Old 02-28-2016, 12:06 PM   #176
65sub
65sub's Avatar
Re: Ian's Tennessee Honey '64 Short Box Step-side - England
Nice job on the trailing arms Ian
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-28-2016, 04:21 PM   #177
ibrown50
ibrown50's Avatar
Originally Posted by Paul Y View Post
Ian,
Very timely as I am about to commence the same operation on my trailing arms.
Quick question, what gauge did you use for your strengthening plates, difficult to see from the pictures.
P.
I used 1/8" (but 3mm would be fine) it worked a treat for the plug welds, any thinner wouldn't have worked, any thicker and I'd still be drilling holes
Richmond sometimes has some odd numbers, just a bit off. You calculated correctly. I would assume that is supposed to be a 3.42 (or close enuff) posi.
Thanks Bill thats what I thought too, however it appears you were right Richmond has some odd numbers
Originally Posted by Grizz1963 View Post
Good looking compressor Ian.
Progress as you say, is progress..
It is indeed and you are making great progress at the minute
Originally Posted by Johnny_Lamebridge View Post
Ian, have a look here:
http://www.richmondgear.com/partsearch/search.php
It appears that you have a 4.10 ratio. Lucky you!
Thanks Johnny 4:10's and a posi ..... drive it like you've stolen it
Thanks Dale, really appreciated. But still very simple stuff compared to your build
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 02-28-2016, 07:14 PM   #178
Paul Y
Thanks Ian!
Looks like a steel run is in order.
P.
Paul Y is offline   Reply With Quote
Old 04-09-2016, 05:43 PM   #179
ibrown50
ibrown50's Avatar
Not done an update for a while, so here we go. I've been working on the rear suspension, it's a 5" static drop using POL components.
The after all the strengthening the trailing arms have had they were finished off with new poly-bushes, so easy to fit a 9 year old can do it (and here is one demonstrating this )
Got the axle cleaned and painted, put fresh oil in and a new gasket, all good to go.
Name:  Ready to load.jpg
Old 04-09-2016, 05:49 PM   #180
ibrown50
ibrown50's Avatar
Springs are -4" with matching nitrogen shocks and new spring cups
Plus 1" lowering blocks and new U-bolts.
I also used the POL shock relocation kit which corrects the shock absorber angle on lowered trucks. The space between the upper brackets was less than the shocks, which although easy enough to tweak is not great given everything came from the same place.
Name:  Shock bracket.jpg
That said this is the first problem I've had with anything from POL and I remain a big fan of POL if you are working on a budget.
Old 04-09-2016, 06:40 PM   #181
Grizz1963
Grizz1963's Avatar
Even a 9 year old can do it.
Nice.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-11-2016, 02:28 PM   #182
ibrown50
ibrown50's Avatar
The axle in my truck is 4:10 posi unfortunately it is also from a 65 (panhard bracket on the diff), my truck is a 64 (panhard bracket on the axle), this means if I use a 64 panhard bar it is too long and if I use a 65 the chassis bracket in the wrong place
The PO had not let mere technicalities like this get in the way and had simply bent a 65 bar until it lined up. I am hoping to come up with better solution
I am toying with the idea of leaving the bar full length and fabricating a bracket to sit on the outside edge of the chassis rail, the plus is it will give me the longest bar possible, the minus is it will be difficult to make it look good. I am undecided, so, while I am mulling this over I thought I would turn my attention to a bit of stripping down ready for a couple of rust repairs I need to do.
First up I removed the passenger door upon removing the check strap and found this absolute masterpiece of engineering.
A check strap made from a 3/16" spanner and 3/8" hex wrench.
Name:  Check link 1.jpg
It made me smile, I will definately keep it........but not on the truck
Old 04-11-2016, 02:37 PM   #183
ibrown50
ibrown50's Avatar
On with the strip down. The good news is there is very little rust,
The bad news is the truck has clearly been strafed down the passenger side and has been repaired using tons of filler,
I chipped this out of the cab corner, it would have been so easy to knock out there's really no excuse for using this much "bodge".
I normally have panels media blasted before paint, however, I have recently bought this paint stripper,
Name:  Paint stripper can.jpg
If paint stripper could be "weaponised" this would be it. It's clearly no good for the environment, dolphins (or people come to that) but it's also not good for paint, one coat had the fender down to bare metal.
Name:  Paint stripper 1.jpg
I'll strip the fender and door and decide where to go from there, but I suspect there will be a replacement door in my future somewhere.
Old 04-11-2016, 02:49 PM   #184
Grizz1963
Grizz1963's Avatar
Progress is progress Ian, even the direction you are headed in right now.
I really think a box frame with that lump of filler and the door check mounted in there would be a great bit of history for the study.
I have the pan hard rod I removed from my truck, the bushes are shagged, but could one move them from your new unit after cleaning and painting my old one??
If so, you are welcome to it.
Old 04-11-2016, 03:32 PM   #185
mjh1965
mjh1965's Avatar
it looks like some people think it's easier to fill a dent than knock it out . Yours must have gone to the same body shop as Paul y's . Glad you didn't find to much rust .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 04-11-2016, 03:53 PM   #186
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Ian, re your Panhard Bar...
