Old 03-04-2022, 09:33 PM   #176
rickcdewitt
rickcdewitt's Avatar
Re: 4x4 1971 K20 build
So you had a radiator made to fit? Or bought one that kinda worked? Also what motor mounts? Adapter plates and old mounts? Duramax mounts?
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 03-04-2022, 10:06 PM   #177
Rednwhitec20
Rednwhitec20's Avatar
I bought a radiator that is made for a 71 K20, just an aluminum one. If you’re running a manual you’d probably be fine but the Allison needs at least a 1/2” hose for the trans cooler running through water, which narrows you to only using a duramax rad. I have a double stacked air to fluid cooler with a fan and it barely keeps it cool enough just cruising. For mounts I used motor mount plates and had eyelets welded to it and it bolts to the custom crossmember using two bolts. So All custom pretty much
Rednwhitec20 is offline   Reply With Quote
Old 03-05-2022, 04:44 PM   #178
rickcdewitt
Sorry to hear its giving you issues. I wonder if a cummins radiator could be used they fit under a 69-72 hood
Old 03-05-2022, 06:08 PM   #179
LT7A
I see the words - for cruising - in your reply. That indicates that there may be some progress. How about an update? That's quite a rig you have built.
Old 03-05-2022, 09:25 PM   #180
Rednwhitec20
I believe a stock style radiator with a manual fan would be great. Mines does okay with electric fans but the trans gets warm.
Here is the unit. I’ve got about 8k miles on it since it’s been road ready.
Old 03-06-2022, 03:57 AM   #181
LT7A
Here, fixed it. They thing is a beast!
4x4 build, 6 inch lift, duramax conversion, duramax swap, k20
