, 01:51 PM   #178
7dee2
7dee2's Avatar
Re: 72 K30 Build
No kidding that's resourceful! I wouldn't have thought there was enough current, good to know.
No worries and yes I was pocking fun at us it looked like a tumor was forming!
You know he did have to listen to me whine when I saw it and we had a little talk about trying to keep weld puddle down.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-28-2015, 02:05 PM   #179
7dee2
7dee2's Avatar
Re: 72 K30 Build
A shot of weld thru and we’re ready to screw them into place for the final time.
Brett
Old 01-29-2015, 01:31 PM   #180
7dee2
7dee2's Avatar
Re: 72 K30 Build
Goodbye pass thru, upper is ready to weld.
Brett
Old 01-29-2015, 01:42 PM   #181
7dee2
7dee2's Avatar
Re: 72 K30 Build
I just hope I can get my grips back from there. If not then I’ll cut’em off and fish the pieces out.
Brett
Old 01-29-2015, 11:18 PM   #182
mjensen
mjensen's Avatar
Re: 72 K30 Build
Looking good Brett! I'm hoping to get something going this weekend...
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-29-2015, 11:46 PM   #183
Trekster
Trekster's Avatar
Re: 72 K30 Build
Great work! I'll be watching this build.
Trekster is offline   Reply With Quote
Old 01-29-2015, 11:49 PM   #184
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Inspiring work, makes me think i may be able to do it myself if i ever get to that point with my current progress..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-30-2015, 12:59 PM   #185
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Mike you going to make some more linkage progress? I updated your thread with an idea.
Thanks Trekster.
I'm sure you can especially if the opening doesn't go too far into the roof area.
Brett
Old 01-30-2015, 01:07 PM   #186
7dee2
7dee2's Avatar
Re: 72 K30 Build
1st round weld, weld, weld.
Brett
Old 01-31-2015, 02:27 AM   #187
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Knocking it out!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-02-2015, 11:56 AM   #188
7dee2
7dee2's Avatar
Re: 72 K30 Build
Knocking it out!
Thanks man.
Brett
Old 02-02-2015, 11:57 AM   #189
7dee2
7dee2's Avatar
Re: 72 K30 Build
And weld some more. We did manage to get the grips backs without cutting them. A telescoping magnet was the ticket!
Brett
Old 02-03-2015, 11:02 AM   #190
7dee2
7dee2's Avatar
Re: 72 K30 Build
Now that we are getting down to starting the frame shortening process I’m having second thoughts about all the frame splices and frame repair on my trailer towing 4x4/work type truck. I now know its doable with the K3500 frame and would probably be fine but I’m debating if we should or if just using a C30 frame is the better option? The K3500 splice job is going to have to be a farm out for us (started the quote process) as we just don’t want to be plagued with frame problems after the K30 is built.
Brett
Old 02-04-2015, 11:50 AM   #191
7dee2
7dee2's Avatar
Re: 72 K30 Build
No comments on the frame statement above? Just thinking out loud and starting to finalize plans for the next phase.
So back to the cab after 2 rounds of weld, grind, weld & grind this is how the inner upper patch is looking (tumor removed).
Brett
Old 02-04-2015, 12:51 PM   #192
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: 72 K30 Build
Cutting down the K3500 frame should not be terrible, and can be plenty strong (in fact stronger than factory) if done with correct fish plates and a good welder.
That said, when you start getting into multiple cuts and splices, you increase the probability of something going amiss. With the C30 frame, a lot of the hangars and so forth line up with factory holes, which allows you to keep things aligned pretty well.
Either way, what's best is what you're comfortable with. On my last project (as you know) I did the original frame with modified hangars and such. On my current one, I'm building a hybrid frame from a different generation truck and a metric G-body. So I'm not really biased
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 02-04-2015, 05:57 PM   #193
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 K30 Build
I agree with what Jjorgensen52 said. On my 76 I did a step cut to help make it stronger. I used to work in a heavy truck frame shop and we used to straight cut them up to a certain length. All the ones we did got sleeved with minimum of 1/4" cold rolled. On super long rigs, we angle cut them. None of them ever got fish plates either. They never had any come back and they had been doing truck stretching/shortening and frame altering since 1979. We had a dump truck come in that they built in the mid 90's that had been rolled. The frame was straight where they stretched it and didn't start to be roled and twisted until after the sleeve ended. We saw all kinds of mangled trucks, and fixed 98% of them.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-05-2015, 12:33 PM   #194
7dee2
7dee2's Avatar
Re: 72 K30 Build
I agree 100% so after a lot of consideration and a pretty big frame fab quote (6 splices w/fish plate and the right rail repair, 2 of the splices were to add 72 frame horns) from one of the better welders in my area I have decided to finish scrapping the K3500 frame.
We are going to try and acquire another C30 133" frame (new plan A?) and if that doesn't fly then we'll go with standby plan B (use my blue C30) for the frame. This new direction does simplify some things and complicate others but its all good cuz there is a plan right???
Brett
Old 02-05-2015, 12:41 PM   #195
7dee2
7dee2's Avatar
Re: 72 K30 Build
More cab progress, the large back patch is looking fairly flat! Saweet!
Brett
Old 02-05-2015, 05:40 PM   #196
Dieselwrencher
Re: 72 K30 Build
It's coming along nicely!
Ryan
Old 02-05-2015, 08:24 PM   #197
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Nice!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-06-2015, 12:29 PM   #198
7dee2
7dee2's Avatar
Re: 72 K30 Build
Nice!
Thanks you guys! We’re thinking it should hold a window OK, here’s how the upper is looking just needs a little more luv on the lip and filler will catch the rest.
Brett
Old 02-06-2015, 09:45 PM   #199
Dieselwrencher
Re: 72 K30 Build
Looks like it should hold the window gasket just fine.
Ryan
Old 02-09-2015, 11:26 AM   #200
7dee2
7dee2's Avatar
Re: 72 K30 Build
This is how the entire back panel looks.
Brett
72chevy, dually, flatbed, k30, motorhome