I had the same situation in my truck. Here's what I did, starting at post #87... http://67-72chevytrucks.com/vboard/s...=642296&page=4
I suppose bending the bar would work too.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 04-11-2016, 07:59 PM   #187
lumpy63
lumpy63's Avatar
Talking Re: Ian's Tennessee Honey '64 Short Box Step-side - England
Hey Ian I have really enjoyed reading your thread, as a youngster i spent many summers in northern England as my parents are from Yorkshire. My current project is a 66 c10 long bed to short bed conversion , ill post some pics as soon as I figure it out "definitely not technically inclined" turns out were both vintage 1963 cheers for now Colin
lumpy63 is offline   Reply With Quote
Old 04-11-2016, 08:31 PM   #188
65sub
65sub's Avatar
Rust free is definitely nice. Even stripping paint and digging out bondo is progress.
Dale
Old 04-12-2016, 05:18 PM   #189
ibrown50
ibrown50's Avatar
Thanks Rian, I'll definately keep the check link, I think the filler got swept up, but I'm sure to find another lump . Thanks for the offer with the panhard bar, I'll let you know
Looking at Paul's thread I'm glad too
Thanks Johnny, I remember reading this, it's a great solution and executed to your usual high standard.
Hi Colin, it's a really small world, I spend one or two days every week in York City (it's beatiful) look forward to the pictures of your truck
I agree Dale, and I don't mind digging out bondo if I find decent metal underneath
Old 04-12-2016, 06:01 PM   #190
Paul Y
Looking good Ian.
P.
Old 04-13-2016, 02:28 AM   #191
Grizz1963
Grizz1963's Avatar
Attachment 1521535
Attachment 1521536
Attachment 1521537
Attachment 1521538
Attachment 1521539
I will try to get my "new" door out this weekend and see if I can get a neighbour around to help me hang it for fit.........
If it fits, I need to strip my red door down As I have given the quarter window to Martin as well, and then we need to get the red door plus Ta2Don's door cutout repair panel and your pallet trolley that is still stored here under the "shed" caravan up to you. So your truck seems to be turning into a Frankenstein like Pauls with bits from Arkansas, Kent etc
They are both quite bulky pieces so a visit and BBQ may be in order. I am sure Martin and Paul would be game for some burnt offerings. (Meat..... That is)
Will let you know if it all works out.
Old 04-15-2016, 02:25 AM   #192
ibrown50
ibrown50's Avatar
I finished stripping the passenger side fender which revealed a large (thick) patch of bondo.......I just had to know what was behind it.
Using my favourite method of propane torch and scraper (if you try this, wear a mask, if the filler catches fire the fumes are terrible) I removed the bondo
What was behind it was a really ugly, snot welded patch, which pretty much sat on top of the panel.......I had to know what was behind it
Using a thin cutting wheel, as carefully as I could, I cut the welds around the patch, which revealed pretty much the same rot hole as most other fender get.
At this point I would normally buy a new fender but having seen how poor some replacement fenders are I'll reserve my decision until I've removed the bondo from the front
Old 04-15-2016, 02:56 AM   #193
mjh1965
mjh1965's Avatar
Now is the time to ask yourself repair or repo ?
MY BUILD THREAD:
Old 04-15-2016, 06:05 AM   #194
[JP]
[JP]'s Avatar
Interesting there on the panhard bracket location...didnt even see that when I done mine not long ago.
the previous owner, just welded an extension on the panhard rod. thought about buying an adjustable panhard rod, but dont really need to spend that money right now. so just left it.
did put polly bushes on the panhard rod and control arms seeing as I had the rear axle out.
I got a rebuilt posi axle on mine, I have no lowering blocks and not a clue how short my rear springs are. do you know how long your rear springs are?
My 65 stepside build/work on thread - http://67-72chevytrucks.com/vboard/s...d.php?t=693138
[JP] is offline   Reply With Quote
Old 04-15-2016, 03:25 PM   #195
ibrown50
ibrown50's Avatar
JP
The springs are fitted so there is a small amount of load on them but as they sit fitted they are 9" high (they are 4" drop from POL)
Old 04-15-2016, 04:27 PM   #196
[JP]
[JP]'s Avatar
cheers!
going to check what mine are, so I have an idea of what they are in relation to standard. just for future reference
Old 04-15-2016, 05:33 PM   #197
Paul Y
Ian,
How tall are your front springs?
P.
Old 04-16-2016, 03:14 PM   #198
ibrown50
ibrown50's Avatar
Paul,
New springs are 2" drop POL and measure 10 1/2", old springs are 12 1/2"
Old 04-16-2016, 03:34 PM   #199
ibrown50
ibrown50's Avatar
Finished digging the bondo out of the front fender today,
Looks like the fender has had some damage which has been repaired using the "drill holes and slide hammer method", I can understand doing this on closed panels and box sections (although it's not something I would do) but on a fender where you can get a hammer or dolly up the back
There's a crease in the lower fender and a couple of rust holes too, there's a good days work or more, sorting this one, I'll pull the other side and decide whether I'm buying fenders too.
Old 04-16-2016, 05:53 PM   #200
Paul Y
Paul,
Attachment 1523123
Thanks Ian,
Could you measure the coil thickness?
My springs are also 10.5 but have had a lump cut off the bottom. Need to,increase my ride height but 1/2" but dont know what to buy to make the difference.
Maybe yours are thicker and that makes the difference. Make sense?
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
